Old 05-04-2008, 10:42 AM   #13 (permalink)
Posting Suspended
fast for us stock turbo guys
Originally Posted by SmokingFords View Post
What is Stage 3,I would like to no that
GETERDID is offline   Reply With Quote
Old 05-04-2008, 03:27 PM   #14 (permalink)
nitrorustler41's Avatar
you think its good enough for a 5 speed truck to pull a a mid 14 in the 1/4? maybe faster?
seriusoly, that would be pretty fast
dsm: who needs a dog, when you can walk your crank?
nitrorustler41 is offline   Reply With Quote
Old 05-04-2008, 03:33 PM   #15 (permalink)
Big R's Avatar
has anyone else had a problem with it cutting out? how much smoke is it giving you too...(not that it really matters) ...Just curious
'99 Cummins 3500 4x4 "The Big Ugly Black Truck with The Stove Pipe Exhaust"
Big R is offline   Reply With Quote
Old 05-04-2008, 04:25 PM   #16 (permalink)
002wd's Avatar
like in the title the truck would not turn off after cooling past 300deg. i was in the house and noticed i could still hear it running. went out with keys in my hand, put them in, turned back on and off no help. put in gear and tryed to kill it. wouyld not die. had to open the fuse box(inside cab) before it would die. the dash still stayed on. so i pulled the adr out from under the hood. i am going to redownload the tune to c if that could be the prob. but this has been working properly for two days now. any help on this would b great. my truk is in my sig. thanks
2000 QC gone. 98.5 3500 4x4 QC. stock for now, not for long. parts on order
002wd is offline   Reply With Quote
Old 05-04-2008, 04:45 PM   #17 (permalink)
002wd's Avatar
re; to big r. no cuttin out issues so far. i can shut the road down with the rigt pedal if u kno what i mean. well im lying i can make people hit the shoulder on the interstate. this thing will smoke like crazy. i am stackin it with a tune from Jim Jessup though:thumbsup
Old 05-04-2008, 11:27 PM   #18 (permalink)
Tech Specialist
BigBlue's Avatar
I tapped into the factory oil PSI sender and my dipricol optix EGT gauge wires for the adrenaline. Oil psi is dead on and pulse egt gauge is 130* high but it works pretty dang nice. Not to mention you it monitors water temp, fuel temp, fuel psi, ECM voltage, engine load %, tps %, boost, vehicle speed, corrected vehicle speed, tranny temp, and a few others. It pulls them from the ECM and seems to be pretty dang accurate.
2001 QC SB AT 4X4 p-pumped
BigBlue is offline   Reply With Quote
Old 05-05-2008, 02:54 PM   #19 (permalink)
GFB
GFB's Avatar
Will any 240-33 ohm pressure sender work for the fuel pressure or does it have to specifically be a 0-40psi sender? Would the scaling be off with a 0-100 sender? The 0-40 ones are tough to find.
2001.5 QC 4X4 Sport
It's black so all the ladies think it's bigger.
GFB is offline   Reply With Quote
Old 05-05-2008, 03:39 PM   #20 (permalink)
Posting Suspended
I pulled a LOW 10 in the 1/8 mile with two wheel drive slow launches... so god only know what I would have got with 4 wheel drive launches I was only on PL04 and im a 5 speed manual.. 70 mph at the finish line.
Old 05-05-2008, 03:45 PM   #21 (permalink)
Colorado Chapter Pres
jbarker's Avatar
R8917: Pressure Senders: 0 - 100 PSI - 240-33 Ohms (U.S. Ohm Range) - egauges.com
this is the sender that number i was given buy quad for the fuel PSI sender. it would be safe to say that any 240-33 ohm sender would work as well.
I run the quad with the parts listed in my sig + plus some extras, and i have run this truck at a best of 13.099 at 102mph. there is more in it i just need to play with the twins a little more and that was with the adrenaline on level 7 with the beta 3000 tune. This Weds is a test and tune night and i will see if i can sneak away to go play some more with it if not it will be Saturday for the E.T. races.
The little bit of surging issues with the beta tunes is due to the aggressive fueling this unit has and it does it only under light throttle because it wants to fuel harder then the TPS is telling it to IMO. once you hammer it there is no surging issues i can find.
John:thumbsup
99, QC short bed running the best of the best and proven to perform. 715 h/p 1400ftlbs 4-18-09
Holland Court Diesel
Give us a call for the best of the best. Quality brand names with service you can trust all backed by nation wide warranties. Pureflow, Valair, BD power, DDP, HTT, Industrial injection, Dipricol, Quadzilla, S&B, Snow performance, Edge, Diamond eye, MBRP, PDR and more. We install what we sell
jbarker is offline   Reply With Quote
Old 05-05-2008, 03:48 PM   #22 (permalink)
Smoked Ya!
Rollin Smoke Diesel's Avatar
Thanks John. I knew you would chime in with the sender :thumbsup
Monday-Friday 9am-5pm CST, online ordering 24/7
Proudly Serving the Cummins Forum since 2006
We are your Diesel Performance Store....Honest, Fast and Friendly Service!
Authorized H&S Performance, Smarty, VIP FASS, ARP, Hamilton Cams, EFILive, Grand Rock Stacks, Edge/Superchips, Quadzilla, Isspro, Diablosport, Spartan Tech, South Bend Clutches, S&B Filters, Flo Pro, Elite Diesel and many of the leading names in the industry!
Rollin Smoke Diesel is offline   Reply With Quote
Old 05-05-2008, 03:49 PM   #23 (permalink)
jbarker's Avatar
Thank you James for starting this thread
John
Old 05-05-2008, 08:50 PM   #24 (permalink)
riceater's Avatar
so since i already have an egt and fuel pressure gauge do i really need to put adrenaline's egt and fuel stuff on too
06 cc auto.FTE stage4 tranny and triple disc, billet flex plate, smarty pod, edge w/att hot unlock,MP-8, 5"tbe w/7"black tip, ATS intake elbow, S&B, dipricol gauges, Recon tails and 3rd brake light, tinted fogs, black headlights, custom painted grill, bushwacker flares, Aeroturbine 5050xl, Airdog 165, leveled w/20" Helo's w/35" mt atz's, 50hp ddp tips and II bag o parts. coming soon HTT 64mm, stainless mani
thanks FTE diesel, Rolling smoke diesel, Thoroughbred Diesel
riceater is offline   Reply With Quote
