#53 block - Dodge Cummins Diesel Forum
Old 07-02-2009, 01:00 PM   #1 (permalink)
kurp017's Avatar
#53 block
some of you might have read my previous thread of my cracked block under the frost plugs on the passenger side. just looking for a way to repair that crack before i have to pull the engine and stitch it. drilled each end of the crack out to stop spread and drilled and tapped 1/8" plugs into each end. tried JB weld and superweld made by goop. both leaked. any idears please!?
kurp017 is offline   Reply With Quote
Old 07-02-2009, 01:24 PM   #2 (permalink)
2001smoker's Avatar
try grinding out the crack a lil and braze welding on it fo fill in the crack
2001 cummins 5.9, 47RE ,edge juice/ATT soon,holley black pump 20psi S&B intake,hx-35, levling kit 33'' tires,4.56's , 5 inch staight pipe.2002 4x4 3500 5.9 dually 12ft. bed edge juice with attitude, 5 inch ex. 6 speed and 2005 F550 6speed 4x4
2001smoker is offline   Reply With Quote
Old 07-02-2009, 01:25 PM   #3 (permalink)
2001smoker's Avatar
oh yeha got to be very very carful to not blow your block apart you cna only weld on it for like 2 seconds at a time or the block will crack even more cast holds lots of water and will pop and crack.
Old 07-02-2009, 02:07 PM   #4 (permalink)
kurp017's Avatar
that was one of my ideas i was thinkign about. hope it works. hopefully the block don't crack anymore, well it shouldnt if i got the ends drilled out. but cast does funny things when heated. have you done this yourself? or just heard of it? any one else got some ideas?
Old 07-02-2009, 03:11 PM   #5 (permalink)
2001smoker's Avatar
ive done this on a buddys truck 4 years ago no problems. also done it on a 454 chevy. yeah cast is very funny on my buddys truck i drianed the water out popped the freeze plugs out on that side and put a heat lamp on it over night to sort of dry it out and i brazed it and worked good just got to do a little at a time
Old 07-02-2009, 07:01 PM   #6 (permalink)
Nick B's Avatar
i have heard not to weld them it makes it impossible to fix once they start leaking agian i am in the same boat as you think i am just butting a new block in
99 2500,4x4,
Nick B is offline   Reply With Quote
Old 07-02-2009, 07:18 PM   #7 (permalink)
2001smoker's Avatar
i did one with no problems
Old 07-03-2009, 02:34 PM   #8 (permalink)
catcher149m's Avatar
there is a company that makes a repair kit. I think it is called lock & stitch something like that
'99 2500 ext cab SB 5 speed, Airdog 150, Autometer FP, EGT, Boost, Quad Adren, 5" straight pipe, Valair 500 HP SD
catcher149m is offline   Reply With Quote
Old 07-03-2009, 04:01 PM   #9 (permalink)
BlackedOut02's Avatar
i have heard of guys doing it. it just seems too risky to me, id get a new block so i can sleep at night
Under Construction
BlackedOut02 is offline   Reply With Quote
Old 07-03-2009, 04:07 PM   #10 (permalink)
cmns2500's Avatar
patracy used lock n stitch on his, and it's holdin up good...
-CJ
97 2wd 47re that's literally falling apart daily...drivin er till the wheels fall off, then puttin em back on and drivin some more
Old 07-03-2009, 10:13 PM   #11 (permalink)
DieselAutoPower.com
patracy's Avatar
iTrader Score: 5 reviews
Uhhh no I didn't. I used marine tex epoxy, but even that has now cracked and leaking again. I'm just watching a few engines right now. I'll O-ring, stud, and valve spring it, then swap it into my truck. I'm thinking I'll take my cracked engine to the best welder I know and let him work his magic on it. Maybe P-pump it and drop it in a chevy.
patracy is offline   Reply With Quote
Old 07-03-2009, 10:57 PM   #12 (permalink)
jason's Avatar
Sorry to hear of your woes Patracy.
exhaust manifold, repair, cast iron, engine block, welding Heres a link for you guys who want some product to fix it with very detailed instructions.
2000,4x4, quad, 315BFG AT's, XZT+ to big hoss level 5,banks high ram,banks wastegate,100hp injectors,4"tbe,TAG,ranch hand,leveling kit,triple disc TC, Transgo Tugger VB, trans,pyro,boost,fuel press gauges, BHAF, FASS 150 Titanium
jason is offline   Reply With Quote
