| 98.5-02 Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect..NO ADVERTISING . |
#13 (permalink) |
I'm with patracy on this. Just cranking down on the studs and calling it a day will almost insure something bad is going to happen. Also, over-torquing a bolt/stud only makes things worse, not better!
1999 Dodge Ram 2500, QC/SB, 2WD, auto, RV275s, Edge w Attitude, AFE Stage 2, AirDog 150, BioDiesel, Bilstein Shocks, B&W turnover hitch, Firestone airbags, RDS toolbox/60 gallon tank combo, Sport headlight conversion with HD relays, Bosch Compact 100 fog lights |
#14 (permalink) |
GA VP...so close to 500hp
![]() Join Date: Oct 2007
Most torque the ARP's to about 125ft-lbs. The thicker marine gaskets are nice too. I also like the suggestion of the copper spray. The reasons you're likely having problems is two fold. They need heat cycles and re-torques. And you're basically "squishing" the gasket out with that high of a torque. Factory head bolts are a torque to yield. Meaning they act like a spring. They pull the head down, while the head gasket acts as a spring to push the head away from the block. Both have to achive a "balance" to keep the head sealed to the block. Too much "spring" on the pull side, and the gasket spring colapses. Since your studs aren't meant to act like a spring, They simply pull the head down on the gasket. They don't stretch (relaitively speaking) allowing for greater clamping force. Since they're not a "spring", they need to be rechecked to ensure they're all even after the first install.
1999 2500 4x4 Club Cab Sport. sorta functional ADRENALINE/pulse , BHAF, FBD 150 sticks, 3rd Gen HE351 retrofit, Hamilton 110lb valve springs, A1 head studs, 5" FBD exhaust, Isspro Boost and Drive pressure gauges, fuel pressure gauge, FP light, Mallory Comp 250 pump, 1/2" big line kit, Draw straw, TC lockup switch, Stealth VP plate, BD TC, BD VB, Billet input, Derale pan. 462hp and 920ft-lbs 11/14/09, I know I can get 500hp...
| The Following User Says Thank You to patracy For This Useful Post: | flintstone (08-05-2009) |
#15 (permalink) |
Yep, what he said!
#16 (permalink) |
Seems odd that it blew in the exact same place both times though dosnt it?
2000 cummins HO 3/4 ton Leveling kit, airbags ,6spd, exh brk, cold air intake, Edge w/att hot unlock, Centerforce dual friction clutch, striaght piped, BD flow-max |
#17 (permalink) |
Cummins CrAzY
![]() Join Date: Apr 2008
That is the most common spot in a 24v with high cylinder pressure to blow. My guess is drive pressure is way out of control. The fact that he is just cranking down on the studs with no rhyme or reason doesnt help the matter.
2000 2500 ext. cab short bed, AFE cold air intake, single 6 inch stack, SPS 62 turbo, FASS 95, Scheid Lightning II's, .093 connector tubes, Maxspool valve springs, A1 head studs, Fire ringed head, Adrenaline, HP intercooler boots, fully built trans. Goerend triple disc converter billet input Haisley full manual valve body with lots of other upgrades, custom trac. bars, draw straw
#18 (permalink) |
It's not really that surprising, you should see how much the deck and head surfaces move around when subjected to fastener clamping pressure. That's why good builders use deck plates when machining both the block and heads. Some even go so far as to heat and pressurize the water passages to operating temps. Even hanging a block on an engine stand, using just the bell housing bolts, distorts the rear cylinder bores! Many top engine builders use special stands that support both the front and back of the block.
1999 Dodge Ram 2500, QC/SB, 2WD, auto, RV275s, Edge w Attitude, AFE Stage 2, AirDog 150, BioDiesel, Bilstein Shocks, B&W turnover hitch, Firestone airbags, RDS toolbox/60 gallon tank combo, Sport headlight conversion with HD relays, Bosch Compact 100 fog lights Last edited by gator_grabber : 06-14-2009 at 07:21 PM. |
#19 (permalink) |
GA CUMMINS CREW PREZ
![]() Join Date: Dec 2007
Drive pressure is the pressure in the exhaust manifold that drives the turbine wheel, you want it to be around or close to a 1:1 ratio with turbo boost, its the expansion of heat gasses exerting pressure on the turbine wheel, causing the inducer to spin, thus sucking in air, creating charger boost, if your drive pressures get too high above your boost, it means your turbo is working out of its efficieny range, thus temps will start to go up, egt's will climb, you will expierence pre-mature gasket failures, and possibilty of detonating a turbo...
CLICK---> GEORGIA CUMMINS CREW "There are no stupid questions, just stupid people." |
#20 (permalink) |
New England Chapter President
are you torquing the studs in the right order? ive seen plenty of people start in the front and go back, by the time they get to the rear the front of the gasket was crushed so thin it usually doesnt last 500 miles.
'01 - 2500 53 Block - 5 Speed
Catch me if you can. |
#21 (permalink) | ||
Eating Fords and sh!ttin chevys
#22 (permalink) | |
Cummins CrAzY
#24 (permalink) |
750 egt's with 125's and a juice!!! Sonethings wrong here.
2000 short, 4x4, 6 speed, 12.25" DD Valair, S.O.VP44, AEM Brute Force HD, FBD 5" with 6" tip, ADRENALINE!!!, AirDog II 165, AutoMeter Cobalts, 35" Mud Grapplers on 18" Black XD Diesels |
