98.5-02 PowertrainDiscussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect..NO ADVERTISING .
I did at least 30 min of searching and all the posts that came up didnt help one bit. I need the torque specs for the bolts from:
Flywheel to Crank
Pressure plate to flywheel
Tranny housing to Engine block
Front Driveline Flange
All for a 2001 24v NV5600 with the 13" clutch and Valair HD stock replacement and 3400# pressure plate. And in Ft/lb to. none of that metric crap.
Thanks
Back and Rarin to go in a:
08 2500 QCSB 4x4 6.7, 6 speed. aFe Stage 2, FLO-PRO ,Shibby Engineering,EFI by Dave @ Draconian Diesel, Breathing easier......
>>>01 2500 SCLB 4x4 5.9, 6 speed...Lots of goodies 380/815...SOLD
Just Ledoux it-RIP Chris LeDoux Wyoming Chapter Eastern VP
101 ft lbs flywheel to crank
18-20 ft lbs pressure plate to flywheel
97 12V The Farm Truck Too much to list!
06 QCSB 4x4 S363/S475 Twins,Wicked Stg3 Cp3, DF165,Exergy 100% overs, Diesel Pro's Cam, Maxspool springs,EFI Live, Valair TC, Built 48RE, Caltrac's,Co-Pilot,Isspro Ev2's,....and a bunch of little stuff I forgot.
just get the bellhousing pretty tight, but remember it is aluminum, as far as the front driveshaft the upper(t-case) yoke should be tight, pretty much all a 3/8 ratchet will handle, but the lower u-joint yoke doesn't take much! you will strip em
now that i look at dans sheet that came with the clutch i see the flywheel and pressure plate ratings. dummy me
