Spool-aid/charge air line review - Dodge Cummins Diesel Forum
Old 09-14-2011, 06:33 PM   #1 (permalink)
Branden246's Avatar
Well I finally got around to installing the spool-aid that I got from Mitch. I did some testing with it today and I was very impressed with the results. Normal driving the egts stayed about the same. I still have to test it on the highway to see if the cruising temps go down. I did a few wot runs and egts averaged 150* less with the spool-aid. I would hit on average 1600* before the spool-aid. With the spool-aid I was hitting right around 1450*. I would say that's a very noticeable drop by just adding that. Spool time didn't change to much, but that's not really what I wanted to achieve out of it. The main reason I wanted to try it was to see if it would lower my egts, and it did.
Thanks again Mitch for it!
2001 3500 SRW 12mm Ppump 651/1158 @ 40 psi, 24*
SO VP Fuel Only 606/1138
Branden246 is offline   Reply With Quote
Old 09-14-2011, 07:46 PM   #2 (permalink)
"I'll go all in."
CumminTryMe's Avatar
iTrader Score: 9 reviews
Aren't you glad I told you to get it??
On a serious note... thats a pretty big drop in EGTs. Especially for what you paid.
"Don't let off, just stand on it! We've got parts!"
Combat Wounded Marine - Some Assembly Required
Originally Posted by HI H.O. SILVER
It's going to be a lot of fun if you like bottle rockets and ninja smoke.
CumminTryMe is offline   Reply With Quote
Old 09-14-2011, 07:51 PM   #3 (permalink)
Branden246's Avatar
Haha. Yeah I'm glad you told me to get it. I'm very happy with the results from it.
Old 09-14-2011, 08:03 PM   #4 (permalink)
"I'll go all in."
Theres not much difference between our trucks... except your manual trans, ADR 4k, and cam. I like to keep tabs on your truck because it gives me some what of an idea of what my truck might be like. You've got a powerful, solid running rig Branden.
The Following User Says Thank You to CumminTryMe For This Useful Post:
Branden246 (09-14-2011)
Old 09-14-2011, 08:26 PM   #5 (permalink)
Branden246's Avatar
Our trucks are going to be pretty much the same once I get the cam. That's a project for later this year though. How long will it be until you get your truck back together?
Old 09-15-2011, 01:31 AM   #6 (permalink)
"I'll go all in."
The truck was together right before my leave ended, except I didn't get the cam or trans in, nor did I get the adrenaline installed. Since theres still major engine work to be done I decided to pull the head and send it to ZZ Fab, so a couple weeks ago my buddy pulled the head and prepped it for shipping, and sealed up the motor. It'll be all together again when ever the Marine Corps lets me get out... looks like febuary at the earliest.
Old 09-15-2011, 10:30 AM   #7 (permalink)
Branden246's Avatar
Hopefully you get out earlier than that. I want to see what your truck can do. Do you think you will get any time between now and then to work on it?
Old 09-15-2011, 10:35 AM   #8 (permalink)
Viper Powered
mjd91's Avatar
iTrader Score: 5 reviews
Glad you like it! How did you route it? Up and over or down and under?
If a Prius drifts is it called the
Electric Slide?
mjd91 is offline   Reply With Quote
Old 09-15-2011, 10:57 AM   #9 (permalink)
Branden246's Avatar
I will have to post a picture up. I actually have it in an S shape underneath. When I first had it all connected it was rubbing against the steering shaft. To fix it I twisted the intercooler pipe so it pulled the hose away from it.
Old 09-15-2011, 12:15 PM   #10 (permalink)
joe6's Avatar
I'd like to see a pic aswell. Thats a good drop in egt's!
2001 xcsb auto SLT, 60/64/14, raptor bedliner, leveled, 09-10 steering, cpp track bar, 35's on 17" Warriors, bilstien 5100's, 4" SS exhaust, raptor 150, big lines, isspro fp guage, afe dry, torque tube, Adrenaline/pulse, Junk DTT converter in a built trans
joe6 is offline   Reply With Quote
Old 09-15-2011, 12:56 PM   #11 (permalink)
Branden246's Avatar
Here are a couple pictures of it. They are kinda hard to see.
Old 09-15-2011, 01:12 PM   #12 (permalink)
Do you think the truck will be a little harder to start in cold weather?
Dodge 2500 4X4 LB, smarty, juice, 90 injectors, 62/65/12, 4" exhaust, T steering, Allison 5 speed transmission, w/271, 19.5 wheels and tires, 3rd gen brakes, DT Radius arms, Buck Stop bumper, Cracked 53 club . Soon; stroker crank, cam and a 451ve.
bwdt is offline   Reply With Quote
