Old 09-24-2008, 01:50 AM   #1 (permalink)
PA CHAPTER VP
BlueSportDiesel's Avatar
What is a good stack with a Smarty?
I am looking into adding another chip/tuner. What is a good stack with the Smarty. What levels should they be run on?
00' 2500 Sport 5 Speed
6" Miter Cut Stacks, 5" Strait Pipe, Smarty/Drag Comp Stack, Southbend Clutch, AirDog 100, 90HP Injectors
EGT, Boost, Fuel Pressure Isspro Gauges, Boost Elbow, Detriot Locker Tru-Trac, Mag-Hytec Differential Cover
BlueSportDiesel is offline   Reply With Quote
Old 09-24-2008, 06:54 AM   #2 (permalink)
Go for Broke
Graphic Man's Avatar
Edge Drag comp or Quad's ADR :thumbsup
I have ran both and prefer the Quad box
Scott
08 Mega cab is on it's way
SOLD01 4X4 Q-cab Sport Monster VP, Redline Injectors, twins 66/S480 with race cover, full billet trans etc,
Special thanks to: Redline diesel and Diesel Dr.s
Graphic Man is offline   Reply With Quote
Old 09-24-2008, 08:35 AM   #3 (permalink)
Space Shuttle Door Gunner
Caleb S's Avatar
Yeah I agree with Scott...
Edge Drag Comp or Quadzilla Adrenaline or TST PM3 :thumbsup
98 2500 4x4 5SP
Caleb S is offline   Reply With Quote
Old 09-24-2008, 03:34 PM   #4 (permalink)
PA CHAPTER VP
what about the edge ez? I think that the only thing i could actually afford currently. How does that work?
Steve
Old 09-24-2008, 03:38 PM   #5 (permalink)
Caleb S's Avatar
Steve
Probably not going to see a big difference with the EZ because it is only like 60HP...and you would have to run your SMARTY on even #'s only and then the EZ...probably not worth it to me. I would say just keep saving your money until you can get a DRAG COMP, ADR or TST...my thoughts at least :thumbsup
98 2500 4x4 5SP
Old 09-24-2008, 03:49 PM   #6 (permalink)
SmokingFords's Avatar
TST,Edge comp or juice.or adrenaline are the best ones
2001 Dodge 2500 Black sport 6 speed BD High HP VP44 Adrenaline/pulse Smoke switch SmartyRevo,.093 tubes DDP 200s HT64/65/14 turbo,southbend DD 3250 ,GFS-392 fuel system,AFE boost tube/ScottieII Snow water/ meth,FBD 5in to 7in tip,35"Nitto's Leving kit 511Hp 1012Tq
SmokingFords is offline   Reply With Quote
Old 09-24-2008, 05:19 PM   #7 (permalink)
THE BDR
ryans01's Avatar
wat he said...
IMO--i'd go with the TST or ADR before the Edge...
Ryan S.
"The BDR Edition" 2001 4 X 4, 3500, 2nd NV4500, II SO VP, SBC DD 3600 12CB w/ input shaft AND Valair HD HYDRO'S, TSTPM3, Edge EZ, AFE, FASS HPFP, 5" turnout stacks, gauges 319.9/776.8 4/25/09 DUNBAR'S DYNO
ryans01 is offline   Reply With Quote
Old 09-24-2008, 06:06 PM   #8 (permalink)
PA CHAPTER VP
Thanks guys. So it sounds like we have
Edge Drag Comp
TST
What is the TST who makes them etc?
Steve
Old 09-24-2008, 06:12 PM   #9 (permalink)
THE BDR
ryans01's Avatar
Steve
TST Products, Inc.
TST inc makes TST....it's a fueling box only....for the 2nd gens...u can stack it with a time'n box or run it as it is...don't get it unless it's either the PM3 or get the COMP unlock one. it's a very clean burn'n box...when run alone..IE without a time'n box...u won't smoke hardly at all...just a slight haze...with what's in my sig, minus the EZ i put down 399/1116 back in Feb on a mustang dyno...
Ryan S.
Old 09-29-2008, 12:12 AM   #10 (permalink)
BlackedOut02's Avatar
edge comp box!! i have a smarty on the way for mine after i saw my buddys set up. its like the juice but no built in safty crap. its fuel and timing that you can adjust them seperatly i LOVE mine. but thats just my $.02
'02 | 2WD | 2500 | NV4500
"Diesels dont run away. Diesels over speed, mechanics run away"
BlackedOut02 is online now   Reply With Quote
Old 09-29-2008, 02:50 AM   #11 (permalink)
Adrenaline
CUMMINS
dieselbomber is offline   Reply With Quote
Old 09-29-2008, 03:39 AM   #12 (permalink)
dsl kicks gas's Avatar
if you want to toy around with it for a month or so go with the ard, its a mean stack with the smarty. i had a tst comp, it surged about like it did with the ard. i sold my tried and true edge comp to buy the quad adr, ran the quad for 2 months, sold it and bought a edge drag comp. long story short EDGE DRAG COMP/SMARTY ALL THE WAY
fyi that south bend will hate you with what ever you stack with the smarty.
98.5 5spd, QC, LB, new 12v 911 pump, 4kgsk, dv's, 5x.014's, street/tow cam, 60# springs, ats manifold, 66/71/14, 3850 DD, AD 150, electric fans, and and so on
99 p pumped 2.8 puller
dsl kicks gas is offline   Reply With Quote
