400 big cam turbo onto a 99??? - Dodge Cummins Diesel Forum
post #1 of 12 (permalink) Old 02-17-2012, 11:30 AM Thread Starter
We have a peterbilt with a blown up 400 cummins,my friend said the other day hey why don't you put that turbo on your pickup?!! I just laughed but I wanted to ask the pros here can that even be done? Mine is a 99.5. Nv4500,strait pipe ,cold air intake and ,air dog raptor,stock injectors and vp44 I don't even think I would do it but I'm just curious
Sent from my Autoguide iPhone app
99 dodge ram
zhcampbell is offline
post #2 of 12 (permalink) Old 02-17-2012, 11:33 AM
Imcummin728's Avatar
Not sure exactly how big that turbo is, but with your mods there is probably no way you could ever spool it
01 QCLB 4x4 H.O. 6 speed|Valair Clutch|BD Short Shift|AFE Intake Manifold|Smarty|Applied Performance Stage 1 Turbo|MBRP 5" SLM|S&B Intake|DDP 100s|Airdog|Isspro gauges|Fluidampr|
Imcummin728 is offline
post #3 of 12 (permalink) Old 02-17-2012, 06:39 PM
DieselFan21's Avatar
you would need a lot more fuel to spin that big of a turbo. And even then you'd have other issues
'99 24v 4x4, 5" lift on 35s, W/M, 250DDPs, EdgeJuice w/Att, 57mm/S475, FASS150, all supporting the mods.. Built auto trans
'90 Dodge D250. Billet Trans, P-pump, triple turbos, 188/220, garden hose injectors
DieselFan21 is offline
post #4 of 12 (permalink) Old 02-17-2012, 07:36 PM
chevota84's Avatar
Ht3b or similar probably.
Sent from my DROID X2 using Tapatalk
99 Dodge 24v 5spd, tst comp/smarty, 7x.014's, super b over s475, fass 95
chevota84 is offline
post #5 of 12 (permalink) Old 02-19-2012, 11:09 PM
FireMed's Avatar
I was thinking it was a 4LEK? Maybe an HX60ish? You would need aftermarked injectors to really make it work for you.
"01" red with red tint, I'd say not quite stock
FireMed is offline
post #6 of 12 (permalink) Old 02-19-2012, 11:36 PM
chevota84's Avatar
If it was a 60 it'd be an ht60 which is a modern version of the ht3 but I'm pretty sure they weren't around until the n-14's.
Doesn't matter either way, its alot too big for a single on a VP truck.
post #7 of 12 (permalink) Old 02-20-2012, 02:25 AM
It has been quite a few years since I have looked under the hood with a BC400 but as I recall it is a pretty big turbo as others have said. Not only that the BC engines are 855 CID so that should tell ya something.
RR
'01 QC 2500 long bed, 3:54 auto w/Dunrite VB & LU switch, untapped Comp, Scan gauge II, Raptor lift pump, fuel pressure gauge and trans temp gauge.
Russ Roth is offline
post #8 of 12 (permalink) Old 02-20-2012, 01:23 PM
jlbayes's Avatar
should be a ht3b or ht60. have a bc400 sittin on the floor in the barn with a ht3b on it.
Jacob, "strictly business" 01 grumpy sob, Calibrated Addiction, Infinite Performance, Farrell Diesel, 97 rclb
jlbayes is offline
post #9 of 12 (permalink) Old 02-20-2012, 01:43 PM
sawdustmaker's Avatar
Just put it on as the primary in a set of compounds. itll work fine.
Yes i can reach the beer fridge from here
sawdustmaker is offline
post #10 of 12 (permalink) Old 02-21-2012, 10:40 AM
johnyb59's Avatar
^^^ Exactly. Put it under your stock turbo, makes a good set of twins. You will still need more fuel to get the full use out of them though.
08' SRW QCLB
johnyb59 is offline
post #11 of 12 (permalink) Old 02-21-2012, 10:58 AM
slideandride's Avatar
iTrader Score: 4 reviews
dude if you run an old charger off some blown up pete your asking for trouble in your pick up, one thing I have learned is if it looks cool and kinda seems like a good idea becuase a buddy suggested it, dont do it!. Like the guys above said with your mods you are no where close to having enough fuel to spool and even if you did you wouldnt like it around the street and it would run like garbage. The charger on there would be similiar to a K1 turbo, I have an old 85 359 pete with a big cam 4 in it as well and I wouldnt attempt to run that charger.
BROTHERS DIESEL PERFORMANCE
Springville, NY
slideandride is offline
post #12 of 12 (permalink) Old 02-21-2012, 11:21 AM
Twistedcummins's Avatar
Idk if it's in questionable shape then have it rebuilt get some bigger injectors, 150's-200's and run it under your stock turbo for a nice compound setup like others have already said.
99 QCSB 4x4 auto/Edge/Airdog/Isspro
Originally Posted by USARMY12V View Post
With a 47RE it's impossible to tell. It's easier diagnosing what's wrong with a woman.
Twistedcummins is offline
