2001 cummins upgrades - Dodge Cummins Diesel Forum
post #1 of 19 (permalink) Old 05-01-2012, 08:30 PM Thread Starter
I know this has probably been asked 1000 times but I just picked up a 2001 qclb 4x4 5 sp. 212000 kilometers .I want make some more hp around 350 to 400 what would be the best way to go?
Thanks for any input
Buzz 880 is offline
post #2 of 19 (permalink) Old 05-01-2012, 08:36 PM
mprmn08's Avatar
lift pump, built trans, quadzilla adr., injectors, exhaust. i think that should about cover it.
98 2500 4x4 5 speed. exhaust and basic pump tweaks. ported head at the shop waiting to be put on...built motor coming soon.
mprmn08 is offline
post #3 of 19 (permalink) Old 05-01-2012, 09:13 PM Thread Starter
I already have egt,boost gauges was thinking starting with programmer air intake lift pump exhaust just wondering witch ones would work best
Buzz 880 is offline
post #4 of 19 (permalink) Old 05-01-2012, 09:21 PM
PA VICE PRESIDENT
Ramitt's Avatar
Lift pump before anything else. Also get a fuel pressure gauge too. Then you can do intake, exhuast and programmer.
Mitt
2002 2500 SLT 4x4 6 Speed 3.55's. SB Dual Disk ,Fass 150,Edge Juice w/attitude, 150hp injectors, AFE intake,5in str8 piped exhaust,20% window tint,Leveled with 33's,Halo head lights w/55watt hid's, 35watt hid fog lights,Ram Air Hood,High idle mod.
Dynoed at 420 hp - 960 ft-lb
Ramitt is offline
post #5 of 19 (permalink) Old 05-01-2012, 09:47 PM
ol work truck's Avatar
smarty programer raptor or airdog lift pump bhaf injectors and turbo
1999 3500 24v 5 speed manual, valair dual disk, 4x4, raptor 150, big line kit, triple ISSpro guages, quadzilla adr. stacked with smarty, BHAF, 7" Smeding diesel cat stacks
phatshaft 62/14, 100 sticks thanks to smeding and dap
ol work truck is offline
post #6 of 19 (permalink) Old 05-01-2012, 10:09 PM
"I'll go all in."
CumminTryMe's Avatar
iTrader Score: 14 reviews
Since you already have gauges, lift pump upgrade and trans upgrades... Then you can think about adding power safely.
"Don't let off, just stand on it! We've got parts!"
Combat Wounded Marine - Some Assembly Required
Originally Posted by HI H.O. SILVER
It's going to be a lot of fun if you like bottle rockets and ninja smoke.
CumminTryMe is offline
post #7 of 19 (permalink) Old 05-01-2012, 10:39 PM Thread Starter
What upgrades to the stick trans do u recommend
Buzz 880 is offline
post #8 of 19 (permalink) Old 05-01-2012, 10:43 PM
PA VICE PRESIDENT
Ramitt's Avatar
All you need is a clutch and while its out fix the 5th gear nut.
Mitt
Ramitt is offline
post #9 of 19 (permalink) Old 05-01-2012, 10:46 PM
97trxuszj's Avatar
Id do in this order:
1. Lift pump airdog, fass, raptor. Any will do id get a 150 gph pump as it will handle all future upgrades, even if you.dont plan on it. Its there in case
2. New clutch as i see you said it was a 5 sp
3. BHAF Big honkin air filter
4. Exhaust
5. Then whatever programmer you want id say edge comp since you have gauges or a smarty as you have a manual trans.
Hope that helps.
Andrew
01,AT,CC,4x4,LB,2.5"LEVELED¦5"TBE¦BHAF¦TRANS,BOOST ,FUEL,EGT GAUGES¦RAPTOR 150¦ DRAWSTRAW I¦1/2" LINES¦NO BANJOS¦EDGE COMP¦SHIFT KIT¦BILLET SINGLE|BLK 3RD GEN RIMS|GRID DELETE|TUNNEL RAM INTAKE PLATE|HX35|HOME BUILT 2 MIC FUEL FILTERS| DERALE TRANS PAN|PSC STEERING BRACE|REDHEAD STEERING BOX|CPP 3RD GEN TRACKBAR| DFI 7X.009 SAC INJECTORS| 35x12.5x17 NITTO TRAIL GRAPPLER MT |TIMBO APPS.|08+ STEERING
97trxuszj is offline
post #10 of 19 (permalink) Old 05-01-2012, 11:07 PM Thread Starter
I work in real dusty conditions in the summer what air filter would work best for dusty enviorments?
Buzz 880 is offline
post #11 of 19 (permalink) Old 05-01-2012, 11:11 PM
Get a afe pro dry stage 2 with a filter cover.
02 2500 QCSB, fass 150, afe stage 2 cai, Edge Comp, DTT built trans, straight 5", 2.8 charger, 6x18 sticks (sold)
Cumm02 is offline
post #12 of 19 (permalink) Old 05-02-2012, 12:19 AM
"I'll go all in."
I run an auto so not to sure on what all needs to be upgraded on a manual. They are a bit more stout then an auto for sure, but when you started adding power things wear and break faster.
For the filter, plenty of options and like mentioned get yourself a filter cover to run in dusty conditions.
