Cam Sensor Bad? - Dodge Cummins Diesel Forum
post #1 of 13 (permalink) Old 02-14-2009, 07:19 PM Thread Starter
Cam Sensor Bad?
I have a 2002 Cummins in a Dodge 3500, What are some of the probs. that arrise when the cam sensor is bad? where can i get one? and can it be changed without removing the fuel pump?
RCTrucking is offline
post #2 of 13 (permalink) Old 02-15-2009, 01:38 AM
cummin 723's Avatar
well first you should get an error code...when the cam sensor whent in my truck it dident just die it worked then it wouldent, also the tach would die.. and with my chip on it would idle real rough. the cam sensor is up front under the injector pump. its a real pain in the arse to get at. there is only one wire plug and a small allen key holdind it in.. i found it easyer to do from under the truck and the allen bits that go on a 1/4 rachet came in handy it was about a 1/2 hour job...i got one from advance at it cost about 40 bucks or so and i dident remove any of the fuel system to do it
hope this helps!!!
Butch
o1' 3500 dually,6 speed swaped south bend dual disk. 4.10 gears ,5 inch Turbo back ,egde j/a with hot code,k+n,silencer ring fell out,fass-150,
cummin 723 is offline
post #3 of 13 (permalink) Old 02-15-2009, 11:12 AM Thread Starter
Cam Sensor
Yep! You have furnished me with what i needed to know, my tach drops off somtimes but dosn't seem to effect engine. anyway Thank You for responding!!
post #4 of 13 (permalink) Old 02-15-2009, 11:45 AM
Mopar1973Man.Com
Mopar1973Man's Avatar
Still scratchin' my head about that yet... Something in my mind still doesn't add up right.
RC you might want to fill out your signature so other can help ya...
http://www.cumminsforum.com/forum/pr...=editsignature
Mopar1973Man is offline
post #5 of 13 (permalink) Old 02-15-2009, 12:37 PM Thread Starter
Michael! using a computer is an area i'm not very exp. in. I guess what i'm trying to say is i don't quite know what to enter. But thx. for the tip, I'll ask my son when he come's over next.
post #6 of 13 (permalink) Old 02-15-2009, 01:54 PM
Mopar1973Man.Com
Really simple when you get to the screen in the link provided... Just enter Year, make, body (Long or short)... Any information you can provide about the truck.
Like my truck would list out like...
2002 Dodge 2500, LWB, 140K miles, AirDog 150, Custom Backup Lights, BHAF, Custom Crankcase Vent, Edge Comp, Exhaust Brake, Custom Fog Lamps, Frantz Filter, DiPricol Gauges, Kenwood MP3 player, straight piped, Silencer ring, ScanGauge II, Custom High Idle...
But since the signature box isn't big enough on most sites its just best to drop a link to my BOMBs...
BOMBs
post #7 of 13 (permalink) Old 02-15-2009, 02:01 PM Thread Starter
OK I'll try that. Trying to find dealers for Air Dog, Vulcan Perf. and Stealth Plate!
post #8 of 13 (permalink) Old 02-15-2009, 02:36 PM
Mopar1973Man.Com
Here you go...
Manufacture Contacts
Dealer Contacts
post #9 of 13 (permalink) Old 02-15-2009, 02:42 PM Thread Starter
Already tried that. thats where i got Pureflow's #. But when i click on Vulcan it say's page not found.
post #10 of 13 (permalink) Old 02-16-2009, 01:00 AM
Vulcan Diesel Performance offers DDUSA twin turbos, FireBall injectors, DrawStraws, Big line kits, FASS fuel pumps, Parker bio fuel line, Quadzilla products, DTT Transmissions, Isspro gauges, High Tech Turbos , Veg pumps, metric adapters & fittings,
Just worked for me.
RR
'02 QCLB 2500, 4.10, limited slip, auto w/Dynamic stage 3 build & LU switch, Edge Comp, Scan gauge II, Raptor lift pump, fuel pressure/trans temp/boost/pyrometer gauges.
Russ Roth is offline
post #11 of 13 (permalink) Old 03-06-2009, 01:31 AM
is it possible to have a bad cps and not get a light ?
99 dodge ram
zhcampbell is offline
post #12 of 13 (permalink) Old 03-06-2009, 08:26 AM
I got a code when mine went, cant remember the #. Tach would come and go and when the tach wasnt working, it was way down on power but still ran, just kinda sick. It can be changed without removing anything but its tight in there and is pretty much done by feel. I used a loooog extention and did it from the top of the truck. Get a mirror and get a good look at the project before you start. Good luck.
okie
01, QC, 4x4, auto, Power puc, muff mia, SSI Steering Stabilizer, FASS 95, BHAF.
okiefired is offline
