I have a 2001 dodge with an quadzilla adrenaline and air dog 100 gph and after killing it every now and then when I try and start it it takes a while of turning it over or I have to bump the starter a few times and let my pump run. I think it may be my lift pump going out but not to sure any suggestions?
Sent from my Autoguide iPhone app
2001 Maroon Cummins Quad-cab 4X4. Air Dog II 100gph, Cold air, Three gauge pillar (Pyro., Trans., Egt.), 4inch-6inch tip. Ats exhaust manifold.
Probable fuel/air leak between VP and injectors, possible ECM problem
1999 QCSB 4x4 built 5 speed: Valair 13" clutch & hydraulics, BD short throw, EGT/boost/fuel gauges
HRVP, FASS 95, CPP 125's, Super B, BHAF, 4" TBE, Tunnel Ram, Pusher Intake, Edge Comp Drag
Carli Suspended with Carli control arms & 325/70s on 3rd gen rims SOLD Lookin for a 4x4 First Gen
98.5 4x4 ext cab short box, 5spd, valair dd clutch, SDX 7x12 injectors, Hamilton 188/220/109.25 cam, o-ringed, head studs, s357/s475 twins, fuel/pyro/turbo gauges, Hamilton 110# valve springs, 4.10's, dana 80 detroit lockers, AD II 165gph, Quad adr V2
Yup, inspect all the fuel lines in the engine bay for moisture, also check the plumbing for the Air Dog into the tank. Does your pump sound louder than normal?
sucks air in and wont leak fuel. have to pressurize your fuel tank to a few psi 2-3 and it should leak a bit
take your compressor and a rag and put air through where you'd put fuel in at. put some air in and keep it pressurized for a few min and it should show you where its leaking from
yes best to do it after your truck was just running as there is fuel through all tubes.
This is exactly the trick I use when trucks come into our shop with the same symptoms you are describing. It works every time.
I have had a few trucks that I couldn't find a leak and it ended up being the pickup tube inside the tank. Some of them crack above the fuel level and will suck air. I have had a couple trucks that the top cap of the sending unit it's self was cracked or not seated properly after it was re-installed on the truck.
But you know now that the issue is between the Air Dog and the tank. That is why I asked if the pump was getting louder. When the Air Dog sucks air the pump noise will get louder.
Alright thanks! That's alot of help man I'm getting a bigger lift pump anyway because of my new injectors but I wanted to find the problem first. But what I don't get is how random the leak is sometimes it'll crank up fine then others it takes a few bumps. Sometimes right after I kill it from driving and try and start it like five minutes later it'll be all the way leaked down.
