1839* egt too hot? - Dodge Cummins Diesel Forum
Old 09-17-2011, 12:28 AM   #1 (permalink)
R.N.Cummins's Avatar
1839* egt too hot?
cant seem to keep the truck's egt cool, probe is pre turbo, laid into it through 4th gear today and the pulse read out was 3,736 rpm at 39lbs of boost and the temp was 1839*, coolant maxed at 201, oil maxed at 187, only thing that seems to get hot is the egt, and its every time i get into it is when i get hot, if i bog it down by shifting to a gear early and put my foot to the floor it just blows black as hell every where but my egt dont get bad, maybe 1100*, but if i run it hard at wot and shift around 3500rpm it is always above 1500*, any way to drop them? mods are below and current
2002 QCSB that compound and down, loaded up and truckin!
R.N.Cummins is offline   Reply With Quote
Old 09-17-2011, 12:34 AM   #2 (permalink)
Alberta.Cowboy's Avatar
Upgrade the turbo and intercooler your cookin those piston rings as it is right now
If you start playing around with injectors like your 150's you need to play with the turbo at the same time
2006 Dodge 3500HD QC/SB, 60HP BD Injectors, Edge Juice w/ Attitude Hot Unlock, Flo Pro Turbo back exhaust, Silencer Ring MIA, Kore Racing Rims, Chromed Out, "THE HUMMIN CUMMINS!!!"
[SIGPIC]https://www.me.com/gallery/#100012/DSCN0783[/SIGPIC]
Alberta.Cowboy is offline   Reply With Quote
Old 09-17-2011, 01:08 AM   #3 (permalink)
yeah thats why i went up to the hx40, guess thats not enough
Old 09-17-2011, 01:12 AM   #4 (permalink)
i know in the adr i can adjust what my egt's are but cant seem to find out any info on that
Old 09-17-2011, 01:15 AM   #5 (permalink)
m!kediesel's Avatar
Hx40 is no where near enough. I have basically the same setup as you and before I did my twins I I just had the hx35/40 hybrid and I saw 1800 degrees everyday ha. Did my twins and got it down to 1500 by the end of the quarter mile.
2001 5 speed, quadzilla adrenaline pulse v2, raptor 150, SDX 7x.012 with .010 lift, valair 650 horse DD clutch, tank to vp44 big fuel line kit, hx35/40 hybrid over bht3b twin turbos, fireringed and arp studded head. 604/1290. SOLD
m!kediesel is offline   Reply With Quote
Old 09-17-2011, 01:15 AM   #6 (permalink)
Tomczaksdiesel's Avatar
That is way to hott!!! 1400 is hott enough!
Watch the skinny pedal till a bigger turbo comes into play
2004.5 Antlantic Blue, 2500 qcsb, 3.73, 4X4, w/ Edge Juice with Attitude, Magnaflow 5in, Nitto Trail Grapplers, AFE air intake, Air Lift airbags,... Shocker Xl train horns.. Can you hear me now?
Tomczaksdiesel is offline   Reply With Quote
Old 09-17-2011, 01:21 AM   #7 (permalink)
Viper Powered
mjd91's Avatar
iTrader Score: 5 reviews
Sounds like you like to play.
Get a 62/71/14 turbo.
If a Prius drifts is it called the
Electric Slide?
mjd91 is offline   Reply With Quote
Old 09-17-2011, 01:54 AM   #8 (permalink)
BlackedOut02's Avatar
you may want to try tightening your gate. 39psi seems a little low.
Under Construction
BlackedOut02 is offline   Reply With Quote
Old 09-17-2011, 01:55 AM   #9 (permalink)
well it seldom doesnt have a horse trailer behind it, 24ft goose neck, but yeah when its not hooked up it still gets a work out, didnt buy it to baby it.....is there a good single turbo setup that will help out the egts, i deff need one that can spool fast, kinda read a few things on here about a spool-aid? couldnt really get to much more info on that
Old 09-17-2011, 01:56 AM   #10 (permalink)
how do i go about doing that, i know its a little low, but i dont want to go over 44 or so lbs with out head studs? head studs are in coming when uncle sam gives me some money back at tax time lol
Old 09-17-2011, 02:06 AM   #11 (permalink)
i guess it depends if your hx40 has a wastegate. there is a threaded arm on your actuaror. take the pin off the gate arm, adjust it in or out to control how your gate opens.
if i were you. id try removing the boost elbow and replace it with a pipe plug. i plugged mine a few weeks after i bought my truck. made many 50psi pulls, no problems. (after i retorqued the studs to 125ft/lbs)
Under Construction
Old 09-17-2011, 02:23 AM   #12 (permalink)
m!kediesel's Avatar
I ran 60 psi everyday without head studs or fire rings and had no problems. I ran 47psi on just my 35/40 hybrid forever also without problems
