Aftermarket push rods? 2001 Cummins 5.9 - Dodge Cummins Diesel Forum
Old 03-06-2008, 06:00 PM   #1 (permalink)
MI Chapter President
IC-Smoke's Avatar
Aftermarket push rods.... Cummins 5.9 2001
are they worth it? who is selling them? I just read over on TDR that Hamilton has chromolly rods now....
Im going to be running a aftermarket cam on my 01 as well as upgraded valve springs... just checking to see if its worth it while the motor is torn apart...
Thanks guys
Ian
IAN COLEMAN - President Great Lakes CUMMINS Crew
1990,2001,2005,1962 M37
IC-Smoke is offline   Reply With Quote
Old 03-06-2008, 06:11 PM   #2 (permalink)
Smourj21's Avatar
iTrader Score: 4 reviews
for $200 thats cheap, why not just do it while its torn apart. it can only help Cummins HD Billet Push Rods 4340 Chromoly 89-98 Dodge 12 Valve Diesel
02 QCSB 6 Speed|215 P-Pump 600cc 24*|SAC 7x12|131 DV's|.084 Lines/.086 Tubes|64/71/14 over S475|Tunnel Ram|CFM+|6" Miter|Valair Comp DD 3600|Colt 181|HD Push Rods/Springs| O-Ringed Head|ARP Studs|AD150|Dana60/80|3:55|True Trac|35" Toyo MT's|Quest for 700+ |
Smourj21 is offline   Reply With Quote
The Following User Says Thank You to Smourj21 For This Useful Post:
dodgezilla04 (01-04-2011)
Old 03-06-2008, 06:12 PM   #3 (permalink)
Go for Broke
Graphic Man's Avatar
i say for the money i would do it.....i am sure a few vendors here can help you out Ian :thumbsup
08 Mega cab 6" lift with long arm kit, 2" leveling, flares, B/M, DPF delete, By-pass oil filter, cold air intake
SOLD01 4X4 Q-cab Sport Monster VP, Redline Injectors, twins 66/S480 with race cover, full billet trans etc,
Special thanks to: Redline diesel and Diesel Dr.s
Graphic Man is offline   Reply With Quote
Old 03-06-2008, 06:29 PM   #4 (permalink)
SIXINAROW's Avatar
I'd say, have you hurt what you got? How many people do you know that has actually hurt the stock push rods on one of these? I think that would only come into play if you planned on some very high rpm's. but then again if you do have it apart that would be the time to do it
97 dwr 4x4, DTT, SDX 5X16,215 pump/180dv, 20*,5k,60lb,.020" HD,hx35
SIXINAROW is offline   Reply With Quote
Old 03-06-2008, 06:33 PM   #5 (permalink)
Fishin2Deep4U's Avatar
How have they been tested?
I have asked about other light weight push rods in the past and can't get any answer.
I would want to be sure they won't fail under higher lift an or greater seat and over the nose pressures of aftermarket springs.
I don't anything about the brand you are specifying. Anyone have any info??
Dave
Fishin2Deep4U is offline   Reply With Quote
Old 03-06-2008, 07:24 PM   #6 (permalink)
Go for Broke
IMO if your running high pressure springs then it's cheap insurance
i have heard of a few guys bending and breaking them....but only a few
they are easy to add at any time down the road
Old 03-07-2008, 12:49 PM   #7 (permalink)
TDR Thread
I would say call OPoole.
Jim
2002 4x4 2500 5 speed HD QC LWB, Rip's Twins DZ/S400, SBC OFE, F1 Helix 2, F1 Mach 4's, TST PM3, Qaudzilla XZT+,
Pacbrake PRXB, Vulcan Draw Straw + Big Line, Glacier GSL-392, Smarty Revo
NoSeeUm is offline   Reply With Quote
Old 03-07-2008, 12:52 PM   #8 (permalink)
tank21pa's Avatar
i paid 125 for all new reg ones. so i would say do it..
GOLD CUMMINS QC SB "ENDLESS EXPENSE"
tank21pa is offline   Reply With Quote
Old 03-07-2008, 12:58 PM   #9 (permalink)
Performance Specialists
farmboysdiesel's Avatar
There are better out there.
farmboysdiesel is offline   Reply With Quote
Old 03-07-2008, 02:55 PM   #10 (permalink)
IC-Smoke's Avatar
so heavier springs and with the cam Ill need some....
what are some options?
Gus PM me bud! whattcha got?!
Old 03-07-2008, 03:09 PM   #11 (permalink)
Same stuff I run on my truck and you know that's some good stuff. :thumbsup
Old 03-07-2008, 06:58 PM   #12 (permalink)
I have the Source Automotive push rods on both of my trucks. Remember it's not just about the strength, but the weight. The less weight, the less inertia, which means the easier the valve springs job is. Not to mention stress on the rest of the valve train components. By looking at the stock push rods, it hard for me to believe that these rods bend. I can believe they get bent, which may seem like the same thing but it's not. Coil bind, valve float, and improper maintance can bend push rods. I don't remember what the weight reduction was, but it was quite a bit.
Paul
02 4x4 Auto Mach 6+'s, Drag Comp,Source Automotive Twins, Ultimate Transmission
05 2500 4x4 Flux 5's, Smarty SSR, Source Automotive Twins, F1 springs, F1 Cam, Crower Rods,Mitusa, PPE Dual Fueler, Ultimate Transmission, Opie shafts,Isspro gauges - 1015hp
paulb is offline   Reply With Quote
The Following User Says Thank You to paulb For This Useful Post:
Ragnar5823 (07-26-2011)
Powered by vBulletin® Copyright ©2000 - 2012, vBulletin Solutions, Inc.
