Building a dream truck - Dodge Cummins Diesel Forum
post #1 of 48 (permalink) Old 02-14-2013, 02:34 PM Thread Starter
bmwtyler's Avatar
Hey i was looking for some help finishing my build.. I'm looking for around 700 hp and beyond whatever is manageable and reliable for street.. i don't tow or even drive my truck that often so its somewhat of a toy... i don't do pulls either..
2001 cummins - 80xxx km
As of now i have edge cts, 5" exhaust, fass 150, cold air intake, lift tires etc...
And its an automatic
Im looking to build my truck "bulletproof"
Im going twins and need help deciding between ATS, Industrial Injection, and BD.. price doesn't really matter as id like to just get it done right the first time!! I really want my engine bay to look nice and clean as well maybe get some of the parts powder coated..
Im stuck between 150 and 200 horse injectors as well.. i found DDP and Industrial injection so far that offer those sizes however industrials is a fair chunk more expensive..
Is there much of a difference between ATS, BD, and PPE trannys? and what stage of tranny wil i need.. billet intermediate, output and that necessary?
And is the hot rod vp the way to go?
Ive never built one before and i just don't want to buy it all and wish i had got something different after ..
Any info is appreciated.. thanks
7-8" skyjacker/fox/bds lift edge cts
fass 150 18" fuel pumps w 37" toyo mts
bmwtyler is offline
The Following User Says Thank You to bmwtyler For This Useful Post:
joe6 (02-15-2013)
post #2 of 48 (permalink) Old 02-14-2013, 02:37 PM
If you want 700hp or more for a toy, just p-pump it
mike
2011 mega
itspaid4 is offline
post #3 of 48 (permalink) Old 02-14-2013, 03:42 PM
As far as pumps go if you decide to stay a vp44 I would not buy anything but a monster pump. They fuel very hard and are reliable. But honestly p pump is the way to go for less headache. I'm just a glutton for punishment I suppose. As far as the rest of the question, the possibilities are endless. Pull up a chair at the computer and grab yourself some search function. You'll be suprised what you'll find.
highplainswelder is offline
post #4 of 48 (permalink) Old 02-14-2013, 03:57 PM
I really would look at suncoast, georend, or revmax for transmissions. Just my .02
1999 2500 QCLB 24valve, 4x4, built auto, air dog II, bhaf, isspro boost/pyro/fp/trans, 4" tbe, edge comp, leveling kit, 285's, tow mirrors, scan gauge II, new vp44
Jbh97009 is offline
post #5 of 48 (permalink) Old 02-14-2013, 04:56 PM
Ford_Cummins's Avatar
And go to Stainless Diesel for your chargers. He's the best hands down.
If you did a little research like most do, youll find some very good answers. Part of the fun and learning process is finding info and putting things together.
Heres an example, if you didnt know how to have sex, would you rather me do all the work by pounding your gf or would you rather figure it out for yourself?
A quote from a member on CompD
Ford_Cummins is offline
post #6 of 48 (permalink) Old 02-14-2013, 05:40 PM Thread Starter
bmwtyler's Avatar
whats the p pump all about.. does that mean scrap my edge and stacked smarty idea etc?
Im in ontario is there any place close to get those trans? they better than bd ats and pep?
bmwtyler is offline
post #7 of 48 (permalink) Old 02-14-2013, 05:44 PM Thread Starter
bmwtyler's Avatar
stainless diesel has a good twin setup?
bmwtyler is offline
post #8 of 48 (permalink) Old 02-14-2013, 05:56 PM
Marq92's Avatar
For the trans I'd go with either Goerend, Garmon, or TRE.
Mike
2001 QCLB 3500 47RE 4x4 3.54 Carli 3.0 TheRetroShop Projector Retrofit VLEDS
Marq92 is offline
post #9 of 48 (permalink) Old 02-14-2013, 06:19 PM
PA VICE PRESIDENT
Ramitt's Avatar
Going with a ppump will cause you to loose any programmer. They are all mechanical. Also a s.o vp44 is good up to 600-700hp.
Mitt
2002 2500 SLT 4x4 6 Speed 3.55's. SB Dual Disk ,Fass 150,Edge Juice w/attitude, 150hp injectors, AFE intake,5in str8 piped exhaust,20% window tint,Leveled with 33's,Halo head lights w/55watt hid's, 35watt hid fog lights,Ram Air Hood,High idle mod.
Dynoed at 420 hp - 960 ft-lb
Ramitt is offline
post #10 of 48 (permalink) Old 02-14-2013, 07:41 PM
irish power mad's Avatar
The only downside to a P pump is it's turned up all the time whereas a vp with a chip or programmer can be turned to different power levels or returned to stock with a flick of a switch.
Am I the only one who knows everything?
01 3500 Dually Q.CAB, Quad Adr.,pulse, 4" straight stainless exhaust, air dog FP 150 fuel preporator,
half inch draw straw and fuel lines.Rancho 5000 shocks rear, 9 way adjustable up front, 3.55 rear end.DIY built DTT trans, triple disc low stall Goerand tc,billet flex plate and input shaft, DTT shift kit, Holset HX40W 60/65/16 turbo(stock turbo propping the door open
)125hp DAP injectors pushing on the pistons, BHAF and more to come
irish power mad is offline
post #11 of 48 (permalink) Old 02-14-2013, 11:28 PM Thread Starter
bmwtyler's Avatar
i definitely like the idea of keeping my vp
bmwtyler is offline
post #12 of 48 (permalink) Old 02-15-2013, 01:03 AM
Did i really read that monster mikes pump is reliable? Guess that means his customer service is top notch also?
2015 2500 Big Horn 4x4 G56 Hills Green - EFI Live V2, Isspro Gauges, 5" Flo Pro Exhaust, Fass 150, Steed Speed, Valair Triple Disk, ARP 625, S467. AMP, Retro Headlamps, AF Alpha SF8 22x12, BDS 4" lift kit. Color Matched.
powerrda is offline
The Following User Says Thank You to powerrda For This Useful Post:
MDowns (02-15-2013)
