Sputter, miss, cut out!!!! - Dodge Cummins Diesel Forum
post #1 of 17 (permalink) Old 08-27-2009, 01:18 AM Thread Starter
Oregon Chapter President
Electric_Cowboy's Avatar
My friend has a 2001 CTD. I'm trying to help him figure out something on his truck. His truck is cutting out, and sputtering at various rpms, whether under load, or at idle sporadically and intermittent. Like how a gas engine will misfire. Has once died at a red light. There seems to be no loss of power at the wheels, and it starts up just fine every time. About three weeks ago he got the p0216 death code for the vp44, so about two weeks ago we swapped in a newly rebuilt one, and added a FASS 150series/95gph water/air separator which replaced the stock lift pump. After all the install was complete, we cleared the code and took it for a test drive. No codes came back, fuel pressure at idle was 16psi and around 12psi WOT I think, and it seemed to run great. A week goes by, and he gets the code P0370 Fuel Injection Pump Speed/Position Sensor Signal Lost. Did some research and seems like that code is only associated with pump failure, but how it's brand new?! So, we decided to clear the code and see if it came back. That was early this week, and it has not come back, but the problem still continues. He says he's not sure if it's just coincidence, but on sunny warm days it does it the most. Do you have any ideas?
I was at first thinking a pin on the pump, or something with the wire harness, but all checks seem to show nothing wrong. Thought maybe he was sucking air from somewhere in the fuel line(s), but can't seem to find one. Reset the APPS already. Think it could be a MAP sensor, ECT Sensor, IAT sensor, or camshaft sensor.
Also, I was doing some reading and found out that Fords have had an issue with sensors that still operate within a set voltage range for the ECM, but overall are failing to sensor. Has anyone every heard of this happening with trucks like ours? Could this explain why there is no DTC present?
Thanks for your help and advice!
Chris
THE S.O.L.I.D CREW and temporarily truckless.
Sold: 1990 Reg Cab, AT, 4x4, 197k, Chassis Unlimited Crossover kit, D400CS springs front, DIY4X shackle flip rear, Nitro shocks, home ground pin, and a ton of body work.
Electric_Cowboy is offline
post #2 of 17 (permalink) Old 08-27-2009, 05:54 PM Thread Starter
back to the top
post #3 of 17 (permalink) Old 08-30-2009, 10:26 PM
offthewall's Avatar
My truck is doing the same thing it seems. I just installed an Airdog 150 on my truck and now it is cutting out and dying at random. Hopefully somebody can let us know what the problem is.
Grandpa's Baby Blue 1963 D-250 Cummins build in (slow) progress
1993 Ram 350 DRW aka "GREAT WHITE," 362 SXE, Hungry Diesel 6x0.13 injectors and fuel pin
2001 Ram 2500 (sold).
2005 Ram 2500. Synergy steering, Dynatrac BJs, Smarty S-06, Edge CTS with sensors, intake elbow, FASS 150, S&B CAI, Amsoil bypass filter, triple-disc billet 48re
offthewall is offline
post #4 of 17 (permalink) Old 08-30-2009, 10:32 PM
24vman's Avatar
when the truck starts acting up does it smoke?
98.5 5spd, 80k miles ,hpfp 150, hotrod vp44, 240 sticks, edge comp/smarty,66/74/14, sb3850, autometer cobalt fp, boost, pyro, stage two afe intake , 6" stacks. SOLD!!!
24vman is offline
post #5 of 17 (permalink) Old 08-30-2009, 10:33 PM
Mopar1973Man.Com
Mopar1973Man's Avatar
Maybe its a bad rebuild... Time to call about warranty...
Its a electronic failure internally on the VP44 there is nothing you can do to fix this problem unless you got a injection pump test bench...
Mopar1973Man is offline
The Following User Says Thank You to Mopar1973Man For This Useful Post:
Electric_Cowboy (09-01-2009)
post #6 of 17 (permalink) Old 09-01-2009, 02:27 AM Thread Starter
Doesn't smoke when acting up.
post #7 of 17 (permalink) Old 09-01-2009, 02:28 AM Thread Starter
Finally! Thank you, I swear I thought the same thing too. Glad to see I'm not off my rocker.
post #8 of 17 (permalink) Old 09-01-2009, 02:36 AM Thread Starter
Update... as far as I know he sent it overnight back to Thoroughbred Diesel. We pulled it on Sunday, and before that it sat for the last few days. He wasn't gonna try to drive it and get stranded somewhere if it decided not to start cause I think on Friday it died four or five times on him just trying to get it running in his driveway.
So, we all think it's the pump. I talked to Thoroughbred Diesel today and they mentioned something about the IAT sensor, but the p0370 code says it all. So I think they need to replace it. They're gonna put it on a bench for 4 hours supposedly, and if it fails they'll overnight one back. If it passes he has to cough up $250 for the bench time and they'll send it back. What kind of crap is that? This place claims they get less than 1% of pumps returned due to defect. Do they really think we're pulling their chain or something here? Do they think we enjoy pulling and putting these things in? Also, what part of intermittent do they not understand? I'm gonna be pissed if they say they ran it and got no problems, cause all this stuff started happening after we put that "new" pump in on his truck.
Sorry for the rant, but it really bugs me. People plop down their hard earned cash for something, and when it doesn't seem to be working right, and you've exhausted every measure to remedy the problem before leaning on your warranty, and they come at you with this? Just pisses me off, almost regret recommending them to him.
post #9 of 17 (permalink) Old 09-01-2009, 09:13 AM
Mopar1973Man.Com
I guess they don't want your return business then after all...
post #10 of 17 (permalink) Old 09-01-2009, 09:24 AM
I have 500 miles on my new Industrial Diesel pump and the truck died in my driveway this morning. The truck fired right back up, died 80 feet out of the driveway and started back up and I drove it 12 miles to work. It sounds just like your problem. The truck did not smoke it didn't stumble, it acted just like when the vp44 died on the highway, but starts back up.
99, 2500, 132000, alcoas, pirelli scorpions, running boards, tractor back up lights and K+N air filter platinum silver.
jmacla is offline
post #11 of 17 (permalink) Old 09-01-2009, 11:48 PM Thread Starter
My thoughts exactly!
post #12 of 17 (permalink) Old 09-01-2009, 11:51 PM Thread Starter
I guess they called him today after they had it on the bench. The computer caught it right away, something about a bad IAT sensor inside the pump. Didn't even know that they had that sort of sensor inside them. That is if IAT stands for the same thing on the block. Anyhow, they are going to over night it back to him with the issue fixed. Keep your fingers crossed that it works right this time. I'll keep ya posted.
