just died while driving - Dodge Cummins Diesel Forum
post #1 of 15 (permalink) Old 09-10-2009, 11:57 PM Thread Starter
Hi guys, im very new to this forum. I have a 00 2500 with Edge with juice and a magnaflow 4" exhaust.
Last monday I was driving down the road at about 70 mph and my truck just died and will not restart. I love my truck and want to do more to it later on. Im upset that I cant drive it.
It just cranks and cranks. My programmer shows lift pump psi at about 9 while cranking. I just found out that my psi while running had been to low. I just read that before I posted this.
I plan to repair it myself and will appreaciate any help.
ramfever 2500 is offline
post #2 of 15 (permalink) Old 09-11-2009, 12:21 AM
VP Moderator
dozer12216's Avatar
Well, start by checking for fault codes. Turn key on, off, on, off, on and watch odometer display. Report any P codes that display.
dozer12216 is offline
post #3 of 15 (permalink) Old 09-11-2009, 12:22 AM
CopenhagenCummins's Avatar
Sounds like your doin a VP44 injection pump. EXACT same thing happened to me and im sure hundreds of others on here.
-(June 28/14 Hit by lightning, burned electrical inside and out) 2011 ram 2500 Laramie megacab 4x4 6.7L cummins. Smarty, Flo-pro 5" early dump, EGR and DPF delete, rollin 35s
CopenhagenCummins is offline
post #4 of 15 (permalink) Old 09-11-2009, 12:23 AM
R.Kelly's Avatar
do the trick with the ignition: on off on off on and leave it in the 3rd on position, the codes will read off in the odometer box. Sounds like injection pump, but find out what the codes are
2000 Ram 2500 black on silver, garmon built tranny, FASS 95/150, Autometer gauges,6 inch aussies, NON 53 BLOCK
silencer ring MIA, BHAF, and tons of turbo whistle, NEW VP44
R.Kelly is offline
post #5 of 15 (permalink) Old 09-11-2009, 12:30 AM Thread Starter
Ok guys, Will any certian code come up that indicates the pump is bad?
Thanks
I have a P0720 and P1693 code
2000 Ram 2500 QC with 2.5" leveling kit and Rancho Shocks. Edge Juice with Attitude and MagnaFlow 4" exhaust and muffler. Just adding a Blue Chip X VP44 and AirDog 2.
post #6 of 15 (permalink) Old 09-11-2009, 12:41 AM
Rescue Tower
Shainer's Avatar
Common guys... if you are gonna tell him his pump is dead, then at least give him the info to verify it instead of making him ask.
0216 is the death code. 10-20psi is what you want at all times.
Custom pinstriped Power Wheel. I started out with very little... I still have most of it. Feel free to PM me anytime.
Shainer is offline
The Following 2 Users Say Thank You to Shainer For This Useful Post:
Mopar1973Man (09-11-2009), ramfever 2500 (09-11-2009)
post #7 of 15 (permalink) Old 09-11-2009, 12:57 AM
VP Moderator
dozer12216's Avatar
The 720 code if for RPM speed sensor on left side of OD housing. It might be bad, BUT WILL NOT make engine die.
The 1693 is a general code that indicates a companion code elsewhere. It is one of indicators for failing VP44. Code P0216 is one of the death codes for a VP44. Sometimes the 1693 code is all that is given on VP44 failure.
You might try repriming the system, but the prognois is looking toward a VP44 fail. Sorry.
The Following User Says Thank You to dozer12216 For This Useful Post:
post #8 of 15 (permalink) Old 09-11-2009, 07:52 AM
R.Kelly's Avatar
i had the 1693 code and had to get a code reader to pull the p0216... so if you can get access to a code reader you can see what the companion code for the 1693 is
R.Kelly is offline
post #9 of 15 (permalink) Old 09-11-2009, 08:10 AM Thread Starter
I did just replace the speed sensor in the tail shaft of the tranny about 2 weeks ago. Would this be the rpm code?
post #10 of 15 (permalink) Old 09-11-2009, 09:16 AM
here is more reading for you..
Blue Chip Diesel Performance Specialists
2003, QC/SB. Edge Juice,Hot, AirDog150/BMS50 nozzles S&B CAI, BD Flex plate/tripple loc T/C. georend VB/ Trans rebuilt by Me. Bilstien5100. carli coils, Air Bags. RETIRED Military Mechanic (20yrs)
nickg is offline
post #11 of 15 (permalink) Old 09-11-2009, 09:35 AM
Mopar1973Man.Com
Mopar1973Man's Avatar
P0720 is the old error code from the speed sensor you replace...
Dieing VP44.. P0216, P1688, P1689, P0251, P0253.. Sometime no errors at all... (Electronic failure).
Lack of fuel pressure causes P0216. (Lower than 10 PSI)
Mopar1973Man is offline
The Following User Says Thank You to Mopar1973Man For This Useful Post:
mfoster48612 (09-11-2009)
post #12 of 15 (permalink) Old 09-11-2009, 07:51 PM
My 2000 just did the same thing, luckily no death code. It's been one week and still cant figure it out. I got a code reader on the way, hopefully that will help me get it straight. Hope it aint my vp44!
HAWAIIAN is offline
