raptor vs airdog - Dodge Cummins Diesel Forum
Old 09-02-2011, 09:39 AM   #1 (permalink)
I don't see tail gates's Avatar
raptor vs airdog
i was told that a raptor and air dog were about the same pump but the raptor didnt have some thing on it that the air dog did i cant rememer what it was need help
blue 2001 2500 5speed 8ft bed 5in strait pipe 8inch tip with ceramic clutch and silence ring removed,smarty s-03
I don't see tail gates is offline   Reply With Quote
Old 09-02-2011, 09:44 AM   #2 (permalink)
Branden246's Avatar
The airdog has filters. The raptor does not.
2001 3500 SRW 12mm Ppump 651/1158 @ 40 psi, 24*
SO VP Fuel Only 606/1138
Branden246 is offline   Reply With Quote
Old 09-02-2011, 09:51 AM   #3 (permalink)
so if i went with the raptor i would have to get filters or what idk nothing about performance
Old 09-02-2011, 09:53 AM   #4 (permalink)
Branden246's Avatar
You can run the raptor to the stock filter. The airdog can be run directly to the vp, or it can be connected to the stock filter housing as well.
The Following User Says Thank You to Branden246 For This Useful Post:
I don't see tail gates (09-02-2011)
Old 09-02-2011, 09:53 AM   #5 (permalink)
Hide your cats!
mstoaks's Avatar
no you dont have to get filter. i got the gdp 2 mic kit. that could be you option for filters. i think it would still be cheaper going that route. atleast thats what im going to do.
2005 white auto, thanks to stoakenstine creations, 23 Diesel, bully dog td ver. 2.5.3, 5" TBE to 6" stack, bhaf, GDP air boss, full triple pod, gdp 2 mic. edge ez 517hp 990ft.lbs
mstoaks is offline   Reply With Quote
The Following User Says Thank You to mstoaks For This Useful Post:
Old 09-03-2011, 01:39 AM   #6 (permalink)
wzeman's Avatar
The airdog is a fuel air seperator system they also make the raptor fuel pumps which is just a pump that you can run to your current filter setup. They also make a FRRP Factory Raptor Replacement Pump which is the raptor pump that mounts in place of the stock lift pump and connects to the stock fuel filter.
The Kit Comes with a about 12" of 1/2" line going from the pump to the filter housing.
2002.5 Ram 3500 4X4 225000+ miles, Rebuilt NV4500 5 Speed, Val air 13" Upgraded Clutch, FRRP fuel pump, RV275 Injectors, Edge EZ, Scanguage 2, Extra Lights Front and Rear, Viper Alarm 350 Plus, Glowshift Fuel Pressure and Boost
wzeman is offline   Reply With Quote
Old 09-03-2011, 09:50 AM   #7 (permalink)
dieseljay74's Avatar
iTrader Score: 4 reviews
I installed the Raptor 100 and love it. Got the full big line kit with it and also did the GDP 2 Micron fuel filters. The Raptor allows you to still use the factory fuel/water seperator which is actually a good unit...so why remove it. Plus the GDP kit options you to use bigger fuel lines leading to the factory filter as opposed to the 1/4" metal oe ones.
On top of it, the Raptor is built like a garbage disposal so it is very durable...and easy to install
'03 2500 CTD
RAPTOR RP100 W/GDP 2 MICRON INLINE KIT
6" TGC LIFT
37" MT/R Kevlars on XD Enduros
DIABLOSPORT PREDATOR w/AEM BRUTE FORCE CAI
BANKS HIGH RAM & 5" TBE w/30" FTE RESONATOR
GREAT LAKES CUMMINS CREW MEMBER
[SIGPIC][/SIGPIC]
dieseljay74 is offline   Reply With Quote
Old 09-03-2011, 02:40 PM   #8 (permalink)
joe6's Avatar
I jus saw that filter kit. I got some questions though... Where do you get the replacement filters? where does it install? Can you install it the same place as the stock filter and just get rid of the stock filter all together? I'm iinterested now. lol
2001 xcsb auto SLT, 60/64/14, raptor bedliner, leveled, 09-10 steering, cpp track bar, 35's on 17" Warriors, bilstien 5100's, 4" SS exhaust, raptor 150, big lines, isspro fp guage, afe dry, torque tube, Adrenaline/pulse, Junk DTT converter in a built trans
joe6 is offline   Reply With Quote
Old 09-05-2011, 06:17 PM   #9 (permalink)
You can get them at your local Cummins location...they are only like $10 there...or from any place that sells the kit itself I would guess...It installs on the inside frame rail under the driver seat area....in my truck ('03) anyway.
Some years mount right by the valve cover area. Depends on the year truck.
Stock filter stays in place and this is an additional filtration unit. You would want to keep the OE filter canister since it's a water seperator also.
Either that or ditch it and get the filter/water seperator combo that GDP sells also.
Check here....Glacier Diesel Power - Product List
'03 2500 CTD
6" TGC LIFT
[SIGPIC][/SIGPIC]
Old 09-15-2011, 12:39 PM   #10 (permalink)
So wasn't planning on upgrading the fuel system, but when I changed the fuel filter out, I realized the stock lift pump had crapped out as I tried to prime the system after changing the filter.
I went with the Raptor FRRP because I don't have big power plans or anything, just want something reliable that can support a programmer. It's only about $60 more than a stock lift pump and with all the negatives out there about the stockers, it was an easy choice.
Install was pretty easy, instructions were clear and thorough, took about an hour overall working in the driveway at night by myself, and I'm very pleased so far. It is a beefy looking pump and requires some patience to get it installed on the bracket, but other than that a pretty easy install.
Also, props to dieselmanor.com....David Murphy has a military discount on everything there and I ordered it on Monday and received it UPS by Wed. with their regular shipping rate.
benartm80 is offline   Reply With Quote
Old 09-15-2011, 08:05 PM   #11 (permalink)
KATOOM's Avatar
Remember.....volume is just as important as pressure. The OEM fuel system is very restrictive because of small ID fuel lines and banjo fittings. So not only do good aftermarket fuel pump kits come with better higher volume pumps but they also come with larger supply fuel line and JIC fittings which are night and day different in flow compared to restrictive banjos.
'01 2500 Sport 4x4 5spd, EZ, straight piped, no sillencer ring, aFe intake, 2 lo kit, Isspro Boost, fuel pressure, and EGT all on pillar, Westach Transmission/Differential temp gauge in dash pod, Raptor 100 with big line kit, Pac Brake, 285's
KATOOM is offline   Reply With Quote
