2000 ram 2500 will not crank over - Dodge Cummins Diesel Forum
post #1 of 17 (permalink) Old 07-12-2009, 09:39 PM Thread Starter
Truck has been running fine. today it will not crank over. all accessories work fine. I check the fuse panel inside the cab on drivers side. I checked fuse panel next to battery. no blown fuses that I can tell. any ideas?
Ken C is offline
post #2 of 17 (permalink) Old 07-12-2009, 10:08 PM
Just Another Cummins's Avatar
Does it make just a tick noise when you turn the key?
Could be a starter. . . . .
Cameron
01 QC SB 47RE
Tinted WS and all others, Quad ADR, BD150 tips, HX35, Raptor 150-DSV, 4" MBRP,35x13.5-18s
2590.8 MM Western Straight Blade
RU "Sirius"
Just Another Cummins is offline
post #3 of 17 (permalink) Old 07-12-2009, 10:25 PM
99dodge2500's Avatar
Try moving your steering wheel up to the top position and try cranking it. Mine has a short in there and from what I hear its a common problem and it should turn over. Check your starter relay fuse if that doesn't help.
99dodge2500 is offline
post #4 of 17 (permalink) Old 07-12-2009, 10:29 PM
Substation Operator
speed185187's Avatar
iTrader Score: 5 reviews
I had my starter relay go bad on mine, swaped it with the horn to get going again till i could get a new one.
16 Chevy 3500 CCLB Dually LML
14 K1600GTL-E
03 Jetta GL TDI platinum grey (summer driver)
03 Jetta GL TDI reflex silver (project car)
13 C-Max Energi (hers)
speed185187 is offline
post #5 of 17 (permalink) Old 07-12-2009, 10:39 PM Thread Starter
won't crank over
No sound at all. Starter relay should be OK. I swapped it with the blower relay and still it will not start. Tried starting in neutral and pushing the steering wheel up. No go.
Ken C is offline
post #6 of 17 (permalink) Old 07-12-2009, 10:40 PM
My fuse never did go bad. Its just a loose wire so if the fuse is good then I would see if I had a loose wire or a short.
post #7 of 17 (permalink) Old 07-12-2009, 10:41 PM Thread Starter
swapped the starter and blower relays, as well as putting in the spare relay. no change.
Ken C is offline
post #8 of 17 (permalink) Old 07-12-2009, 10:59 PM
Sounds like a loose wire or a bad starter.
post #9 of 17 (permalink) Old 07-13-2009, 01:59 AM
Al Hale's Avatar
this happened to me as well, roll under the drivers side of the truck and check the small ignition wire on the starter take a 8 or 9 mm 1/4 deepwell socket and rachet with you to tighten it up. if its loose, youll be back on the road in 5 min. good luck
2000 6 SPD, Jake, K&N, Airdog Raptor LP, SR MIA, Edge w Juice.
Al Hale is offline
post #10 of 17 (permalink) Old 07-13-2009, 12:43 PM Thread Starter
thanks, I will give that a try
Ken C is offline
post #11 of 17 (permalink) Old 07-13-2009, 12:48 PM
Sounds like the starter contacts to me. Buy a starter repair kit on ebay, comes with the contacts and plunger.
1999 Ram 3500 Banks Powerpack with 4" exhaust, BD Pulse manifold, super B special, superchips programmer, 200hp sticks, ARP head studs, FASS, dynafact gauges, stage three transmission.
bosshoss is offline
post #12 of 17 (permalink) Old 07-14-2009, 12:45 AM Thread Starter
x
yep, dealer says its a bad starter. wow are they expensive.
Ken C is offline
