Transfer case problems - Dodge Cummins Diesel Forum
post #1 of 8 (permalink) Old 09-18-2009, 12:56 PM Thread Starter
When my truck is up to highway speeds 45+ I get a bad vibration. If I shift into 4hi the vibration goes away. I think I am in the need of a rebuild. The case is a 241 DLD.
Is anyone knowledgable about these cases or know what could be causing this vibration?
Also do many guys pull with this transfercase or are they swapped out for a NP205?
Slipster is offline
post #2 of 8 (permalink) Old 09-18-2009, 01:08 PM
Rescue Tower
Shainer's Avatar
You driving that on asphalt in 4 low at 45 mph?? Just looking for clarification as to what you are doing.
Custom pinstriped Power Wheel. I started out with very little... I still have most of it. Feel free to PM me anytime.
Shainer is offline
post #3 of 8 (permalink) Old 09-18-2009, 02:15 PM
VP Moderator
dozer12216's Avatar
NP205. Is that not the old full time iron horse. To each his own I suppose.
When you put in 4HI your are loading the driveline and can't vib. Look for loose and worn drive line components first. U joints, diff assy, ect. Could it be a bad tire or balance??
What ever it is in transfer case will be apparent once you get into it.
dozer12216 is offline
post #4 of 8 (permalink) Old 09-18-2009, 04:25 PM
Osar's Avatar
NP205 is old iron part time. NP203 is the old iron full time.
2000 2500 4x4, QC, LB, rebuilt auto trans w/shift kit, ISS Pro EV2 gauges, AD150, Edge Comp, BHAF, Chevy RWC.
Osar is offline
post #5 of 8 (permalink) Old 09-18-2009, 11:41 PM
You've peaked my curiousity too. Are you driving in mud or snow? Drag racing or pulling? Or did you just try it for troubleshooting reasons?
02 2500 4x4 HO Quad Cab-short bed Adrenaline-Brute Force-4" Stainless MBRP exhaust-boost elbow-Airdog 100- BD wastegate- Valair ceramic/kevlar single disc
96ram1500 is offline
post #6 of 8 (permalink) Old 09-19-2009, 02:27 PM Thread Starter
While driving down the road (asphalt)the truck all of a sudden developed a bad vibration. It seems like as soon as the tourque converter locks up is when the vibration gets worse. I could feel the vibrations through the 4 wheel drive shifter so I pulled it back into 4 HI while driving and the vibration stopped and the truck smoothed out. I pulled the front driveshaft and the vibration was still there. Even if I shift into 4HI.
The NP 205 is an all gear cast iron case no chain and no aluminum. It came divoriced and attached to the transmission. When divoriced the truck uses a 2 wheel drive tranny with the driveshaft going to the transfer case. It only came divoriced on some Dodges and the Ford hi boy. With a divoriced case you could move the transfer case back to help with balancing out the truck and shortening the rear driveshaft. The one downside besides the weight is the 1.96 low range. The 241 has a 2.72 low range.
Slipster is offline
post #7 of 8 (permalink) Old 09-19-2009, 04:17 PM
you do not want to sled pull with a 241 dld; there just not going to hold up. the slipped yoke on the driveshaft that slides into the rear of the transfer case is your week link. if you still want to keep a slip yoke style driveshaft/transfer case, just upgrade to the 241 DHD; its still a slip yoke style; just much stronger and bigger tailshaft. you'll have to have the right end put on your driveshaft for that bigger tailshaft. you can find a 241 DHD in any dodge ram 3500 dually.
however; my recomendation(if your makein a lot of torque and horsepower) just go with either the gear to gear like some are saying. or go with a 271 D transfer case with a fixed yoke on the rear.....you'll have to shorten your rear driveshaft and put the fixed yoke end on the driveshaft. their the kind that bolt to the transfer case instead of just slip in. this way if you snap the rear drivshaft, you can still get the truck on the trailer without losing any tranny fluid. they are also much stronger and will take much more abuse. the 271 D is still chain drive but very reliable. they will bolt right up to any dodge 4wheel drive transmission from 1994-2002; most you'll have to do is just lower your skid plate bracket, but it don't take much. and also have the rear driveshaft refabbed....the front driveshaft will bolt right up, no fabbing needed to front shaft. need any more info just holler.
Dieselholic is offline
post #8 of 8 (permalink) Old 09-20-2009, 08:11 AM Thread Starter
Well I figured out what the vibration was and its not the transfercase. When I dropped the driveshaft I found the front end was not engaging in 4 wheel drive. I pulled the cover on the center axle disconnect and the shifter fork was busted, I could move both axles all over the place and there is no fluid whatsoever only thick grease with busted bearings and the shift fork. So my vibration is from the axles just wobbling around in the housing. Time for a front end rebuild.
Slipster is offline
