Twin HX35's? - Page 2 - Dodge Cummins Diesel Forum
Old 10-09-2008, 03:38 PM   #13 (permalink)
199eightcummins's Avatar
MySpace.com - Go Fast Diesel Fast Twins buildup begins
local shop around INDY there were at the DHRA at ORP but I heard they dont have a good rep around here but im pretty sure its the same idea you are thinking off
FOR SALE!!! 1998.5 Dodge 2500 5 Spd CUMMINS Reg. Cab long bed
MODS: SB clutch, AEM intake, 4in TB, gauges,3in intake horn ,bd-boostfooler,DDP 110's, ARP studs, Superchips, Aurora 3000, FASS 95, and Vulcan draw straw II
Thanks for all the help from Mark at Danville Performance
199eightcummins is offline   Reply With Quote
Old 10-09-2008, 03:52 PM   #14 (permalink)
sooter's Avatar
i took this picture about 5 years ago. that truck was long since sold and i haven't seen the owner (tim) since around that time.
2004 Dodge Cummins 2500, smarty, homebrew built trans w/billet input, dpc triple disc converter, 2nd gen ex manifold, full 5in exhaust
-The size of your exhaust tip is not the size your exhaust. get over it.
sooter is offline   Reply With Quote
Old 10-09-2008, 04:34 PM   #15 (permalink)
DieselAutoPower.com
patracy's Avatar
iTrader Score: 5 reviews
Originally Posted by rufushusky View Post
Maybe but I wonder how much boost can they really produce? I think that is why you see the compound turbo set up more with diesel because they can handle, most of the time, far more boost and air volume than their gasoline counter parts and I think an s400, s480, ht3b etc would flow more air than even two smaller chargers working in parallel. But I am not a turbologist so I am not too sure. Yeah you can get 35 psi from an hx35 and an s480 but the s480 is pushing a TON more air. I am not saying it would not work I am just thinking return on investment.
I like everyone else here loves how Patracy thinks outside the box.
You've got to remember we're not looking for boost PSI, we're looking for FLOW. 800cfm at 20psi is better than 640cfm at 20psi.
I'd have to venture a guess that we're concerned with getting it to spool. But wouldn't "half" an engine with massive sticks provide plenty of the thermal energy needed to spin one turbo? I know my HX35 will launch into the stratosphere with just the ADR turned up.
Click here to visit www.dieselautopower.com
1999 2500 4x4 CCSB Sport. ADRENALINE/pulse , BHAF, 150 hp sticks, Tunnel Ram Intake plate, Byrd's intake Horn, HE351 retrofit, Hamilton 110lb valve springs, A1 head studs, 5" exhaust, Isspro Boost & Drive pressure gauges, fuel pressure gauge, FASS 150, 1/2" big line kit, Draw straw, TC lockup switch, Stealth VP plate, BD TC, BD VB, Billet input, Derale pan. 462hp and 920ft-lbs 11/14/09
patracy is offline   Reply With Quote
Old 10-09-2008, 04:36 PM   #16 (permalink)
DieselAutoPower.com
patracy's Avatar
Was that your truck?
Old 10-09-2008, 04:42 PM   #17 (permalink)
kooimanj's Avatar
your jammin all that air into one tube. Choke point might stop ya. kill your flow
2001 Dodge Cummins Sport. Got a few goodies. Starting to gather parts for a P-Pump convert.
kooimanj is offline   Reply With Quote
Old 10-09-2008, 05:25 PM   #18 (permalink)
i work at a marina and caterpillar does it with one of their engines granted it is 12 leiters but it works
jacksmack290 is offline   Reply With Quote
Old 10-09-2008, 05:56 PM   #19 (permalink)
rufushusky's Avatar
I gotcha, a s400 can flow up to 1500cfm, a pair of hx35s will get ya something like 1100cfm...
Turbo Flow Rates [Archive] - Competition Diesel.Com - Bringing The BEST Together
TDR Roundtable - View Single Post - k31 s400 ?? twins setup im unsure?
2002 Ford F-350 ECLB 7.3 4R100 4X4, 6637 intake, 203* T-stat, 08 diff cover, HPX, Stancor Relay
Gone:
04.5 Ram 2500 Reg Cab 48re 205k miles
Cat fuel filter
rufushusky is offline   Reply With Quote
Old 10-09-2008, 06:06 PM   #20 (permalink)
SPEAKSUP's Avatar
I have thought about this setup also cause you can find another one fairly cheap. I beleive this is how Woodruff uses them in their triple setup two parellel being fed by a big turbo. With some bigger sticks shouldnt have no problem. Also Outlaw diesel has a setup on their 12 valve like this said they saw 600hp with out Supercharger but then they added the supercharger fedding the twins. If you do this let me know how this goes cause I have been thinking about the same setup.
OHIO COAL ROLLERS
SPEAKSUP is offline   Reply With Quote
Old 10-09-2008, 06:08 PM   #21 (permalink)
sooter's Avatar
not. the guys name was tim. he used to be a diesel mechanic for Blue Chip Diesel when chip was in hudson, nh (that business was sold to ben, a former employee, who now runs it as Northeast Performance Diesel). at the time he was running bully dog 8s which if you remember were extremely smokey and smoked at idle. the twins hit 50psi, but i don't remember what size they were. he did make good power, but a good a good set of compound twins and the newer injectors out there would have out performed this system.
Old 10-09-2008, 06:11 PM   #22 (permalink)
sooter's Avatar
oh, haha, i see how i worded it that you thought it may have been mine.
i forgot to mention that he had cut up 2 12valve manifolds and welded them together. i dunno why, since it's a 24v (the port shape issue), but they didn't leak. the pressure hose was radiator hose used for testing i believe. but i didn't see him much after that day and then i eventually saw that the truck was being sold...stock..
Old 10-09-2008, 08:50 PM   #23 (permalink)
Hey Patracy…
It would work if you were looking to make 500 to 600 hp.
A very crude way of sizing a turbo is to look how much power it will support. An HX35 will hold about 250 to 300 hp. So, if you were to make around 600 hp, then yes… 3 cyl could push the turbine. Now, as far as lag goes… you would have the same lag as a stock set up. But, if you were pushing that kind of power… then a big turbo isn’t very laggy. But a smaller turbo has less mass… so it will spool faster than one big one. (simple physics)
One thought… you would want to get a turbine housing without the divider in it. A large T3 type may work, or a set of Banks quick spool housings possibly.
2001 2500 QC 4x4, edge EZ, Glowshift Gauges, 4" Exhaust, K&N, TransGo, AirDog 100, RV275
Tony, Prez A&L Motorsports, LLC.
Dr Honda is offline   Reply With Quote
Old 10-09-2008, 08:55 PM   #24 (permalink)
As far as an exhaust manifold…
I’ve built a bunch of “Log” style manifolds that flow well. If you can get someone to cut you a flange (1/2 inch steel) you can make the legs from cast steel pipe from McMaster Carr. It is very strong, very weldable, and cheap!!! Plus it will take the heat of the diesel. If built correctly… they look good, and wont crack.
Powered by vBulletin® Copyright ©2000 - 2012, vBulletin Solutions, Inc.
