24 Valve lash adjustment? noise/sound??? - Dodge Cummins Diesel Forum
post #1 of 16 (permalink) Old 09-18-2012, 09:21 AM Thread Starter
Huskiemuskie's Avatar
When I did my valve lash adjustment I did not have a barring tool so I used the alternate method to turn the engine backwards using a ratchet and socket on the alternator...
Here is my question/comment... I turned engine till I got TDC (everything was nice and smooth and quiet) did the valve adjustments then started turning engine to get to BDC... while I was turning everything was smooth and quiet and all of a sudden I start to hear a clicking noise every time I would turn over the engine... the sound persisted for about 5 or 6 turns on the rachet and then stopped... I never heard it again after that...
It noise/clicking sounded like it was coming from the aft bottom of the eng block oil pan/starter area...
Ever since then I have had a lumpy idle at startup issues...
I wonder if I damaged something internal...
99 Ram 2500 4x4, Auto, QCLB: Edge CTS juice/attitude, aFe Stage II cold air, aFe Bladerunner, Raptor 150, 5" MBRP turbo Back.
Huskiemuskie is offline
post #2 of 16 (permalink) Old 09-18-2012, 10:42 AM
Double check your lash. .01" intake / .02" exhaust.
Sent from my iPhone using AG Free
Cummins. is offline
post #3 of 16 (permalink) Old 09-18-2012, 10:50 AM Thread Starter
already did... prefect...
post #4 of 16 (permalink) Old 09-18-2012, 03:01 PM
Are you running stock cam and stock head? I don't see were barring the motor over from the alternator would cause any clicking noise unless you had a valve hit a piston?
Cummins. is offline
post #5 of 16 (permalink) Old 09-19-2012, 12:27 PM
clatterbuck2000's Avatar
do the las h agin turning the engine FORWARD. its not much difference but the lash will make a difference in setting the overhead. probably catch some flack on that but its worth a shot.
00 QCLB CTD Nv4500-steering brace-Isspro & Autometer gauges-BHAF-Airdog DF165
-South Bend DD3600-o-ringed-studded-DAP 7x.010 sac's-Borg S363Snow W/M-TST COMP/TS MVPLotta smoke...Not a whole lotta go
cracked 53 block Next to come: Engine under construction
clatterbuck2000 is offline
post #6 of 16 (permalink) Old 09-29-2012, 08:59 AM Thread Starter
Back to NORMAL !
Well I did the last resort to see if my IDLE issues would go away... I put my Original stock injectors back in and NO more loping, rough Idle, hard starts or stalling...! The only thing I will missing is the "on demand smoke" that the 85hp injectors provided... but i much rather NOT have the issue that they brought with them... (MY VP44 for whatever reason just flat out does not like them)
I took apart and cleaned the stock injectors before putting them back in. Starts up instantly... Idle a solid 800rpm and when I dial up the Edge I can get some BLACK on launch.... the trucks happy and so am I thanks for all you guys HELP... I've learned alot
post #7 of 16 (permalink) Old 09-29-2012, 09:38 AM
mprmn08's Avatar
Where they new injectors? If so I would send then back and have them checked. Sounds like they weren't set up right. Or send them somewhere anyway and have them cleaned and set.
98 2500 4x4 5 speed. exhaust and basic pump tweaks. ported head at the shop waiting to be put on...built motor coming soon.
mprmn08 is offline
post #8 of 16 (permalink) Old 09-29-2012, 11:40 AM
If they're newer injectors id be contacting the distributor. If your just after smoke wire up a smoke switch. Or if you want to take better advantage of that edge get a set of 150 nozzles or something. Sounds like your capable of switching the nozzles if you disassembled the injectors to clean them.
Cummins. is offline
post #9 of 16 (permalink) Old 09-29-2012, 01:19 PM Thread Starter
Brand new Industrial Injection 85 hp injectors... I called them and they said their injectors are pop tested...
I am thinking about having them checked to see what they are poping/set at ... maybe they missed one??? That could be the problem...
post #10 of 16 (permalink) Old 09-29-2012, 03:04 PM
pepsi71ocean's Avatar
did you pull off the injection pump vent to see when your engine was at tdc and bdc?
99 3500 Built DTT Auto, 600 lower TC, 3.55, 4x4, BHAF, 6" lift, ARP's, Danin Optix, Gauges, DAP 100hp sticks, FASS 95, 2LO kit, HIGH Idle, Silencer ring delete, 4" exhaust, SMARTY, 03 VW PASSAT 1.8T Big Thanks to (FTE Diesel),(DAP),(DTT)
They ROCK!
pepsi71ocean is offline
post #11 of 16 (permalink) Old 09-29-2012, 04:17 PM Thread Starter
Yes when I did the valve clearance...
pretty sure that is fine because the truck runs perfect now with the stock injectors back in...
post #12 of 16 (permalink) Old 09-29-2012, 04:23 PM
0124vctd's Avatar
Just curious. Do you know what your fuel pressure is when you start up? At idle?
2001 2500 4x4 SOLD.
06 2500 CCSB AUTO Patriot Blue Stock!
Crossroads Diesel Performance
0124vctd is offline
