| 98.5-02 Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect..NO ADVERTISING . |
Super Moderator
![]() Join Date: May 2008
trouble shooting thread
HEY GUYS HOW ABOUT SOME FEED BACK??? has it helped any one? anything you would like to see added? any ideas welcome. just send me a PM! thanks guys ![]() INFORMATION GATHERING Please provide all information about you current problem. OBD II Error Codes - Gather error codes from the onboard computers (PCM/ECM). This give the biggest clues to the faults and/or problems. http://mopar.mopar1973man.com/pdf/error-codes.pdf http://www.edgeproducts.com/product_...cle-pdf-39.pdf Lift Pump Diagnostics Since most all engine problem revolve around poor fuel system and lift pumps please check for proper fuel pressure and volume. ]TROUBLESHOOTING APPS Sensor Removal and Replacemnt listed here. Some other technical information given. Apps Reset How to properly calibrate your APPS sensor to the ECM once again. Voltage Drop -How to test your main battery supply cables for faults. Hard Starting With Hot Engine -Hard start when hot? Check this link. OTHER DIAGNOSTIC INFORMATION Here is some PDF documents to help with repair, troubleshooting, etc... Download PDF Dodge Ram 2001 Service Manual | PDFTown.com This will work for 1998.5 to 2002 Dodge truck for most all repairs. Anatomy of an APPS - the sequel! FUEL INFORMATION Here are two PDF files that offer up plenty of info on different fuel charts http://mopar.mopar1973man.com/pdf/022003bosch.pdf http://mopar.mopar1973man.com/pdf/hf...ieselplace.pdf Brake Upgrades 37337 1-ton wheel cylinder install with pics! My 3rd gen brake swap - PICS - 56K BEWARE!
DUKE<-- 2000 4x4 3/4 ton ex cab lwb ATS converter,suncoast heavyduty rebuild kit,ATS valve body, edge EZ, straight piped, 3rd gen cromeclads, isspro pyro boost fuel, FASS , coaltrain 150's Last edited by Broke Down : 10-01-2009 at 06:15 PM. |
| The Following 3 Users Say Thank You to Broke Down For This Useful Post: |
