Old 11-02-2009, 11:04 PM   #1 (permalink)
I need HELP ASAP!!!!!!
I was towing our excavator, around 12k, and all of a sudden the truck started to surge under load. As long as I kept it under 1600 rpm it ran fine, as soon as I went over 1600 rpm it would start surging. After I got it home I noticed that the lift pump was not running. So I ordered an AirDog hoping that that will fix the surging. Am I on the right track? Also, their were no codes. Any other ideas?
2000, 2500, 24v, NV4500, NP241DHD, BHAF, BD Wastegate, Quadzilla Boost Fooler, AirDog 150, Dana 80. Started Life As A Gasser
MnDLawn is offline   Reply With Quote
Old 11-02-2009, 11:11 PM   #2 (permalink)
dodgediesel59's Avatar
It is very possible the VP was running empty on fuel. Its hard to say if it will live or die, but the aftermarket lift pump is needed anyways. All you can do is put the pump in and hope for the best.
Robert
2001 2500 ex cab long box. flat bed with dual 5" stacks 4 gauge pillar with boost, egt, fuel press, and trans,billet auto,quadzilla xzt+, Fass 150, 125HP injectors,4.10s bfaf
dodgediesel59 is offline   Reply With Quote
Old 11-02-2009, 11:13 PM   #3 (permalink)
caleb's Avatar
check for a code one more time.... sounds to me like the pump is starting to go out
01 24 valve 5spd QC/SB 2wd....soon to have stg2 monster pump/hurricane stg2 injectors,smarty s-03 w revo,juice w attitude w hot unlock, 5" exhaust ,silver bullet,fass 150 and south bend 750
caleb is offline   Reply With Quote
Old 11-02-2009, 11:14 PM   #4 (permalink)
grazmo's Avatar
fuel pressure guage is a good idea to so you can tell if your lift pump is doing its job
01 CTD QC Short Bed, 5" Exhaust into 5" Flat Black Stack, Juice w Attitude stacked w Smarty, BHAF, Raptor 100, ATS stage 2 trans, ATS 5 Star TC, Aurora 4000 , Stage 5 Jammers
grazmo is offline   Reply With Quote
Old 11-02-2009, 11:27 PM   #5 (permalink)
I have a fuel pressure gauge, but it as one of the cheap a$$ glowshift ones and it bounces all over creation. I'm just hoping the VP was running out of fuel, I run 2 stroke in it so I hope that saved it.
Old 11-02-2009, 11:28 PM   #6 (permalink)
dariddell's Avatar
i hope it lives good luck man
2001 24-valve, Fass 150, Edge W/attitude w/hot code, aurora 3000, 100hp sticks, BD converter, lock up switch, BD pressure loc, billet output shaft, custom clutches, ats valve body, 5 inch stacks, american racing rims, afe intake, and some other stuff!
dariddell is offline   Reply With Quote
Old 11-02-2009, 11:34 PM   #7 (permalink)
Jimbowe's Avatar
You may need a needle valve or snubber (if the gauge is electric) to make it read steady. the fluctuation is most likely caused by the water hammer effect from the VP44.
98.5 3500 dually 4X4, BHAF, 14mm turbo exh, B&D exh man, 80hp edge inj, FASS 95, PowerMax, CoPilot, PacBrake, TripleLock LS converter, HP VB, MagHytec DD Tran pan, 2nd Tran cooler with fan, 3.55 gears, MBRP 4" exh, 93 gal aux fuel.
Jimbowe is offline   Reply With Quote
Old 11-06-2009, 09:49 PM   #8 (permalink)
Put the Airdog 150 on and the truck still surges, but not as bad. Any other tips?
Old 11-06-2009, 10:04 PM   #9 (permalink)
i think you know the dreaded answer were going to give you.
whats your fuel pressure at? and get a needle valve on that gauge just barely crack it open.
1999 2500 Laramie 4x4, Longbed, nv4500, goose neck hitch, boost/pyro gauges, raptor 100.
Dracozny is offline   Reply With Quote
Old 11-06-2009, 10:55 PM   #10 (permalink)
FP is steady at 15psi. And no death codes yet. I did have a weird one, P1698 - Which is only for autos, mine is a 5-speed. I just can't bring myself to the realization of dumping another $1000 into her.
Old 11-06-2009, 11:18 PM   #11 (permalink)
edcasey's Avatar
Ya...the 1698 makes no sense. A 1689 would make perfect sense.
2000 3500 4x4, auto 4.10,BHAF, 4" MBRP, Power Puck, Converted to SRW, Walbro, DiPricol FP, PSC DSS, triple disk, billet trans
edcasey is offline   Reply With Quote
Old 11-06-2009, 11:34 PM   #12 (permalink)
dennhop's Avatar
isnt 1698 the companion code? Can't remember off the top of my head, but if you do a search, you should find one. try the APPS, or the MAP sensor...dunno, but maybe that'll help.
2001 QCSB 4x4, 5spd, AD150, Milemarker SI9500, CON OFE, Edge Comp(IT'S ALIVE!) stacks, HBS 2 in leveling kit, FP/Pyro/Boost Dipricol Optix gauges, RV275s
2003 QCSB 4x4, 48RE, stock...and will remain so...or my wife might kill me.
dennhop is offline   Reply With Quote
