homemade water injection? - Dodge Cummins Diesel Forum
post #1 of 15 (permalink) Old 01-26-2007, 12:51 AM Thread Starter
bbraden's Avatar
anybody have any ideas on how to make a homemade water injection kit? If not, is there any downsides to water injection? ie... rusting internal parts/or grid heater problems?
'99 dodge 4x4 NV4500, Super X VP, FASS 150, Custom Quick Spool Super B w/ ATS manifold, RV's, Smarty programming. north of 400 hp... Bout to add water/meth injection
bbraden is offline
post #2 of 15 (permalink) Old 01-26-2007, 10:07 AM
farmboysdiesel's Avatar
By the time you by everything you'll need to make a home made kit you could have bought a nice stage 2 kit and be done with it. There's quite a bit involved in putting something like that together.
farmboysdiesel is offline
post #3 of 15 (permalink) Old 01-26-2007, 11:56 AM Thread Starter
bbraden's Avatar
Alright, I'll take your word for it but is there any downsides to water/methanol injection??
bbraden is offline
post #4 of 15 (permalink) Old 01-26-2007, 12:07 PM
No downsides really you just need to use it right and not try to go over board with the methanol part or anything. It's generally a pretty safe power adder and it cools EGT's too. Kind of a two bird with one stone deal.
post #5 of 15 (permalink) Old 01-29-2007, 02:04 PM
How many horses does meth/water injection add?? say if someone had a Smarty/DRAG comp already stacked?
2000, 2500... White/gray short bed...
Grille guard, Warn winch, BHAF Isspro 3 gauge (pyro, boost, fuel press), 2 Holley Blues, Smarty, Edge Drag COMP, SBC CON-FE, 5in Mitre Cut Stacks
AWall is offline
post #6 of 15 (permalink) Old 01-29-2007, 05:21 PM
You really need bigger injector/excess fuel in order to really see good hp gains. A water/meth kit probably wouldn't benefit you that much right now.
post #7 of 15 (permalink) Old 01-29-2007, 05:34 PM Thread Starter
bbraden's Avatar
Ok - tell me if I'm way off the wall here, but basically I was looking for fuel economy. I'm very close to upgrading to RV 275's and I was hoping that at the same time that I did this, I could build me a cheap, homeade propane kit and a homemade water/meth injection kit. From talkin to the old farmers that used to run propane/butane tractors/pickups, they claim that propane is VERY hard on valves. Talking to diesel guys, I've heard propane runs high EGT's easily which would be in turn hard on pistons and the turbo (my guesses) Now- if I put in a little water to counteract the disadvantages of the propane, maybe I could acheive better mpg's without harmful side effects. But with injectors and propane, I'd think that a little water to cool the burn would help. Regardless, I think that my comp box can overfuel for the air that I can give it and then add 275 injectors to that....
bbraden is offline
post #8 of 15 (permalink) Old 04-22-2010, 12:47 AM
01HOtony's Avatar
if theres a way to build a kit i wanna know save me a few $
2007.5, 2500 Mega Cab Laramie 6.7. AFE Cold air, H&S EGR delete, flo pro dpf delete. superchips racing tuner
01HOtony is offline
post #9 of 15 (permalink) Old 04-22-2010, 02:28 AM
SLTRAM98's Avatar
Like Farmboys said... far cheaper/safer to just buy a good one. You have potential to damage your engine or not have any affectiveness at all.
1998.5 24v 4x4 5sp ext. cab 3500. Fully Loaded. Straight 4" pipe from the turbo back, Quadxilla Adrenaline w/ Pulse, 100hp Edge sticks, AirDog 150 Silencer ring MIA.2" front lift HD...3:54's
NICE
SLTRAM98 is offline
post #10 of 15 (permalink) Old 04-22-2010, 08:08 PM
runit02's Avatar
Ill dig somethin up . . . http://www.alcohol-injection.com/wat.../universal-19/
Official CF repair crew
[QUOTE=JearBear;19022602] I have always and will always love men, cats, and single cabs.
runit02 is offline
post #11 of 15 (permalink) Old 05-06-2010, 10:06 AM
17nCummins's Avatar
i made my own and it was really easy, worked great and was really cheap, entire thing plus 2 gallons of 50/50 mix cost less than 30 bucks, used the stock windshield washer components and worked great ever since
2000 Black Ext Short 5spd SouthBend Single, 160hp P pump conversion
, rack plug, no plate, 21* Timing, .084 lines, 90hp DDPs fass 150 fuel system
17nCummins is offline
post #12 of 15 (permalink) Old 05-06-2010, 10:42 AM
VP Moderator
dozer12216's Avatar
$600 for a stage 11 kit is out of budget. A simple kit for under a hundred dollars should be achievable. I doubt there are many if any benefits for a motorist.
dozer12216 is offline
