Revmax transmission build - Dodge Cummins Diesel Forum
post #1 of 82 (permalink) Old 02-28-2012, 09:03 PM Thread Starter
sportster1208's Avatar
I got all my parts in today from Revmax, they cut and cleaned my Torque converter and built me a new Valvebody with second gear lock up. This time everything is getting a higher clutch count to hold any extra power I can throw at it. They told me this thing will deffinetly hold 750hp+! I'm going to be drag racing, sled pulling and what ever else I can do put it through!
Here's what was waiting for me when I got home!
New stage 5 triple disk
New valve body with second gear lock up and increased line pressure!
Seal kit from Revmax
Billet piston and servo cover
1999 Ram 2500 standardcab, 2.8 puller
2008 Ram 3500 tow rig
B0TTSR brother of PA chapter
sportster1208 is offline
post #2 of 82 (permalink) Old 02-28-2012, 09:10 PM Thread Starter
More billet pistons and servo
Direct drive clutches and billet piston to increase clutch count
OD brake with reaction plate and increased clutch count
I'm excited to get started ! Maybe tomorrow! Thanks Revmax
Front clutch with reaction plate and more clutches then stock
post #3 of 82 (permalink) Old 02-28-2012, 09:29 PM
Nor'Easter's Avatar
Would love to have that going into mine
All in what was your total for the parts? PM me if you want..
Mike-97 2500 5spd.-5x.012s-3GSK-Usual pump stuff-Fluidampr-Stock Timing- 310/784 9/15/13 SOLD
97 F350 OBS Fummins-getting VE/NV4500 and frame-off and TWINS. SOLD
1957 Dodge Power Wagon 12v/NV5600/Coilover and Air Suspension
Nor'Easter is offline
post #4 of 82 (permalink) Old 02-28-2012, 09:42 PM
Banned
I just ordered through revmax this morning for my rebuild! Trans will be 750hp stable, minus i chose i single disk tc due to funds =( but im still safe for what i will be running!
stage 3 single disk torque converter-$400
complete rebuild kit-$499
supercoolawesome valve body-$349
billet 2nd gear servo, billet strut accumulator housing-$168
shipping-$nottomuch.
totaled out to $1525.
the capability to run hard, long, and fast, go home and sleep like a baby after warm milk with no worries of tranny failure, priceless.
gearmonkey23 is offline
The Following User Says Thank You to gearmonkey23 For This Useful Post:
sportster1208 (02-28-2012)
post #5 of 82 (permalink) Old 02-28-2012, 09:54 PM
Got P7100?
mathews8pt's Avatar
iTrader Score: 9 reviews
So they are squeezing 7 in both direct and OD brake?
Hobie
2000 QCSB, 180 pump, 6x.013's, maxspool 2.5, s364/s480, tranmission built by me, AD150
11.23 @ 121mph
mathews8pt is offline
post #6 of 82 (permalink) Old 02-28-2012, 09:57 PM Thread Starter
Yes they are able to do that by changing to a billet piston in the direct and a thinner reaction plate in the OD brake, using normal thickness or just a little thinner steels! But not thin enough everything gets warped!
post #7 of 82 (permalink) Old 02-28-2012, 09:57 PM
subscribed! keep us updated with a lot of pics troy!
2005 ccsb - 100% injectors, 10mm cp3, s366, 6.7 mega rail
qssc is offline
post #8 of 82 (permalink) Old 02-28-2012, 10:00 PM Thread Starter
THIS WILL GET YOU DROOLING FOR FINISHING THE JOB,!
post #9 of 82 (permalink) Old 02-28-2012, 10:07 PM
Got P7100?
mathews8pt's Avatar
DTT uses a billet piston and a machined reaction plate as well, but only goes with 5 in direct and 6 in OD brake. i am surprised they put that many in each pack. OD brake would be tough to get 7 in I would think.
Guess everyone builds them different...
Good luck with your build
Hobie
11.23 @ 121mph
The Following User Says Thank You to mathews8pt For This Useful Post:
post #10 of 82 (permalink) Old 02-28-2012, 10:14 PM
jtheado's Avatar
Subscribed! Wanting to see how it performs...
98 2500 12V|170K Miles|#0Plate|AFC MIA|HX35|Raptor 150|TorkTek Airdog OFV|Isspro EV Pyro/Boost|KDP Fixed|47re Stock|FBD 5"|BHAF
08 Chevrolet 3500 CCLB DRW|50k Miles|LTZ|100% Stock
jtheado is offline
post #11 of 82 (permalink) Old 03-01-2012, 11:31 AM Thread Starter
Looks like this weekend I'll be cleaning everything up and starting to reassemble!
post #12 of 82 (permalink) Old 03-03-2012, 07:11 PM Thread Starter
Well I got some done today,
Super second servo
Then I nicked the seal on the low reverse servo putting it in, dont ask! I was trying to put it in upside down!
New billet direct drive piston installed!
Clutches soaked and stacked! I got 6 clutches in with .097 clearances
Front clutch assembled with 5 clutches with .025 clearances
OD unit assembled with 10 OD clutches, and 7 OD brake clutches with about .100 clearance
That's all the farther I got till I get the lip seal for the servo and the right apply lever, I have a 5.0 and a 3.8 and I'm not sure which one to use with the valve body.
