| 98.5-02 Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect..NO ADVERTISING . |
#61 (permalink) |
Im having this problem to. shutters 4th when its trying to into it and its a brand new built trans with triple disk converter. ![]() It seams every one has the same thing to say on how to fix it. First off i have my blk/org ground wire wraped in aluminum tape and foil. I've done the ats bypass on the "apps" and did nothing at all. New batteries, every ground wire replaced, cleaned alternater wires, replaced alternater tryed noise filter worked about a week and came back!!!! Im lost and fed up with it, i have a tc lock up switch and it does it on that to. Any help would be a life saver thanks NATHAN |
#62 (permalink) | |
I chose cleaning all grounds in the engine compartment, putting in an extra ground wire from the TPPS, Extra ground wire from the TCM box to the battery. This fixed my problem permanently, it is now over one year since i fixed it. As other also mention, there is not just ONE fix for this, there can med many different things causing it. Try the things that does not cost any first. Good luck guys and girls!! Last edited by toreka : 11-07-2009 at 10:17 AM. |
#63 (permalink) | |
Wraped ground wire "blk/org" in aluminum tape, replaced both batteries, replaced alternator, check and cleaned every ground, tried noise filter, tried both suncoast and ats fix and reset the apps numerous amounts of times. Any other ideas to try would be great. Thanks nathan Last edited by tx02 : 11-09-2009 at 12:19 PM. |
#64 (permalink) |
![]() Join Date: Mar 2009
Wow am i glad i found this thread, my 02 recently started doing what everyone describes, at first i assumed i had band issues. Called my trans guy( this is the only guy i have ever let drive any of my vehicles lol trust him with my life) he said could possibly be a apps or a few things that if i could leave it with him for a half day he diagnose it for me and check the internals. Problem is now that i moved i am about 40 miles from him so was trying to find time to take it to him. he said it more than likely wasnt the tranny itself since i had no problem in other gears and my temps havent changed, fluid smells and looks brand new. Gonna go threw this stuff tomorrow and see what happens. ![]()
02 Ram 2500 sport, Edge Comp, Air dog 150, big line kit, AFE stage 2, silencer gone, 5" MBRP turbo back, Banks high ram, 6" Rancho lift, 37"s, wireless train horns!!! In the works:One bad rear bumper ![]() 1955 chevy 3600....In the works but we'll say chevy made it cummins will shake it!! |
#65 (permalink) |
If the alternator is the source of the problem, why not just put the filter on it? Also can you get the filters locally (Ex: Radioshack)?
1999 Dodge Ram 2500 4X4 Auto, CAI, Walbro Lift Pump, Bypass Oil Filters, All Other is Stock
#66 (permalink) |
Went out and messed with mine this evening, wrapped that aluminum tape around the black and brown coming from the alternator, checked all my plugs and cleaned the battery terminals, werent to bad except for the cable that goes between em looks like it wouldnt hurt to replace it, got to talking to the neighbor and didnt take it out for a drive so guess i'll find out tommorrow
#67 (permalink) | |
GA VP...so close to 500hp
![]() Join Date: Oct 2007
1999 2500 4x4 Club Cab Sport. sorta functional ADRENALINE/pulse , BHAF, FBD 150 sticks, 3rd Gen HE351 retrofit, Hamilton 110lb valve springs, A1 head studs, 5" FBD exhaust, Isspro Boost and Drive pressure gauges, fuel pressure gauge, FP light, Mallory Comp 250 pump, 1/2" big line kit, Draw straw, TC lockup switch, Stealth VP plate, BD TC, BD VB, Billet input, Derale pan. 462hp and 920ft-lbs 11/14/09, I know I can get 500hp...
#68 (permalink) |
If I can get one of these I may install in hopes it would keep my TC working correctly. Understanding The Turbo EncabulatorVideo
96 & 01 2500 Cummins Auto all stock.
