Low power, no smoke, help! - Dodge Cummins Diesel Forum
post #1 of 10 (permalink) Old 03-22-2009, 10:55 PM Thread Starter
Ever since owning this stock truck for about two months, I have not been happy with the power. It has new lift pump, fuel filter and low pressure light, it is six speed with H.O. and 3.55 gears. It weighs almost 10k. It will not belch any black smoke ever. Starts great. I just installed boost gauge and it won't build anything over maybe 15 or 17 psi. 10 psi at 2000 rpm and from there it goes up. The truck just doesn't have any low end power like I am used to on a turned up 12 valve. In maybe gear 3 or 4 and you floor it, it doesn't take off till about 2100 rpm. I know it should be in the low 20's on boost buy why isn't it getting there? I am either going to do a map sensor or check intake for leaks. I am not showing any relevant codes or CEL. I have access to a snap on solarus scan tool. It showed the boost was something in kpa's or kilapascals which converted to 32 psi. I know that wasn't right, so do you think map sensor as well? Thanks.
seedcleaner is offline
post #2 of 10 (permalink) Old 03-22-2009, 11:01 PM
lvin4jc's Avatar
Sounds just like my '01 as far as boost numbers go, it's hard to get above 20 with stock injectors and no fueling box, at least with my HY, but i'd bet your HX doesn't do that much better. What year is it?
Also, mine weighs 7,200
2001-4X4-47re-3.55 gears-Amsoil 4510-Isspro triple gauge pod- Leveling kit-Straight piped-Debadged - 240,000+ Miles and counting
lvin4jc is offline
post #3 of 10 (permalink) Old 03-22-2009, 11:33 PM Thread Starter
What does hx and hy stand for, I assume the turbo but why would yours be different than my 2001 dodge? The most psi I can get is about 17 psi. I refuse to believe this truck has the correct performance for a stock truck. It just seems sick. Someone can surely shed some light on something that can be done. What are symptoms of bad MAP sensors without it throwing codes? Thanks
post #4 of 10 (permalink) Old 03-22-2009, 11:39 PM
lvin4jc's Avatar
It's turbo's. My automatic truck has a slightly smaller HY35 and your manual truck has the HX35. The good news is that you can adjust your wastegate for more boost cheaper than I can - eBay Motors: DODGE CUMMINS TURBO, TURBOCHARGER ADJUST BOOST ELBOW (item 310130111267 end time Mar-29-09 15:10:33 PDT)
What's your 0-60 time? Fuel Mileage?
lvin4jc is offline
post #5 of 10 (permalink) Old 03-23-2009, 11:18 AM
scooter0803's Avatar
Yea, you can adjust the boost all day long, but until you add more fuel your not going to get more boost. I have an HX and max I can hit is 20.5 to 21 psi on stock tune, and the HX puts out more than the HY. So your probably hitting pretty much the max boost for the stock setup. If you do boost more than that with no tuner you will just through an over boost code and De-fuel the engine. Do all your normal checks, including fuel pressure, filters, and so forth. There are a bunch of threads on here about this topic with some rear good info. Try to do a search and good luck.
scooter0803
06, 4wd mega cab, auto, bullydog gt 40420
scooter0803 is offline
post #6 of 10 (permalink) Old 03-23-2009, 11:30 AM
Mopar1973Man.Com
Mopar1973Man's Avatar
Comment in blue...
Ever since owning this stock truck for about two months, I have not been happy with the power. It has new lift pump, fuel filter and low pressure light, (Need a fuel pressure gauge) it is six speed with H.O. and 3.55 gears. It weighs almost 10k. It will not belch any black smoke ever. (Normal for stock engines) Starts great. I just installed boost gauge and it won't build anything over maybe 15 or 17 psi. (That is normal boost levels for stock 24V I normally didn't get much over 18-19 PSI) 10 psi at 2000 rpm and from there it goes up. The truck just doesn't have any low end power like I am used to on a turned up 12 valve. In maybe gear 3 or 4 and you floor it, it doesn't take off till about 2100 rpm. I know it should be in the low 20's on boost buy why isn't it getting there? I am either going to do a map sensor or check intake for leaks. I am not showing any relevant codes or CEL. I have access to a snap on solarus scan tool. It showed the boost was something in kpa's or kilapascals which converted to 32 psi. (24V engine tend to mis report boost pressures mine shows its idling at 14.9 PSI I highly doubt it...) I know that wasn't right, so do you think map sensor as well? Thanks.
You truck is normal and very typical. Now you power and boost pressure will change as soon as you drop a enhancement box on. Like turning on a 12V well the electronics turn up a 24V engine.
Stock I would barely get about 18-19 PSI at the most...Anything over 21 will trip a error code and defuel the engine... No smoke and very doggy out of the hole. But add a Edge Comp to it... Now I got a truck that comes out of the hole screamin' and building 34-35 PSI of boost, black smoke for sure, but awesome MPG and serious power!
So there is nothing wrong with yuor truck it just needs some upgrades now...
2002 Dodge 2500 (286k miles) - Quadzilla Adrenaline, +50HP Vulcan Performance Injectors, BHAF, 3" Flow Through Muffled Exhaust, AirDog 150 (10 years old)
Mopar1973Man is offline
post #7 of 10 (permalink) Old 03-23-2009, 11:30 AM
New Mexico Chapter Vice President
mikeluna_17's Avatar
man as for black smoke mine smokes pretty good...i dont even know if its normal for a truck with no chip or programmer..but i think the previous owner did something that i dont know about....but when i shift from 2nd to 3rd..or especially 3rd to fourth and i give it some good throttle i get some very nice black smoke...and i have some real good power too
98.5 24 valve cummins QCLB.5spd Straight Pipe..HBS 2.5" leveling kit. 35"s No silencer ring.homemade CAI
mikeluna_17 is offline
post #8 of 10 (permalink) Old 03-23-2009, 12:25 PM
smok3rx's Avatar
yea mine is the same way. im not sure if it has some new injectors or something cause i know it dosnt have a chip but when you put your foot down it will take off and poor smoke. im not always trying to push it but one time i was following my borther and decided to pass him and give him a little smoke i was going 50 when i floored it around him and by the time i looked back down i was going 115
02 2500 Ext. Cab, Long bed, 4x4, 4" Turbo Back, BHAF, Airdog 100, New vp44, Quadzilla Adrenaline with Pulse v2
smok3rx is offline
post #9 of 10 (permalink) Old 03-23-2009, 03:25 PM
Dave3500's Avatar
So there is nothing wrong with yuor truck it just needs some upgrades now...[/QUOTE]
Edge Comp, that sounds like a plan. Is that what you did to yours? I will have to go over to your site & check out your mods again. What's your MPG's?
Red 98.5 24V 3500 dually. K&N filter, low fuel pressure light.
Soon to be added: Fuel Pressure & Trans Temp Gauges.
Will be running Biodiesel!
Dave3500 is offline
post #10 of 10 (permalink) Old 03-23-2009, 03:46 PM
yeah man the last owner of my truck must of put bigger injectors or somethin..because im gettin plenty of smoke and power
