911 truck won't stop running need help fast! - Dodge Cummins Diesel Forum
post #1 of 12 (permalink) Old 01-11-2013, 10:35 PM Thread Starter
6chevy9's Avatar
My quadzilla is half way frozen and my truck will not shut off... Need to figure this out fast please. The screen with the boost egt ect ect is frozen but I can hit menu and get into everything. I had turbo timer set but the truck won't shut off. I give it throttle it just revs. Turn turbo timer off nothing! What do I do?
99 ext cab short bed 4x4 24 valve, auto trans #2, CAI, 79 cent shift kit, Quadzilla adrenaline 4k pulse v2, 2.5" HBS, fox shox, FASS 150, sinister sump, 5" pipe.
6chevy9 is offline
post #2 of 12 (permalink) Old 01-11-2013, 10:39 PM Thread Starter
6chevy9's Avatar
Alright I got her shut down! I went to pull the wire in the dash mounted fuse panel and as soon as I opened the panel door it started shutting off and turning back on. I think I have a bad connection there or something.
6chevy9 is offline
post #3 of 12 (permalink) Old 01-11-2013, 10:41 PM
In hook the POWER at the ALTERNATOR. Red wire.
.02 Cummins HO / 6spd / 4x4 / LBQC / Edge JWA / BD /200* T-Stat / Homemade HIGHIDLE /
cummins6sp5.9 is offline
post #4 of 12 (permalink) Old 01-11-2013, 10:58 PM
08dmaxx's Avatar
Take air filter off and stick something flat on it to cut off air supply.
Sent from my iPhone using AutoGuide.com Free App
05 ccsb, built trans, afe intake, cfm intake horn....awaiting EFI
08dmaxx is offline
post #5 of 12 (permalink) Old 01-11-2013, 11:02 PM
Mopar1973Man.Com
Mopar1973Man's Avatar
Like said above cover the turbo inlet with a board and choke it out then disconnect the batteries till you get you Quadzilla fixed.
Personally this is one of the few reason I will NOT upgrade to Adrenaline or Juice. All you eggs in one basket and really easy to have one failure that disables the truck completely.
2002 Dodge 2500 (276k miles) - Quadzilla Adrenaline, +50HP Vulcan Performance Injectors, BHAF, 3" Flow Through Muffled Exhaust, AirDog 150 (10 years old)
1996 Dodge 1500 (163k miles) - 5.9L V8, Dynamic 46RE Tranmission, Mopar Performance PCM
Mopar1973Man is online now
post #6 of 12 (permalink) Old 01-11-2013, 11:54 PM Thread Starter
6chevy9's Avatar
I was not aware of any of these issues with the quadzilla. This is the first time anything has happened with it.
6chevy9 is offline
post #7 of 12 (permalink) Old 01-12-2013, 12:45 AM
MikeRodrig27's Avatar
If it's not puking smoke out of the tailpipe and it is not revving super high, I wouldn't choke it out. I would start pulling fuses till she shut off. Sticking something over the intake might allow contaminants like dirt ect to get into it.
1998.5 24v Auto 2wd, 5" straight, FASS 125, 180 p-pump, .084 lines, 4k GSK, Mack Rack, ISSpro gauges
MikeRodrig27 is offline
post #8 of 12 (permalink) Old 01-12-2013, 12:51 AM
Nelson1248's Avatar
i had that happen to me with the turbo timer on the Edge i unplugged the wire under the steering column and it shut right off plug it back in and fire it up acted normal after that...
MOPAR or No car!!!
Built Not Bought!
2006 5.9 Laramie 6 inch Superlift 37x13.50R17 Toyo tires 17'' Fuel wheels. 7 inch Stacks!
Nelson1248 is offline
post #9 of 12 (permalink) Old 01-12-2013, 12:54 AM
What did you have your turbo timer set to? I could pull my keys out of my ignition with a ejwa and the truck still run till the temp got to a certain degree.
02 2500 QCSB, fass 150, afe stage 2 cai, Edge Comp, DTT built trans, straight 5", 2.8 charger, 6x18 sticks (sold)
Cumm02 is offline
post #10 of 12 (permalink) Old 01-12-2013, 01:11 AM
Nelson1248's Avatar
had mine at 350... my edge module was completly frozen the mph was reading 37 at a complete stop and egt's were still at 630 boost was at 2 it was just frozen... been meaning to call edge its happen a few times and now i just kinda dealt with it and unplug that clip under the steering column plug back in and go on my journey...
MOPAR or No car!!!
Built Not Bought!
post #11 of 12 (permalink) Old 01-12-2013, 12:22 PM Thread Starter
6chevy9's Avatar
That is exactly what happened to me. I had the timer set for 2 mins. But it was only the main screen that was frozen. I went into the menu and turned off the turbo timer went back to the main screen which was still frozen and nothing. So I turned the key back to on and then off again still nothing. I had to pull the wire in the fuze panel. 12 volts power to the quadzilla and it shut right off.
6chevy9 is offline
post #12 of 12 (permalink) Old 01-12-2013, 05:41 PM
Moparman. Your Edge Comp won't do this? Very possible I would think!!!
