2001 dodge 24valve no oil pressure - Page 2 - Dodge Cummins Diesel Forum
post #13 of 22 (permalink) Old 10-31-2009, 10:55 PM
You betcha, glad to be of help! I know when my sensor went out, I unplugged it and plugged it back in and it worked for a short period of time, then quit again. Since I replaced the sensor I've had no issues.
And to give credit where it's due, I linked the diagram from mopar1973man's website
-Paul
2006 Ram 2500 QCLB from Florida. Allegedly came with a shift kit, and she's got 285/70/17's. Other than that still stock for now...
quadgoat is offline
post #14 of 22 (permalink) Old 10-31-2009, 11:17 PM
Rescue Tower
Shainer's Avatar
Download a shop manual. You will need it somewhere down the road. It's not very often these engines loose oil pressure, but man that's a big risk to take. Even used engines are not cheap to buy.
Custom pinstriped Power Wheel. I started out with very little... I still have most of it. Feel free to PM me anytime.
Shainer is offline
post #15 of 22 (permalink) Old 11-01-2009, 03:13 PM Thread Starter
xx_lethal.error_xx's Avatar
Where's the cheapest place i can pick this sensor up?
2001 Black dodge 2500, short-bed, quad cab, cummins 24v,auto,4x4,Bhaf,Edge Ez,6" Mitre Stacks.
xx_lethal.error_xx is offline
post #16 of 22 (permalink) Old 11-01-2009, 03:15 PM
Rescue Tower
Shainer's Avatar
Check with your local auto parts stores. Nothing special about the sending unit.
Shainer is offline
post #17 of 22 (permalink) Old 11-01-2009, 03:15 PM Thread Starter
I just spoke to a buddy of mine who is a good mechanic,He said to replace the oil pressure sending unit, is that the same as the oil pressure sensor just different terms???
post #18 of 22 (permalink) Old 11-01-2009, 06:10 PM
samething, different names
2003, QC/SB. Edge Juice,Hot, AirDog150/BMS50 nozzles S&B CAI, BD Flex plate/tripple loc T/C. georend VB/ Trans rebuilt by Me. Bilstien5100. carli coils, Air Bags. RETIRED Military Mechanic (20yrs)
nickg is offline
post #19 of 22 (permalink) Old 11-01-2009, 06:52 PM Thread Starter
I found the oil pressure sensor on this website Cummins 24 Valve Parts
Price is $88.20 , this would be the part i need correct?Its near the bottom of the page.
post #20 of 22 (permalink) Old 11-05-2009, 05:31 PM Thread Starter
Finally got the new oil pressure sensor today.First off, didnt have the right size socket to take the old sensor off nor to install the new 1, picked up the socket to install the new 1 which is 1 /16 deep socket for oil pressure sensors.Turns out that socket does Not fit the stock sensor in my truck, after 3 more trips to napa after trying to find the right size socket to get the old sensor off it turns out its a size 32 deep socket,Took the old off installed the new 1, oil pressure now working again,what a royal pain in the it was to get to that sensor.Thank you all for who helped and put their 2 cents in.
-Rich
post #21 of 22 (permalink) Old 03-15-2010, 11:31 PM
Just replaced the oil pressure sensor on my '99. Got a used sensor on ebay for $26. FYI the correct size deep well socket for stock sensor is 1 1/4 inch. The 32 mm will work but is a little loose. Slide under the truck on the driver's side, reach up just in front of the starter, and the sensor is right there. Took about ten minutes.
chinooklr is offline
post #22 of 22 (permalink) Old 03-16-2010, 12:45 AM
VP Moderator
dozer12216's Avatar
Some are just gifted on replace and others can't get started.
Remember, every job requires a new tool purchase. Part of mechanics creed.
dozer12216 is offline
