fuel pressure spikes - Dodge Cummins Diesel Forum
post #1 of 9 (permalink) Old 05-22-2009, 06:23 PM Thread Starter
jonny24v01's Avatar
I got all the glowhift gauges. I hooked up the electric fuel pressure gauge about two weeks ago and it read steady till yesterday. Now it just jumps around everywhere. All the other gauges have worked fine. I have a tapped banjo bolt and then the fuel pressure sender. I've heard something about needed to run a fuel pressure snubber. I found a pic of one and it looks like the tapped banjo bolt i'm already running. I am confused. What do i need to run inline to keep the sender working, i could i have just gotten a bad one.
2001 quad cab 4X4 5.9 CTD. NV5600. 4" exhaust. adrenaline,100hp injectors. 214K
jonny24v01 is offline
post #2 of 9 (permalink) Old 05-22-2009, 06:26 PM
Steveo24's Avatar
You just need to plumb in a needle valve between the sender and wherever you have the sender hooked up to. It's purpose is to buffer the fuel pressure pulsations to the gauge
98.5 3500 2WD dually, 4:10's, Full Auto Meter, 5" Bullhaulers, Byrds Intake,3.3 whipple/ 63/ 480, HRVP, GHD, Studded and Ringed, 6x.018, .093 tubes, Stage 2 snow, Air Dog 165, Georend trans, VP intercooler boots
Steveo24 is offline
post #3 of 9 (permalink) Old 05-22-2009, 06:28 PM Thread Starter
jonny24v01's Avatar
whats a part # or some pics of how to do this
post #4 of 9 (permalink) Old 05-22-2009, 06:45 PM
Steveo24's Avatar
hmmmm.... Look on Moparman1973's website. Look him up on this site, and then click his link in his sig. That will take you there.
Steveo24 is offline
post #5 of 9 (permalink) Old 05-22-2009, 07:48 PM Thread Starter
jonny24v01's Avatar
i've looked at that. But what do you use to protect the sending unit with a non-mechanical gauge. I've seen many posts that peoples senders last about 1 week or 2. I might need to see some pics of an electrical gauge setup to understand this.
post #6 of 9 (permalink) Old 05-22-2009, 09:12 PM
Steveo24's Avatar
the electrical gauge I thought had like an 1/8" npt thread on the end right? SO you should be able to run a line out of the banjo bolt then the needle valve, then the sender.
Steveo24 is offline
post #7 of 9 (permalink) Old 05-23-2009, 12:51 AM
Westcoast KW's Avatar
Weatherhead part no. WH6820, just got mine at napa for 8 bucks, works good
'01 2500 QCLB, auto, napa special straight pipe, BHAF, fp gauge, airdog 100, moparman inspired puke bottle mod, jkidd vp44, power puck
Westcoast KW is offline
post #8 of 9 (permalink) Old 05-23-2009, 01:02 AM
BuffaloLake's Avatar
What he said. This is a little needle valve that has 1/8" male thread on one side and 1/8" female on the other. It works with both mechanical and electric. You want to just barely crack the valve open.
1998.5 24v 3/4 ton 4wd quad cab long bed 209,xxx miles, Airdog 100, Adrenaline with IQuad, BHAF, 6" Aussie stacks (thanks to FBD) with custom heat shield, auto trans rebuilt for towing, Hornblasters 240 Shocker, occasionally tows 35' 5th wheel...
BuffaloLake is offline
post #9 of 9 (permalink) Old 05-23-2009, 10:38 AM
cowtippwe's Avatar
snubber from diesel manor will fix it and screw right in to the tapped banjo bolt.
'02 2500 CTD. H.O 3.55 gears. DSV. Assasin fuel pump, BHAF, 4" Turbo back w/Muffler, Dpricol Optix guages, Edge Comp, SIRIUS Satellite Radio. (Work) - '99 2500 CTD Quad cab. Short bed, assasin fuel pump, BHAF, 4" turbo back, +50 injectors, DTT 47RE,Play)
cowtippwe is offline
