turbo spool rpm - Dodge Cummins Diesel Forum
Old 06-04-2012, 01:38 AM   #1 (permalink)
bleedcummins's Avatar
turbo spool rpm
what rpm do your turbo's lite?
what elevation are you, turbo your running, injectors, programmar/s, cam. manual or auto?
trying to see if mine is were it should be, and what i can change to make it better, or get more top end air suffering very little spool up time.
1700ish
5000-3500ft. super b, 75hp vco, adr. DTT auto.
i dont get hot down low, but CAN smoke like a train, but gets hot up top.... not enough air
02 2500 DTT, IQuad, s357/s475, 7X.012 sac, 110# springs, HD pushrods, ARP Headstuds, Traction bars, ATS Pulse-flow, Rad box, AirDog 453/998.9 (75s and Super b)
bleedcummins is offline   Reply With Quote
Old 06-04-2012, 04:03 AM   #2 (permalink)
chevota84's Avatar
What do you mean by light? When the boost gauge comes off the peg? 10 psi? Full boost?
Sent from my DROID X2 using Xparent Blue Tapatalk 2
99 Dodge 24v 5spd, tst comp/smarty, 7x.014's, super b over s475, fass 95
chevota84 is online now   Reply With Quote
Old 06-04-2012, 08:59 AM   #3 (permalink)
jlbayes's Avatar
i can see 3 psi at around 1300rpm's, 10 psi around 1500, and full boost shortly after. IMO you have plenty of air, whats your total boost?
Jacob, 01 qcsb 4x4 ported & o-ringed cr head eep 115# springs fmw s467.7 ats t4 manifold Weston's 6x.013s TS MVP Shibby GHD BD rad box 4" tbe w/6" mitre's bhaf 165 adII "built" trans w/triple disc DTT billet flex plate, p-pump in the works!
jlbayes is offline   Reply With Quote
Old 06-04-2012, 07:26 PM   #4 (permalink)
total can hit 40psi, sometimes it only goes to 35 or so. depends how i fuel it i guess.
i mean like i get some boost at like 1500, but at 1700 the peg jumps and rips. 1700 is where mine really jumps psi and gets me going. i guess its full boost i am speaking of.
Old 06-04-2012, 07:37 PM   #5 (permalink)
BlackedOut02's Avatar
I see full boost around 2000rpm. 7x14, mvp, and 63/68/14.
Under Construction
BlackedOut02 is offline   Reply With Quote
Old 06-04-2012, 08:02 PM   #6 (permalink)
jlbayes's Avatar
Do you have a boost elbow or just using the wastegate on the Turbo?
Either way it sounds like you may need to adjust the wastegate. I know your at a higher altitude but it should help. I'm way over fueled and I see lower egt's than you.
Old 06-04-2012, 08:03 PM   #7 (permalink)
Scott1's Avatar
Elevation is going to make you have more lag and smoke, I can light my twins at around 1500rpm +-100rpm depending on tune. I ran a superb special for a while and at 5500ft elevation it smoked like a pig. I'd think you should be building boost a little quicker than 1700rpm.
1999 qcsb with a few mods..
Scott1 is offline   Reply With Quote
Old 06-04-2012, 08:23 PM   #8 (permalink)
Dinner's Avatar
Agreed about the elevation!
As well, my twins "light" (reach 15-20lbs and flash to 60lbs) around 15-1600 RPM depending on how I'm driving and tuning.
2001 Dodge 2500 4X4: Goerend, TST, Smarty, MVP, BD Rad, Injectors, Two Turbo's, C-Tech Head, Snow Performance, Supporting Mods...
2002 TDI Jetta
Dinner is offline   Reply With Quote
Old 06-04-2012, 10:07 PM   #9 (permalink)
ok. thanks guys. maybe its my tuning in the quad making it laggy. or maybe i have a boost leak somewhere? or would bigger injectors make it spool faster?
with twins, will it spool faster, same, slower than it does now?
i am waiting on studs then i will play with the wastegate and go for 45-48psi. twins are the ultimate future plan.
Old 06-04-2012, 10:35 PM   #10 (permalink)
Freakin' Honey Badger
99StoneColdCountry's Avatar
1700ish
comes off the peg around 1300, by 1500 I'm lit and pulling hard
sea level, Super B, 125hp VCOs, Quad Max Mileage timing box, 5spd.
wastegate set at 45psi (until I get my head flowed/o-ring/studs), I get there quick. I was very impressed, I didn't think the Super B would do as well as it has. Had to play with the wastegate a lot at first though.. maybe that's where you're lacking? funny tune on Quad?
1999 QCSB 4x4 built 5 speed: Valair 13" clutch & hydraulics, BD short throw, EGT/boost/fuel gauges
HRVP, FASS 95, CPP 125's, Super B, BHAF, 4" TBE, Tunnel Ram, Pusher Intake, Edge Comp Drag
Carli Suspended with Carli control arms & 325/70s on 3rd gen rims
SOLD Lookin for a 4x4 First Gen
99StoneColdCountry is offline   Reply With Quote
Old 06-04-2012, 11:04 PM   #11 (permalink)
my tunes on the quad are
11
7
100
1800/2000 (two seperate tunes, pump stretch is the only difference)
80
25
80
25
20
i think thats all the tune info. it would be awesome to spool at 1500!!!! but i know my elevation will hurt that
Old 06-05-2012, 04:10 PM   #12 (permalink)
Western WA President
jigabop's Avatar
1500-1700 is where it really starts to pull (10psi to 65psi in about 1 second). depends on what rpm I floor it at though, and what tune I currently have it set on.
'00 2500 Sport 4x4 SOVP, 6spd, 4.10's 2" lvl, 315/75R16 BFG M/Ts, posi-lok, SB3600-6DD, DDP150's, S357/S475 twins, Adrenaline w/Pulse v1, Smarty, ARP 425's, AirDog150 + DS-V liberty mod, DiPricol fp gauge, 2x isspro boost gauges, 08.5+ steering, carli low-mount, DT ProFab track bar, 5"str8 pipe 538hp 1078tq 10/1/2010
"Tow mirrors extended with no trailer is like wearing a condom with no woman." - UnregisteredUser
jigabop is offline   Reply With Quote
