Edge Juice Tire Size Adjustment Question???? - Dodge Cummins Diesel Forum
post #1 of 8 (permalink) Old 08-06-2009, 06:16 PM Thread Starter
Nickscott89's Avatar
iTrader Score: 10 reviews
I have a Edge Juice with Attitude and I am wanting to adjust for the tires that I have on it but it asks for stock circumference and the circumference of the ones currently on it. How do you figure circumference on both? I am not even sure what stock tire size is in the first place but the tires currently on it are 315/70/17 and I also run 325/50/20 If someone knowa the circumference of all three please let me know!!!!!!!
2002 6 speed HO, Edge Juice, Raptor 150,200hp JL Machine injectors,AFE Intake, FB 5" straight pipe, SB DD 3250, and other goodies!!!!!
2000 5 speed 3500,edge,150's,dd3250 etc...
Nickscott89 is offline
post #2 of 8 (permalink) Old 08-06-2009, 07:02 PM
GloNDark's Avatar
I used this to calculate my tire circumferance for the Pulse after putting my 285's on.
Tire Diameter And Circumference Calculator
2008 Dodge 2500 Laramie 4x4 68rfe and a few goodies
GloNDark is offline
post #3 of 8 (permalink) Old 08-06-2009, 07:21 PM
RollinCole's Avatar
well a 315-70-17 is a 35 inch tall tire so take 35 times that by 3.14 and TA-DA = 109.9 i think thats how it works
If having the FASTEST Cummins Truck was easy.........It would be called your mom
RollinCole is offline
post #4 of 8 (permalink) Old 08-06-2009, 09:41 PM
BigRedTruck's Avatar
An empirical way to do it is mark the down most part of a rear tire and the ground at the same spot, roll ahead or back until the tire mark is down again, mark the ground and measure. This takes into account variations in tires and also the flat side of the tire.
06 3500 SRW 4x4, Quadcab LB 'Big Horn'. G56, Smarty S06-POD,Redhead steering box.
BigRedTruck is offline
post #5 of 8 (permalink) Old 08-06-2009, 11:48 PM Thread Starter
What are stock tire size on a 02 ram?
post #6 of 8 (permalink) Old 08-07-2009, 12:22 AM
245/75/16 i believe. or 95.7"
2000 2500 QCSB 4x4 217k, auto, Edge Juice/Attitude, Holley Blue, AEM Brute Force, 4" straight
cobhc is offline
post #7 of 8 (permalink) Old 07-03-2010, 11:05 PM
f44life's Avatar
well does it calibrate your speedo or only your juice speedo>?
98.5 24v 5spd 53 block 2wd/ raptor 150/ drawstraw/ full mbrp ex/ats intake mani/bhaf/edge attitude/150 nozzles/sb upgraded hydros/sb3600dd and input shaft
f44life is offline
post #8 of 8 (permalink) Old 07-03-2010, 11:15 PM
On call 24/7
98whitelightnin's Avatar
iTrader Score: 13 reviews
Stock is either 245/75/16 or 265/75/16. The door will probably have the size info on it.
2012 Laramie Longhorn, EFI by Ryan, 5" FloPro, 35x12.5x20 Toyo AT II
1995 Dually, Weston's 5x.016, 4k GSK, 5" FloPro, 255/85r16 Toyo M/T, Goerend, ARP, 60# Springs, BW 62/65/14, BW 75/96/1.10, Isspro, Fass 125, BDP Sump, 7mm DV's, 751 HP 1883 FP Torque on NOS
1998 P-Pumped 24v, 4x4, NV4500 swap
98whitelightnin is offline
