Gear Lube for Dana 80/60 - Dodge Cummins Diesel Forum
post #1 of 10 (permalink) Old 07-04-2009, 02:08 PM Thread Starter
Smourj21's Avatar
iTrader Score: 4 reviews
What kind of lube do you run with the dana axles the front 60 is all stock and the 80 im putting the detroit true track in this week. do i have to run the friction modifier in the front or is that an open carrier? what kind of lube 75-90? 80-90?
02 QCSB 6 Speed|215 P-Pump 600cc 28*|64/S480|SAC 7x12|131 DVs|AD150|Colt 181|HD Push Rods & Springs|ARP/O-Ringed Head|Fluidampr|Valair Tripple Disk|.084 Lines/Tubes|Tunnel Ram|CFM+|Water/Meth|6"Miter|Dana60/80|4.88|True Trac|35" Toyo MT's|
Smourj21 is offline
post #2 of 10 (permalink) Old 07-04-2009, 02:37 PM
Phily's Avatar
That true trac might have you run non- synthetic. No friction mod in either axle. Front is open. 80w90
Phily is offline
post #3 of 10 (permalink) Old 07-04-2009, 05:13 PM
VP Moderator
dozer12216's Avatar
Must be GL-5 gear oil. SYN is optional. 75-90 or 80-90 is good. 90-140 if pulling trailers or heavy load all the time.
dozer12216 is offline
post #4 of 10 (permalink) Old 07-05-2009, 02:15 AM
Amsoil
Severe Gear 75w-140w Amsoil front and back
1994 12 valve 4X4 2500 Loaded Carli Suspension featureing 3" Kings Full billet Suncoast trans converter & flex plate HX 40 370 injectors -Snow Performance Meth h20 injection- gov springs- ATS manifold- AFE sock 315-75-16 Pro-Comp Extremes Wilco
Grumpy John 4X4 is offline
post #5 of 10 (permalink) Old 07-05-2009, 12:22 PM
Phily's Avatar
Since he is running a brand new locker, it might say he can't run sythetic.
Phily is offline
post #6 of 10 (permalink) Old 07-06-2009, 02:33 AM
landworks0216's Avatar
especially if your towing, or pulling hard with all four, next paycheck im converting mine
2002 Dodge Ram 2500 HO, SO VP44, 6 Speed, 4x4 with a 4 inch lift on 37/12.50R16.5 Military issue Humvee Tires
landworks0216 is offline
post #7 of 10 (permalink) Old 07-06-2009, 10:23 AM
Mopar1973Man.Com
Mopar1973Man's Avatar
I'm running Mobil One 80W-90... I haul heavy all the summer without a problem.
Mopar1973Man is offline
post #8 of 10 (permalink) Old 07-06-2009, 08:59 PM Thread Starter
Smourj21's Avatar
what would be the reason for a non synthetic? anyone with a truetrac have any info on this
Smourj21 is offline
post #9 of 10 (permalink) Old 07-07-2009, 12:12 AM
idk what the true track needs, im gonna convert mine to amsoil 75w140 in both axles
post #10 of 10 (permalink) Old 07-07-2009, 03:52 PM
Phily's Avatar
Alot of lockers recommend no synthetic for the first 3,000 Miles (or something like) . I'm guessing it's a break in thing, just like a engine.
Phily is offline
