55 block - Dodge Cummins Diesel Forum
Old 12-28-2006, 11:32 PM   #1 (permalink)
D-Roc's Avatar
55 block
I noticed another member has this in his sig. What is it? I know about the 53, but how bout some infor on the 55? Where would you find it stamped. I am starting to shop around for a 2nd gen and would like to have all the info I can.
Thanks
"Every word every thought every sound. Every touch every smile every frown. All the pain we've endured until now. All the hope that I lost you have found."
D-Roc is offline   Reply With Quote
Old 12-28-2006, 11:41 PM   #2 (permalink)
bucket truck's Avatar
I have a 55 block. It is printed on the bottom of the block about middle ways front to back next to the oil pan on the drivers side. It supposedly is one of the thicker blocks. I think the 55 was cast in Mexico but not sure? I think I've heard somewhere that it has a little different mixture of metals than the 53.
2001 extra cab 2500 SLT laramie (dark blue over silver) 4x4 S.O. 55 block, 47re, silencer ring/resonator/muffler are MIA, gauges, big bumper up front, B&W turnover ball, 315 buck shots, and Quadzilla XZT+ (thanks DieselNut)
'89 GMC Sierra SLX 1500 4x4 186K 350TBI w/custom 400 tranny
'06 Freightliner Business Class M2 106 tandem w/lockers,30k# winch, and Altec digger/derrick
bucket truck is offline   Reply With Quote
Old 12-28-2006, 11:47 PM   #3 (permalink)
2001shrtbedcummins
Guest
Posts: n/a
yea the 53 blocks were never meant for a hp application much over 100 I believe...amazing to think of these engines only making that little amount of hp. 55's are good. You will see the number on the side of the engine block, can't remember exactly where...if you climb under like you were changing the oil filter and look up w/a light you will see it.
Old 12-28-2006, 11:57 PM   #4 (permalink)
nothing wrong with the 55 block only the 53's had an issue with cracking
96 auto ,p-pump tweeked out ,4" exhaust, b
And thats all i am saying
moneymaker44 is offline   Reply With Quote
Old 12-29-2006, 12:03 AM   #5 (permalink)
D-Roc's Avatar
That is odd that they would make a block that was prone to cracking. Wonder who was behind that one and if he can look himself in the mirror anymore.
Old 12-29-2006, 12:28 AM   #6 (permalink)
2001shrtbedcummins
Guest
Posts: n/a
not that they made a block that would crack...just that block wasn't meant for such a stressful application as the ram. Don't know why they put em in the trucks (probably didn't know it would happen)
Old 12-29-2006, 10:21 AM   #7 (permalink)
You guys blew it................... You had a chance to really make him nervous. You should have told him that it had a worse reputation than the 53 block......... Could have been a lot of fun.
Tom05 is offline   Reply With Quote
Old 12-29-2006, 11:12 AM   #8 (permalink)
Supporting Vendor
Duluth Diesel's Avatar
They didn't intentionally make 53 blocks thin for low power applications. That isn't the correct story. The 53 just designates what casting was used to make the blocks. The 53 cast had a flaw, and resulted in blocks with thinner walls. It was a mistake, and wasn't realized until thousands of blocks were produced. It wasn't an intentional design, it was a screw up. I think they were case in Brazil, but I could be wrong. 53 = lemon block. Other casting numbers, like 55, are normal and don't appear to be a abnormal problem. Not all 53 blocks will fail, but it is well documented that 53 cast blocks have a much higher rate of failure than normal.
53 block + VP44 + junk LP = headache
Proud Cummins Forum Sponsor since 2006 - SUPPORT YOUR CUMMINS FORUM SPONSORS, WE SUPPORT YOU. THANK YOU!
Specializing in AMSOIL everything
Duluth Diesel is offline   Reply With Quote
Old 12-29-2006, 11:20 AM   #9 (permalink)
Banned
Thats the story as I understand it.....
More info: 53 Block FAQ and Information
Dr. Evil is offline   Reply With Quote
Old 12-29-2006, 11:27 AM   #10 (permalink)
www.Mopar1973Man.com
Mopar1973Man's Avatar
Thank God that the 2002 came out... Now I've only got...
VP44 + Junk LP = :fist: Not as bad...
Mopar1973Man.com -=- Michael Nelson -=- 2O8-628-3645 -=- If you need a hand with your Dodge Cummins give me a shout...
AirDog 150, RV275 Injectors, Edge Comp (Tapped), Straight Pipe 3" Exhaust, BHAF, Exhaust Brake, Timbo APPS, Southbend Con OFE, ScanGauge II, DiPriocl Gauges, High idle / MPG fooler, etc.
(Posted with Ubuntu Linux 12.04)
Old 12-29-2006, 01:12 PM   #11 (permalink)
D-Roc's Avatar
Originally Posted by Whitmore View Post
Ya it was prolly the Doc
He is a trouble maker and all good men should refrain from conversation with him
I think you meant MnTom, Whitmore!
Old 12-29-2006, 04:38 PM   #12 (permalink)
So now what did I do?
