Trouble code!!!!!!!!! p1693 - Page 3 - Dodge Cummins Diesel Forum
post #25 of 43 (permalink) Old 04-15-2011, 07:58 PM
I am currently looking at a 24v 2002 2500 and i did the key trick to see if any codes would come up...the P1693 code came up and then said done....do you think it would be worth while taking it to autozone to have it expounded upon beings it seems like there is more behind that code?
also the E-brake light flashes even though the brake is definitely off....i knew a friend whose 98 24v did the same thing? any ideas?...
dieseldandy1988 is offline
post #26 of 43 (permalink) Old 04-15-2011, 10:15 PM
jlbayes's Avatar
the p1693 is a companion code. the truck has a code stored in the ecm for probably the transmission. you will need a scan tool to get the code and not just a code reader.
Jacob, "strictly business" 01 grumpy sob, Calibrated Addiction, Infinite Performance, Farrell Diesel, 97 rclb
jlbayes is offline
post #27 of 43 (permalink) Old 06-11-2012, 04:28 PM
wheres the best place to get a OBII scanner
ugo1st is offline
post #28 of 43 (permalink) Old 06-11-2012, 04:36 PM
guess I should discuss my problem .
Got 2000 3500 dually 4x4 219000 miles bone stock ect. for tranny and, air dog.
Dang thing will go into random limp mode and stay there untill a compleat cool down ( the next day !! ) the only code It will give is a P1693 . I need help . No one can figure it out . Its been to dealer ship and several local shops . I am in deep on this thing $$ with no results . HELP !!
ugo1st is offline
post #29 of 43 (permalink) Old 06-11-2012, 04:39 PM
WillM's Avatar
iTrader Score: 10 reviews
Your local auto parts store (O'reilly, Autozone, etc) will pull codes for free. . . If you can get your truck there?
Ranch Truck: '98.5 QCDRW, NV4500, 2WD, BHAF, Straight Pipe, FASS, Gauges, Steering Box Stabilizer, Ranch Hands
My Truck: '91.5 RCLB, NV4500, 2WD, Leveled, BHAF, 4" Straight, Isspro Fuel Pressure/Boost/Pyro/Tach/Oil, HX35, 24V Intake Horn, PS I/C, 3" Intake Plumbing, THD Competition 6x.013", VE Tuned, Hot Screw, Piston Pump, KSB Spacer, THD Pin, 366 Spring, Valair, A1 Studs & 60# Springs 282HP/692TQ
(w/ stock injectors)
WillM is online now
The Following User Says Thank You to WillM For This Useful Post:
ugo1st (06-11-2012)
post #30 of 43 (permalink) Old 06-11-2012, 07:32 PM
Mopar1973Man.Com
Mopar1973Man's Avatar
More on this code here...
P1693 codes (SOLO)
2002 Dodge 2500 (286k miles) - Quadzilla Adrenaline, +50HP Vulcan Performance Injectors, BHAF, 3" Flow Through Muffled Exhaust, AirDog 150 (10 years old)
Mopar1973Man is online now
post #31 of 43 (permalink) Old 06-12-2012, 08:06 AM
jlbayes's Avatar
if your trans is "built" the line pressure may be on the boarder of being to high. mine did that when i did the first build on it. if you had it at the dealership or any good repair facility they should have scanned it.
jlbayes is offline
post #32 of 43 (permalink) Old 06-12-2012, 09:29 AM
Quick question , What would be avrage oil presure for a stock 24 valve w/219000 miles ?
I only ask because I noticed this morning that my oil preasure gadge is reading 60-80 psi or 3/4 guadge with just the key on, and it dont move after i start it, or rev it ??
Would a oil preasure gaudge or sending unit trigger limp mode ??
ugo1st is offline
post #33 of 43 (permalink) Old 06-12-2012, 10:45 AM
WillM's Avatar
That might be a bad sending unit, but it wouldn't trigger limp mode.
The bottom line is, you need your codes pulled.
WillM is online now
post #34 of 43 (permalink) Old 06-27-2013, 08:36 PM
Kornbred11's Avatar
I have p 1693 but no other codes....my dealership has replaced ECU twicw....ive personally replaced turbo,fuel injection pumb....its driving me crazy....somebody please help
Kornbred11 is offline
post #35 of 43 (permalink) Old 06-27-2013, 09:03 PM
Kornbred11's Avatar
just found 0122 and 0500
post #36 of 43 (permalink) Old 06-27-2013, 09:15 PM
WillM's Avatar
Were you replacing parts just because you had P1693?
P0122 - Replace your APPS with a Timbo APPS.
P0500 - You we're probably just
anyone have a P0500 code?
WillM is online now
