Airdog 165 install - Dodge Cummins Diesel Forum
post #1 of 10 (permalink) Old 01-05-2012, 10:26 PM Thread Starter
ddesness's Avatar
Airdog 165 install
Just bought the airdog II 165. Did some research. Couldn't really find much. I have an in-tank pump. I don't have the tools to pull the bed. Any recommendations for easy install? Do I have to drop the tank? What about the draw straw? Did you guys also use that special tool to hook up the lines? Thanks for the help
'01 Edge Airdog AFE 4" Brake.
ddesness is offline
post #2 of 10 (permalink) Old 01-06-2012, 12:18 AM
alrhoads's Avatar
I looked around and there is a video on youtube that takes you step by step from start to finnish, and yes you will have to remove the tank to upgrade the draw straw. I dont have one of these pumps yet but I am looking forward to getting one when I have the cash.
Video 1
Video 2
2001 F250 12V cummins (in progress) auto quad cab, AD2 150, 4K governer springs, HX35, Waste gate locked, TCU stand alone tranny controller, 9'6" v-plow, salt spreader.
alrhoads is offline
post #3 of 10 (permalink) Old 01-06-2012, 12:30 AM
Automotive Connoisseur
seanb02's Avatar
You don't need any special tools to pull the bed, just regular hand tools to undo the bolts and the fuel filler. A buddy is a good idea to slide it back about a foot and half, no need to even remove the rear bumper, just rest it on that and the rear tires. If you don't have anybody to help its not real expensive to rent a engine hoist for a day or two, doesn't take long to do the in tank part and everything can be back together quickly. Pulling the tank will be a major undertaking, lots of hassle doing it that way. No tools required for hooking any of the fuel lines up, push on fittings until they click, its that easy. Make sure to route your fuel lines carefully near any edges that could wear into them. The hardest part is going to be neatly routing the wiring harness and deciding where you will mount the pump. Good luck!
2002 6 SPEED QCSB 4x4
- in a state of flux -
- 2003 Honda Element... Economical, Reliable, Utilitarian, and Ugly -
- 1998 Chevrolet Suburban... Tool Hauling Service Rig -
- 1973 Volkswagen Beetle... In storage, future project car -
seanb02 is offline
post #4 of 10 (permalink) Old 01-06-2012, 10:27 AM Thread Starter
ddesness's Avatar
Video 1 AirDog Installation - Video 1 of 2 - YouTube
Video 2 AirDog Installation - Video 2 of 2 - YouTube
Thanks for the help fellas. Ima try to tackle this tomorrow.
ddesness is offline
post #5 of 10 (permalink) Old 01-06-2012, 01:33 PM
jlbayes's Avatar
you will need a release tool to un-hook the factory lines from the original fuel pump. thats the only special tool you will need.
Jacob, "strictly business" 01 grumpy sob, Calibrated Addiction, Infinite Performance, Farrell Diesel, 97 rclb
jlbayes is online now
post #6 of 10 (permalink) Old 01-06-2012, 07:54 PM
SmokinCummins's Avatar
You can remove it without special tools. Just pinch both blue tabs and pull the line off.
Sometimes, people just HAVE to spend money on a mod no matter how useless it is.
SmokinCummins is offline
post #7 of 10 (permalink) Old 01-06-2012, 10:30 PM
seanb02's Avatar
One other thing, when drilling and installing the straw into the in tank module and cutting out the original lift pump, be careful as the plastic is rather brittle. A new fuel module from Dodge is very expensive. I cracked mine while drilling it and ended up spreading silicone around the top to keep it from leaking. Going to pull it back apart again in the next couple weeks and put JB Weld around it as the silicone is only a temporary fix and the Diesel will likely eat through it. Also be sure to watch the rubber gasket around the top of the tank as it is easy to pinch or drop down in the tank while reinstalling the module.
seanb02 is offline
post #8 of 10 (permalink) Old 01-09-2012, 11:13 AM
jlbayes's Avatar
gotcha. i must be thinkin of something else. been awhile since i had mine apart.
post #9 of 10 (permalink) Old 02-13-2012, 08:19 PM
You might want to try some Permatex Hylomar Universal Blue. You can get it at any parts house. It's meant for fuel and it isn't a silicone base. I used it on a leaking fuel flange on my motorcycle several months ago and it hasn't leaked a drop. Its meant for high heat areas and doesn't mind if its in an area that is repeatedly taken apart and put back together. It's some awesome stuff and seems a little less permanent than JB Weld.
2001.5 CTD QCSB 4x4 Auto 3.55 - 4" Diamond Eye, AD150, iQuad, BHAF, ISSPRO Gauges.
Gunsablazin is offline
post #10 of 10 (permalink) Old 02-13-2012, 09:17 PM
MegaRam2002's Avatar
If you didnt do it already, I got a few picks of my install, look for Thread called....I Need help installing Draw Straw I .....In 98.5-02 Powertrain.
Might help some, or at least give you an idea. I enjoyed the install except the part i bled the line and a ton load of diesel came flyin out
2002 5.9L Longbed auto ,Edge w Juice, AFE stage 2 intake,Phatshaft 62/65/12 ,ARP Head studs, Airdog150, Contagiou$ Diesel SAC 7x.010, Magnaflow turbo back, RebuildTrans dd disk shift kit billit conver, New Vp44 ,VPMAX intercooler boots,Pusher intake,Traction bars from CPP
MegaRam2002 is offline
