VP Failures - Dodge Cummins Diesel Forum
post #1 of 20 (permalink) Old 07-25-2009, 08:10 PM Thread Starter
VP Failures
Do the 2002 vp's go out more fequently than the previous three yrs they were used?
Maybe we could do a poll on what yrs go out sooner.
I'm still on my OE vp44 55k miles.
TIA
mjgcamper is offline
post #2 of 20 (permalink) Old 07-25-2009, 08:15 PM
Kybel's Avatar
Mine went out at about 70k miles just after I bought the truck. The old Lift Pump failure unbenounced to me. Learn from your mistakes.
2006 Mega 2500 Laramie, 5" FTE Stainless w/30" resonator, 285/75/18 Toyo MT's, XD795 Hoss Machined, Levelled, Firestone Air Bags, Smarty Jr. POD, BMS 50hp Injectors, Willys Whistler w/Amsoil Dry Filter, Isspro Rail/Boost/Pyro
Kybel is offline
post #3 of 20 (permalink) Old 07-25-2009, 08:53 PM
112k!?
Great idea and thread! I bought the 02 below about a month ago and as far as I and the previous owner know, it has the original VP. Do not know who the first owner was. I am the third owner. I will be interested in what other 02 owners have to say in this thread. I believe Mopar1973Man has an 02 as well.
Is there any way to tell if the VP has been replaced? My truck is running great without any signs of VP problems. It does have a FASS lift pump and draw straw instead of the intank pump. Runs 15 psi or greater most of the time.
After reading the Lubricity Additive Study Results below I will be trying some virgin soy or sunflower cooking oil at 128:1 (1 oz./gal) from Walmart or Sam's. This should be better than 2 cycle oil at 128:1 or the biodiesel at 50:1 AND is a great fuel.
Lubricity Additive Study Results - Diesel Place
02 2500 4x4 SLT Laramie, QC, SB, 120K, Dropped, 47RE, HTS VB, 241DHD, Gear Vendors, 4.10, QuadZilla Scout, 4" Exhaust, FASS HPFP, Draw Straw V
afgunn is offline
post #4 of 20 (permalink) Old 07-25-2009, 09:00 PM
scott 6.7L cummins's Avatar
well my buddy got 208k out of his vp and he is the original owner and he has had a power puck on for since 175k and got 275k on his truck now (01 by the way)
1999 2500 4x4 24v, Two Tone White W/ Silver,airaid intake,boost elbow, smarty, Straight pipe. 3rd Gen Chrome Clad Rims. Fass and new injection pump,somewhat of a built tranny :-P need more
scott 6.7L cummins is offline
post #5 of 20 (permalink) Old 07-25-2009, 11:06 PM
Mopar1973Man.Com
Mopar1973Man's Avatar
I lost my first one at 50K miles...
The second one is at 101K and still going strong!
Mopar1973Man is online now
post #6 of 20 (permalink) Old 07-25-2009, 11:27 PM Thread Starter
There's an idea floating around that the 02's go out sooner; reason I started this thread.
I did have a hard start, for the first time, cold morning, about a month ago. No codes.
post #7 of 20 (permalink) Old 07-26-2009, 01:15 AM
I have an 02
I have an 02 and I am in the process of replacing the VP and lift pump.
As a Diesel mechanic for 26 years I have loved the Cummins engine in the big rigs, that is why I went with the Dodge, boy am I pissed about this, I wish I would have known about the problem with the lift pump earlier, I have been telling all my friends driving the Dodge Cummins about this failure. Like I said in the past this should be a class action suit against Dodge to compensate this.
peteyscummins is offline
post #8 of 20 (permalink) Old 07-26-2009, 02:34 AM
Explosives87's Avatar
I would agree with you about the suit, but it is a cummins problem and mopar had a retofit for it.
01 2500 QCLB 4 in TB, BHAF,6 spd,Stock for now
"A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed." 2nd amendment
Explosives87 is offline
post #9 of 20 (permalink) Old 07-26-2009, 03:23 AM
Fishin2Deep4U's Avatar
Late '01's and early '02s were the worst for failure rates when using a wire tap box IMO.
Nothing to back it up, but it was always a gamble to lose a pump just after a box install back in the day.
Dave
Fishin2Deep4U is offline
post #10 of 20 (permalink) Old 07-26-2009, 07:31 AM
But it is Mopars turd of a pump that is failing and destroying the VP44, some engineer should be kicked square in the sack.
post #11 of 20 (permalink) Old 07-26-2009, 08:44 AM
Clunk's Avatar
The '98.5-'99 were reported to quit within minutes of tapping the wire due to an internal pump maching issue. I ran tapped for right at 4 years before mine let go.
'01.5 QC, SB, 6spd 4x4, Drag Comp, 4" exh. Jammer 100's, 62-65-.70A/R WG, adj.boost elbow Big Line, fuel press.pyro & boost gauges fuel cooler BHAF, Black Holley lift pump-12psi WOT Ceramic/Kevlar SD clutch, studs Take time to turn-so you don't burn
Clunk is offline
post #12 of 20 (permalink) Old 07-26-2009, 09:54 AM
O2CUMMINS's Avatar
I replaced mine @ about 95,000mi. I was the second owner and it was the original pump
2002 Cummins 24v six speed, GR 6" AUSSIES,BHAF W/ K&N air intake tube and heat shield, Quadzilla Adrenaline, Valair DD, 62/65/12, pyro,boost,and fuel pressure gauges, 100 HP sticks, FASS 150
.Chris.
O2CUMMINS is offline
