| 98.5-02 Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect..NO ADVERTISING . |
Blown Head Gasket NEED HELP!!
I have a 1999 cummins that I have had to put a couple head gaskets in now. I have ARP stud kit torqued to 165 # the surfaces are perfect. Edge juice with attitude, air box, 5" exhaust, 125 HP sticks,FASS system and the most I have seen is 34# of boost on the gauge. What can I do so the BIOTCH will quit blowing head gaskets? ![]() Will O-ringing the head do it? What type of gasket do I need? THANKS for any help I can get!!!!!!
Eating Fords and sh!ttin chevys
#2 (permalink) |
something isnt right if you are only hitting 34lbs and you keep blowin gaskets with studs.
2001/NV5600/TWINS/200hp STICKS/ARP STUDS/110lb SPRINGS/QUAD ADRENALINE/RAPTOR 150/ISSPRO GAUGES/DEVILS OWN METH INJECTION/5in EXHAUST/SBC3600 DD/SBC HYDROS/IN SEARCH OF 600HP AND BUILT WITH DIESEL AUTO POWER PRODUCTS |
#3 (permalink) |
yea, have the head checked to make sure it is perfectly flat (if not, have it surfaced), check the block deck for flatness, snag up almost any MLS head gasket and copper spray it, Torq it to spec cold and then let it completely warm up and then re-torque (3-4 times). There shouldn't be a problem....
98.5 2wd. DragComp, 150's, HolleyBlack,CatTurbo (~42psi), adjustable FPR,T/C switch,custom 6" Stack, 2stage nitrous, custom Billet Single Disk T/C, rebuilt 47re w/ v/b&shift kit. fastest 2nd gen in GJ: 13.6@105, 2.5 60ft
#4 (permalink) | |
Checked it last time for flatness and its all fine, block and head. I did not warm it up and re-torque though. The people at cummins told me I did not have to. I just want it right this time. ![]() Is it better to O-ring it?
#5 (permalink) |
dont need to oring it....shouldnt even need studs...somethings a miss
2000 cummins HO 3/4 ton Leveling kit, airbags ,6spd, exh brk, cold air intake, Edge w/att hot unlock, Centerforce dual friction clutch, striaght piped, BD flow-max |
#6 (permalink) |
Heavy Engine Technician
![]() Join Date: Feb 2009
Is it blowing in the same spot or different places?
2001 Dodge 2500 4x4 Edge/Att Coaltrain 100's BHAF with Custom Shield Airdog 150 5in Straight Exhaust Recon 3rd Brake Light Double 12 Boston Acoustic Subs with Diamond 400W Amp 382Hp/822Tq 15.6 at 88mph Stock Turbo and Stock Transmission |
#7 (permalink) | |
GA VP...so close to 500hp
![]() Join Date: Oct 2007
There's your problem. They're thinking the torque to yield factory bolts. Not a stud. Also you're tightening the studs too tight. You should torque them down, temp cycle, back off the studs one at a time, then re-torque.
1999 2500 4x4 Club Cab Sport. sorta functional ADRENALINE/pulse , BHAF, FBD 150 sticks, 3rd Gen HE351 retrofit, Hamilton 110lb valve springs, A1 head studs, 5" FBD exhaust, Isspro Boost and Drive pressure gauges, fuel pressure gauge, FP light, Mallory Comp 250 pump, 1/2" big line kit, Draw straw, TC lockup switch, Stealth VP plate, BD TC, BD VB, Billet input, Derale pan. 462hp and 920ft-lbs 11/14/09, I know I can get 500hp...
#8 (permalink) |
When it blows is it mixing coolant/ oil or is it blowing between two cylinders, or what? If it is mixing fluids, it may not be the head gasket at all, might be a cracked head???
98.5 3500 2WD dually 4:10's lFull Auto Meter lByrds intakel64/71/14 lGHDlARPl150 horse sticks l.093 tubesl Smarty lEdge Comp HOT lStage 2 snow kitlAir Dog lAmsoil lGeorend trans l VP intercooler boots 536/1175 10/17/09 |
#9 (permalink) | |
01' Quad Long Bed adrenaline fass 100hp stix 01' Jetta tdi 45mpg 225,000 miles. rolling coal 95' Harley Davidson Fatboy 110'' Revtech
#10 (permalink) |
I have not torn it down yet, but last time it was in the front were it was blown. And yes the oil is mixed in the coolant system ( what a freakin mess to clean out ) They checked the head for a crack last time and said there was not one ( I had that done just for peace of mind ) Looks like I will do it again. Should I run a marine gasket? What should the studs be torqued at?
#11 (permalink) |
GA CUMMINS CREW PREZ
![]() Join Date: Dec 2007
what about your drive pressures also? need a gauge, to see where they are at... prolly isnt helping any if its higher than 1:1
CLICK---> GEORGIA CUMMINS CREW "There are no stupid questions, just stupid people." |
#12 (permalink) |
I just went out and looked and it pushed the gasket out the front of the head just like last time. Southernsmoke what is drive pressure?
