- - REGISTER - CALENDAR - INFO - SITE HELP - RULES - STAFF - MEMBERSHIP - ADVERTISE - CONTACT US - |
| 98.5-02 Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect..NO ADVERTISING . |
#13 (permalink) | |
But can we stick to the 53 topic?
2001 Ram 2500 Laramie 4x4 6 speed Manual 4:10's 57.5K Stock Stock Stock!!! Bronze with Charcoal leather |
#14 (permalink) |
Your right sorry about that. Again mine cracked at 149,000 miles.
00 2500 4x4 5spd, Balanced & blueprinted, Rings&Studs CR Head W/P&P, All ARP, HD Big Stick, 110# Valve springs, Coated pistons & bearings, S&B, Intake horn, Header, 5" TB, Edge J W/A HOT, GT3788R, 120HP stix, FASS, ValAir DD, Fluidamper. |
#15 (permalink) |
Just Get It Straight
204,000 miles and no crack.
'00 24v 4x4 qc lb silver 205k, airdog 100, Quadzilla with pulse, hx35 with boost bolt, byrd diesel intake horn w/o grid heater, fbd 5inch exhaust, AMSOIL bhaf, DTT valve body and triple disc billet torque conveter, maghytec trans pan, boost gauge on column, fuel psi gauge in cubby, 2in leveling kit on 35s. gone back to stock to save for towing twins.
#16 (permalink) | |
check out dat azz
![]() Join Date: Mar 2009
well, to be honest with ya, i got an 02 that i ain't checked to see which on it is yet, so, i can say 126k, no cracks...
-CJ 97 w/ gauges and what not...and Waterloo Turbo Delete Pipe traded 5/06/10 02 5 speed Quad Adren/Pulse untapped/RV's/FASS 150 HPFP/LED's, HID's, ETC... Quote:
#17 (permalink) |
PA Diesel Fuel Mafia-Don
![]() Join Date: Feb 2008
My bad....but after you been here a while you see these posts about once a week. The search function is your friend here on CF.
1999 2500 Quad Cab 4x4, Edge Juice w/Attitude, AirDog 100,II 62mm snail ,6" stack, BHAF, 125hp Injectors,5spd swap w/ Valair 3850 DD, thanks to Holland Court Diesel, and TheDityD! Jvmpmotorsports.com |
#18 (permalink) | ||
check out dat azz
#19 (permalink) | |
#20 (permalink) |
i've got close to 190,000 on mine and no crack.
99, 4X4, stick, 2nd VP44, 4th carter, fuel press. guage, BHAF, silencer ring MIA, str8 pipe, crack free junkyard dash for $25. |
#21 (permalink) | |
check out dat azz
![]() The following words are either very common, too long, or too short and were not included in your search: 53 that's what i got....
#22 (permalink) |
You have to go to advanced search type in the keyword then go over to the right side of the page and select the 98.5-02 2nd gen forums so it only searches the forums in this section.
#23 (permalink) | |
Sasquatch
![]() Join Date: Sep 2008
1) Go to the search tab and then press "Advance search" and this will be the screen that will show up. ![]() 2) Now enter the search words you are looking for, I prefer adding 2 to 5 words that are about the topic for example the 53 block. 3) Make sure you change the search from entire post to thread title like here below in the fancy paint edited screen shot. Also change amount of points to at least 5 or 10 or to whatever you feel like for threads with large discussions on the topic. 4) Change the search results for relevancy instead of sort by date. 5) Select the forums to search in, you don't want to search for information about the 53 block in the 6.7 section so this can help you weed that out. ![]() 6) take a look at all the results you have, if you don't have anything you are looking for then you have to modify your search a little but you have to wait 30 seconds between searches. ![]() Here's the 44 threads you can look at about the 53 block. If you still don't get the results you're looking for then try the google search provided in the search function. I personally go to google first and then if I don't have the results I am looking for I try the advance search.
'99 Cummins: too many mods to list '97 Cummins: restoration project Motorola Droid:Rooted, Android Froyo 2.2 ported, clockwork recovery, UD extreme RC2 rom, chevy 1.25 ULV Kernel Some tips on using the search function for better results. Last edited by crazyrunner33; 10-20-2009 at 01:06 PM. |
| The Following 15 Users Say Thank You to crazyrunner33 For This Useful Post: | alloutboyz (10-19-2009), Art (01-22-2010), Cliffbuilt (12-02-2009), Cummins Cruiser (08-13-2009), firecracker cummins (01-09-2010), Frankie Figs (08-12-2009), ilovemydiesel04.5 (09-09-2009), Jameson Bearden (02-05-2010), krawlericf (01-08-2010), Powerwagon64 (03-23-2010), PVXCummins (04-07-2010), RedRum (07-30-2009), revcwall (02-02-2010), Smourj21 (09-27-2009), trianom (04-02-2010) |
#24 (permalink) | |
Sasquatch
'99 Cummins: too many mods to list '97 Cummins: restoration project Motorola Droid:Rooted, Android Froyo 2.2 ported, clockwork recovery, UD extreme RC2 rom, chevy 1.25 ULV Kernel Some tips on using the search function for better results. |
