Trouble code!!!!!!!!! p1693 - Dodge Cummins Diesel Forum
post #1 of 43 (permalink) Old 12-07-2006, 04:59 PM Thread Starter
Truck just threw me a P1693 code: Turbo Charge Control Circuit Malfunction. Just what does this mean, and how do I fix it. Is it safe to still run it with this code? First time I've seen this one.
Thanks guys.
2001 Ram 3500 SLT, Auto, 4x4, long bed dually, HO version. Right now completely stock.
jandcwilson is offline
post #2 of 43 (permalink) Old 12-07-2006, 07:46 PM
Banned
Thats not what that code is...
P1693 is the companion code...it means that there may be another code stored and you need to use a OBDII scanner to extract it.
If I was a betting man I bet it will be P0216....Injection Pump timing failure...
Let us know what happens.
Dr. Evil is offline
post #3 of 43 (permalink) Old 12-07-2006, 08:28 PM
Guest
Guest
Posts: n/a
80% chance of correctness there Doc ..........If I were a bettin man I would bet with ya too
post #4 of 43 (permalink) Old 12-07-2006, 08:34 PM
Tech Specialist
Gary - K7GLD's Avatar
I wonder where guys are getting this notion that a 1693 is a Turbo issue?
White '02 Quad cab, NV5600, GAUGES! Comp, Walbro, DTT SS intake, Rip's 4 in. exhaust, Don M's 1.6's, DSS, Frantz oil bypass & fuel filters, Amsoil air filter, MOBILE Ham Radio-IC-706, 600 watt amp, '88 Kit 24 ft. 5er, 418 HP/978 Tq., 24 ft KIT 5er.
Gary - K7GLD is offline
post #5 of 43 (permalink) Old 12-07-2006, 08:43 PM
MS Chapter President
2141pete's Avatar
I was told 1693 means you have a stored code in the pcu or ecu. Maybe this will help
TroubleCodes.net- engine & OBD2 Trouble Codes and Technical info & Tool Store.
If this is where you got it from it says at the top anything above P1000 is manufacturer specific and might not be right
94 rcsb 2wd, Ported head, HD181/210, big shiny pushrods, valve springs, TRE 47rh, DPC converter, Cheetah shifter, caltrac's, AD150, stainless diesel manifold, Stainless diesel twins, CPP 7x.012" injectors, detroit locker, and..........
2141pete is offline
post #6 of 43 (permalink) Old 12-07-2006, 09:16 PM
Mopar1973Man.Com
Mopar1973Man's Avatar
Actually that P1693 code could be any code really...
Like When I was doing some work on my truck I pull the harness connector apart and forgot... Well it tripped the CEL light... P1689 (If I remember right) and the P1693... After 5 key cycles the CEL light went out. The codes remained. But after 50 (or so key cycles) the P1689 code left and the P1693 remained...
So yes.. Your going to need a ODB II scanner to pull the older codes out... But OBD II scanner can also clear all old codes too... Where disconnecting you battery won't...
2002 Dodge 2500 (281k miles) - Quadzilla Adrenaline, +50HP Vulcan Performance Injectors, BHAF, 3" Flow Through Muffled Exhaust, AirDog 150 (10 years old)
Mopar1973Man is online now
post #7 of 43 (permalink) Old 12-08-2006, 02:47 PM Thread Starter
Thanks guys guess I gotta go down to autozone and have 'em check it out. Hope to god its not the IP......if so
post #8 of 43 (permalink) Old 12-08-2006, 05:34 PM
Whats up i have a 99 3500 cummins Its giving me the p1698 and in the dash it says no bus.. I read in a website it could be the crankshaft sensor i havent changed it i have a body computer the one that goes on the pasenger side and still hasnt cranked on.....
99cumminsoro is offline
post #9 of 43 (permalink) Old 12-08-2006, 07:27 PM
Tech Specialist
OK - I'll bite - what's a "body computer", and what does "cranked on" mean?
I must be getting old - some of this "new terminology" sure seems like Greek to me!
post #10 of 43 (permalink) Old 12-09-2006, 02:46 AM Thread Starter
Went to Autozone and had them plug their OBDII scanner up. It was two P0234 codes: Overboost condition. Cleared them out, haven't come back yet. Is there anything in particular that would cause overboost? Cold weather, engine not fully warmed up? I really don't lay into the pedal very much anymore, at least until I get some extra money to fix 'er up the way I want to.
post #11 of 43 (permalink) Old 12-09-2006, 01:17 PM
Tech Specialist
AH, great, no problem then - you either have an overly efficient turbo, or perhaps a borderline MAP sensor - I wouldn't worry about it - other than perhaps check connections to the sensor for corrosion or poor contact.
post #12 of 43 (permalink) Old 12-09-2006, 03:43 PM Thread Starter
I just about did a little dance for joy when I got the real codes read to me.
I'll check the sensors out a little later today. Gotta get me one o' them scanners
Thanks guys
