2002 dodge 2500 diesel - Dodge Cummins Diesel Forum
post #1 of 7 (permalink) Old 02-04-2009, 10:50 PM Thread Starter
farmallm1947's Avatar
i have a 2500 dodge diesel with the automatic transmission. when the truck takes off it takes off in second gear instead of first. i can manually pull it in to first and it will work. any ideas on what might be wrong
farmallm1947 is offline
post #2 of 7 (permalink) Old 02-04-2009, 10:59 PM
cumminspwrd02's Avatar
FarmallM1947, I had the same condition in my truck a couple years ago. Whats wrong with your truck is it needs a new Gov Solenoid and Transducer in the transmission. These parts I think are part of the valve body. When mine went out it was still under warranty so I wasn't the one doing the job, dodge did. Mine would also shift into first manually but not on its own if I left it in drive. Do a search on Govenor Solenoid and Transducer, you'll probably find some good reading on it.
Matt
2002 Dodge Ram 2500 4x4 Reg. Cab, Arrest Me Red SLT Laramie 24v Cummins AT w/ 4.10 LSD. Quad XZT+, Gauges, Amsoil BHAF, RSD 5" exhaust, Tonneau Cover, Tinted windows.
cumminspwrd02 is offline
post #3 of 7 (permalink) Old 02-05-2009, 01:04 PM Thread Starter
are these two seperate pieces or are they one piece. is there a better one to buy i haul antique tractors about 10000lbs with truck?
post #4 of 7 (permalink) Old 02-05-2009, 01:56 PM
I'm pretty sure its two different parts. I never got to actually do the repair because mine went out under warranty and dodge did the fix. I've heard of others that had this problem and they just get the parts from the dealer. I don't know if there is an aftermarket replacement part, but you could install an aftermarket valve body built for towing. I'm sure someone else will chime in with more info. I have had this repair done now for 3 or 4 yrs and I've put about 80k miles on it since then. I also haul heavy on occasion, sometime dads antique tractors and equipment for others.
Matt
Last edited by cumminspwrd02; 02-05-2009 at 02:09 PM. Reason: forgot to add something
post #5 of 7 (permalink) Old 02-05-2009, 04:09 PM
diggerdrew79's Avatar
the gov pressure sensor is in the pan next to the filter and is a simple change i just got one for bout 108 bux my truk is doing the same thing and the gov sensor change didnt fix the problem i havent bought the transducer yet but i hope it fixs the problem its a external part suposedly on top of tranny
gone but not forgotten 01 ccsb 06 ccsb TRX4 now enjoying 09 4x4 larimie megacab 6 spd gearjammer staying stock for now
diggerdrew79 is offline
post #6 of 7 (permalink) Old 02-10-2009, 07:45 AM Thread Starter
does anyone have pictures of where the transducer is located? my plan is to buy both pieces and me and a friend that is a diesel mechanic(big trucks) are going to change them and service the transmission.
post #7 of 7 (permalink) Old 02-10-2009, 07:49 AM
I had that problem after installing a Race VB and was told it was due to older electronics. I was told to call DTT and buy a voltage regulator for the 47re it cost me 75 bucks shipped and took about 20 minutes to install and fixed the problem. I still get a second gear start after a long highway drive but its because I dont have the voltage dialed in all the way.
2010 Jetta TDI
1995 Regular Cab 2wd, Billet Single, Valve Body, BHAF, 4k GSK, Autometer Boost/EGT Gauge
01Cummins24v is offline
