» Site Navigation
» Network Links
04-04-2009, 10:02 AM
#1 (permalink )
I bleed Diesel
flywheel torq spec
does anyone no what the flywheel torque spec is?
1995 f350 cummins ppump
1997 f350 powerfulljoke
1992 fsuperduty cummins 5speed dump ve pump
1989 f450 tow rig cummins in the making
1970 javelin 360 4 speed
04-04-2009, 10:38 AM
#2 (permalink )
TORQUE SPECIFICATIONS
5.9L DIESEL ENGINE
DESCRIPTION TORQUE
Air Fuel Control
Fitting 8 N·m (72 in. lbs)
Battery Cable (Negative) to Block
Bolt 77 N·m (57 ft. lbs.)
Belt Tensioner Mounting
Bolt 43 N·m (32 ft. lbs.)
Block Heater Mounting
Bolt 12 N·m (108 in. lbs.)
Cab Heater Hose Clamp
Screw 4 N·m (35 in. lbs.)
Cab Heater Tubing Bracket
Bolt 9 N·m (84 in. lbs.)
Camshaft Thrust Plate
Bolts 24 N·m (18 ft. lbs.)
Clutch Cover to Flywheel
Bolts 23 N·m (17 ft. lbs.)
Connecting Rod Nuts
Step 1 - Preliminary 35 N·m (26 ft. lbs.)
Step 2 - Secondary 70 N·m (51 ft. lbs.)
Step 3 - Final 100 N·m (73 ft. lbs.)
Cooling Fan to Fan Clutch
Bolts 20 N·m (15 ft. lbs.)
Crankshaft Main Bearing Bolts
Step 1 - Preliminary 60 N·m (45 ft. lbs.)
Step 2 - Secondary 90 N·m (60 ft. lbs.)
Step 3 - Final Additional 90°
Cylinder Head Bolts
Step 1 - (All Bolts) 90 N·m (66 ft. lbs.)
Step 2 - (Re-check All Bolts) 90 N·m (66 ft. lbs.)
Step 3 - (Long Bolts) 120 N·m (90 ft. lbs.)
Step 4 - (Re-check Long Bolts) 120 N·m (90 ft. lbs.)
Step 5 - (Rotate All) Additional Turn (90°)
Exhaust Manifold
Bolts 43 N·m (32 ft. lbs.)
Fan Clutch Mounting to Fan Hub
Left Hand Thread 57 N·m (42 ft. lbs.)
Fan Hub Bracket
Fan Hub Bearing
Fan Pulley to Fan Hub
Bolts 9 N·m (84 in. lbs.)
Fan Shroud Mounting
Bolts 11 N·m (95 in. lbs.)
Flywheel
Bolts 137 N·m (101 ft. lbs.)
Flywheel Housing Adaptor
Bolts 77 N·m (57 ft. lbs.)
Generator Mounting
Bolts 41 N·m (30 ft. lbs.)
05 2500 4x4 Carli Dominator 3.0 Suspension Baja proven
94 2500 4x4 Carli performance 2.0 with full leafs
90 wrangler injected locked and caged crawler
The Following User Says Thank You to bob4x4 For This Useful Post:
04-04-2009, 10:52 AM
#3 (permalink )
www.Mopar1973Man.com
Originally Posted by
bob4x4
5.9L DIESEL ENGINE
DESCRIPTION TORQUE
Air Fuel Control
Connecting Rod Nuts
Cylinder Head Bolts
Exhaust Manifold
Fan Hub Bracket
Fan Hub Bearing
Fan Shroud Mounting
Flywheel
Generator Mounting
Help you spot it in this mess...
Mopar1973Man.com -=- Michael Nelson -=- 2O8-628-3645 -=- If you need a hand with your Dodge Cummins give me a shout...
AirDog 150, RV275 Injectors, Edge Comp (Tapped), Straight Pipe 3" Exhaust, BHAF, Exhaust Brake, Timbo APPS, Southbend Con OFE, ScanGauge II, DiPriocl Gauges, High idle / MPG fooler, etc.
(Posted with Ubuntu Linux 12.04)
04-04-2009, 12:19 PM
#4 (permalink )
bob4x4
5.9L DIESEL ENGINE
DESCRIPTION TORQUE
Air Fuel Control
Connecting Rod Nuts
Cylinder Head Bolts
Exhaust Manifold
Fan Hub Bracket
Fan Hub Bearing
Fan Shroud Mounting
Flywheel
Generator Mounting
Under Construction
04-04-2009, 01:20 PM
#5 (permalink )
No kidding...
04-05-2009, 12:28 AM
#6 (permalink )
snap-on 3/8 air impact with a good 18mm socket.
06 2500 Big Horn 6spd QC 2WD LWB, New to me and stock.
*SOLD* 01 2500 5spd 4 door 4x4, 4" turbo back, Quadzilla Adrenaline , missing silencer ring, Raptor 150, 90hp sticks, Pulse monitor & Valair ceramic clutch.
09-10-2010, 03:00 PM
#7 (permalink )
how about the engine to transmission bolts (bellhousing)?
95 2500 4x4 110K AT: Autometer gauges, #10 Plate half way, silencer ring MIA, BHAF, Boost Elbow, luke's link (5), 3K-GSK,
09-10-2010, 07:36 PM
#8 (permalink )
Just make sure they're tight but don't go overboard and strip one. I use a 3/8 impact and a swivel socket.
2002 6-speed, 5 inch straight pipe, Icebox, Edge Drag Comp, +100 hp injectors from Diesel Auto Power, Isspro pyrometer, mechanical boost guage & electric fuel pressure gauge. FASS 95, Valair kevlar/ceramic clutch...
Linear Mode
