Old 11-06-2009, 11:37 PM   #13 (permalink)
edcasey's Avatar
I didn't notice the second definition. It also means "Bus communication failure to PCM. A companion DTC was set in both the ECM and PCM.'
2000 3500 4x4, auto 4.10,BHAF, 4" MBRP, Power Puck, Converted to SRW, Walbro, DiPricol FP, PSC DSS, triple disk, billet trans
edcasey is offline   Reply With Quote
Old 11-07-2009, 12:07 AM   #14 (permalink)
Originally Posted by dennhop View Post
isnt 1698 the companion code? Can't remember off the top of my head, but if you do a search, you should find one. try the APPS, or the MAP sensor...dunno, but maybe that'll help.
1693 is the companion code. its also in a sticky at the top of this board
1999 2500 Laramie 4x4, Longbed, nv4500, goose neck hitch, boost/pyro gauges, raptor 100.
Dracozny is offline   Reply With Quote
Old 11-07-2009, 01:06 AM   #15 (permalink)
Jimbowe's Avatar
You can look up the codes on Mopar1973Mans web site:
http://mopar.mopar1973man.com/pdf/error-codes.pdf
98.5 3500 dually 4X4, BHAF, 14mm turbo exh, B&D exh man, 80hp edge inj, FASS 95, PowerMax, CoPilot, PacBrake, TripleLock LS converter, HP VB, MagHytec DD Tran pan, 2nd Tran cooler with fan, 3.55 gears, MBRP 4" exh, 93 gal aux fuel.
Jimbowe is offline   Reply With Quote
Old 11-07-2009, 10:46 AM   #16 (permalink)
www.Mopar1973Man.com
Mopar1973Man's Avatar
Originally Posted by edcasey View Post
Ya...the 1698 makes no sense. A 1689 would make perfect sense.
Ok...
P1698 No CCD Messages received from PCM Bus communication failure to PCM. A Companion DTC
(PCM is no longer talking on the CCD network for some reason)
P1689 No Communication Between ECM and Injection Pump Module Data link circuit failure between ECM and fuel injection pump. Low power, engine derated, or engine stops.
(VP44 and ECM are no llonger talking)
P1693 DTC Detected in PCM/ECM or DTC Detected in ECM
A Companion DTC was set in both the ECM and PCM.
(A problem exist in one or both modules - Companion code)
Remember to smack the THANKS! button for those that helped you or you think that post is helpful to others!
