What is "proper" 47re line pressure? - Dodge Cummins Diesel Forum
post #1 of 4 (permalink) Old 12-20-2008, 03:16 PM Thread Starter
Hey fellas. I got a chance to measure the line pressure in my 24 valve 47re. The transmission still shifts fine, but I want to make sure I keep it that way. I bought the truck about 20,000 ago used. The original transmission went and was replaced about 90,000 ago, but that's all the owner really knew, he wasn't sure what exactly was put in or if the old one was rebuilt.
It is a 99 transmission case with a <97 valve body. At idle the line pressure was about 55-60#, at 3,000 it was about 85-90#. I tried to research it, but I can't really find a standard for stock 47re transmission pressure. What do you guys think?
I'm just wondering whether I should leave it be since it's still shifting good after 90,000 or if I should put in a shift kit to improve it's life. She's gonna get used for towing, but there isn't any power mods.
99' 24 Valve Cummins 5.9 ISB Turbo-Charged Inter-Cooled Diesel, Extended Cab, Full Box, 4X4, No Tailgate and a Crack Windshield
Farmer Z is offline
post #2 of 4 (permalink) Old 12-20-2008, 03:33 PM
Horse Power JUNKIE
Nitrous340's Avatar
I have a book on it, but its at another house... But I'm pretty sure stock at idle is anywhere from 50-65. My suncoast is set at 85-90 at idle....
2001 2500 4x4
PhatShaft62
, DDP 150, TST Comp/Smarty, S&B Intake, PSC brace, Hamilton 110 springs, Fluidamper, ARP studs, 4" straight pipe, AIRDOG 150, BD black FP, Suncoast billet trans, 3-disc converter, 3rd Gen Brakes, Thuren 3rd Gen track bar. RIP grandpa "Red" 10-11-08
WAGNAAR MOTORSPORTS
Nitrous340 is offline
post #3 of 4 (permalink) Old 12-20-2008, 03:59 PM
From the FSM.
Overdrive clutch (Fourth gear only) Pressure should be 68-72 psi with closed throttle and increase to 90-130 psi at 1/2 to 3/4 throttle.
Line pressure (at accumulator) Closed throttle- 54-60 psi.
Front servo (Third or Fourth gear only) No more than 3 psi lower than line pressure.
Rear servo (1 range) No more than 3 psi lower than line pressure. (R range) 160 psi at idle, builds to 270 psi
at 1600 rpm.
Governor (D range closed throttle) Pressure should respond smoothly to changes in mph and return to 0-1.5 psi when stopped with transmission in D, 1, 2. Pressure above 1.5 psi at stand still will prevent transmission from downshifting
Hope I got this right. I had to edit and do copy and paste to get it here and look right.
RR
'02 QCLB 2500, 4.10, limited slip, auto w/Dynamic stage 3 build & LU switch, Edge Comp, Scan gauge II, Raptor lift pump, fuel pressure/trans temp/boost/pyrometer gauges.
Russ Roth is offline
post #4 of 4 (permalink) Old 12-25-2008, 04:37 PM Thread Starter
hey thanks a lot guys. that really helps cause i hear the pressure is the best way to judge the health of you transmission.
is it best to leave a stock transmission at stock pressures?
Farmer Z is offline
