2001 Cummins 24 valve upgrades on normal mans budget - Dodge Cummins Diesel Forum
post #1 of 23 (permalink) Old 11-21-2011, 11:01 PM Thread Starter
N.D. Cummins Man's Avatar
I have a 2001 Cummins with a 5 speed with around 130,000 miles...everything is stock other than a high flow exhaust system and a diablo sport puck..what can I do to upgrade my truck and get maxium power and mileage both combined on a normal mans budget though....plz leave only positive feedback
2001 Cummins with Diablo sport puck and high flow exhaust
N.D. Cummins Man is offline
post #2 of 23 (permalink) Old 11-21-2011, 11:09 PM
Headcase98002's Avatar
iTrader Score: 9 reviews
A good HPFP to start with. Once you get a good lift pump on there you need gauges. Then a boost elbow and BHAF.
1998.5 QCDRW - p24v 180hp pump, 6x.013's, ATS T4 Manifold, s363/68/.83 - HT4B, TunnelRam, BD Intercooler, Hamilton Springs/Push Rods, FirePunk Billet Trans, DPC 3150 TC, PowerStop, IssPro Gauges.
Headcase98002 is offline
post #3 of 23 (permalink) Old 11-21-2011, 11:09 PM
BlackedOut02's Avatar
Reliable, cheap, fast. You can only have two...
Under Construction
BlackedOut02 is offline
The Following 2 Users Say Thank You to BlackedOut02 For This Useful Post:
c418 (11-24-2011), texfan91 (11-22-2011)
post #4 of 23 (permalink) Old 11-21-2011, 11:12 PM
I pick cheap and fast....
The Following User Says Thank You to Headcase98002 For This Useful Post:
runit02 (11-25-2011)
post #5 of 23 (permalink) Old 11-22-2011, 12:01 AM Thread Starter
I like gauge pods better...i was wondering what the best combo would be as far as chips to get the best of both worlds to get mileage and power and to have a gauge pod
post #6 of 23 (permalink) Old 11-22-2011, 01:54 AM
chevota84's Avatar
Adr or juice.
Sent from my DROIDX using Tapatalk
99 Dodge 24v 5spd, tst comp/smarty, 7x.014's, super b over s475, fass 95
chevota84 is offline
post #7 of 23 (permalink) Old 11-22-2011, 02:02 AM
rhagfo's Avatar
You have a good combination already.
Get a Fuel pressure gauge as soon as you can, most importand to the long life of your VP$$ (injection pump). You need to be running between 15 to 20 psi at idle and no less than 10 psi at WOT (Wide Open throttle).
01 2500 5.9 QCLB 4X4 5 Spd, Valair DD Organic, Power Puck, 298K miles ISSPRO Gauges FP, Pyro,& Boost. "A" Pillar, FASS DDRP-02, BIG Line Kit, 18 PSI, 3.55's, Kool Vue Tow mirrors, Bilstien 5100's, Pacbrake, Puke bottle deleted.
rhagfo is offline
post #8 of 23 (permalink) Old 11-22-2011, 02:53 AM
biopoweredcummins59's Avatar
Definitely need a fuel system first!! check out airdog or fass. Will help you out in the long run and will let u throw more power to er without an issue. Then Get u some injectors, 100-150 with stock turbo. Injectors will go a long way with your set up... Need to get gauges before the injectors though, keep an eye on egt, fuel psi, boost. Those are the main ones:.... Most of all have fun with it and make it your own!!
Sent from my Autoguide iPhone app
08 2500 QCSB 6spd 4x4, 5'' Exhaust, Fleece Tune, 2nd gen Swap w/ S472, Southbend 3250, Track Bars, Dynatrack BJ's, Blisteins, Carlie adj Track Bar, Synergy HD Steering Upgrade.
biopoweredcummins59 is offline
post #9 of 23 (permalink) Old 11-22-2011, 11:09 AM
I would say a fuel system, gauges, a clutch, bhaf, then a tuner, injectors, in this order just my opinion
texfan91 is offline
post #10 of 23 (permalink) Old 11-22-2011, 11:27 PM Thread Starter
Thanks I'm lovin all the imput..Its alot of help and there's never to many opinions or to much help
post #11 of 23 (permalink) Old 11-22-2011, 11:28 PM Thread Starter
What would be the best all around clutch? I was thinkin Southbend stage 2 perhaps?
post #12 of 23 (permalink) Old 11-22-2011, 11:40 PM
I would go with a valiar there cheaper and just as good in my opinion i ran a valiar 550 hp full ceramic and loved it
texfan91 is offline
