mean flat bed - Dodge Cummins Diesel Forum
Old 08-29-2011, 09:01 PM   #1 (permalink)
mean flat bed
hey guys i got a 99 work truck with smarty and im considern 150 injecters and a hot vp but i pull a lot and dont wanta get it to hot will that thro a lot of fuel and power with the programer on stock?
Megapower 06 is offline   Reply With Quote
Old 08-29-2011, 09:12 PM   #2 (permalink)
Fill in your sig so we know what all is done to it. Do you have a pyro, boost, and fuel psi gauge? You're prob gonna need a bigger turbo than stock to keep it cool depending on how heavy you tow.
2010 QCSB 2500 SLT Bighorn Deep Water Blue G-56 3.42
SolarYellow05 is offline   Reply With Quote
Old 08-29-2011, 10:43 PM   #3 (permalink)
modestodieseldk's Avatar
A lot of turbo talk going on, specifically with 150s. ASsuming you have the supporting mods, i.e. lift pump, all gauges, stout transmission etc, then a 62mm of your choice would work well with 150s. You can do without the larger turbo, but I wouldnt tow anything with it, and I would keep a light foot most of the time
It's got a blower?
modestodieseldk is offline   Reply With Quote
Old 08-30-2011, 07:58 PM   #4 (permalink)
CoalRoller's Avatar
If you tow a lot get a standard output vp44 and a fueling box that taps the vp44. JMO From what I've read, the high performance vp44's won't last as long as a standard pump and the so pump is good for 500hp or better.
2002 6-speed, 5 inch straight pipe, Icebox, Edge Drag Comp, +100 hp injectors from Diesel Auto Power, Isspro pyrometer, mechanical boost guage & electric fuel pressure gauge. FASS 95, Valair kevlar/ceramic clutch...
CoalRoller is offline   Reply With Quote
Old 08-31-2011, 09:01 PM   #5 (permalink)
thanks guys but like if my truck is set on stock with 150s and even a so pump will it add a lot of fuel
Old 08-31-2011, 09:09 PM   #6 (permalink)
Headcase98002's Avatar
iTrader Score: 8 reviews
It will be a good increase. YES!
1998.5 QCDRW - Edge"DRAG"Comp, TunnelRam, ATS Pulse Flow Exhaust Manifold, s362/HT3B Compounds, BD Intercooler, SOVP44, 6" Exhaust, SAC 6x.013, FASS 150, FirePunk Billet Transmission, DPC 3150 Triple Disc Converter, B&M Deep Trans Pan, BD Steering Brace, Detroit Truetrak, DD Diff Cover, TGC 1" Coil Spacers, Rough Contry-Nitro-Shocks, LT235/85R16 Kumho Road Ventrure SAT KL61, Gauges, exc.
Headcase98002 is offline   Reply With Quote
Old 09-01-2011, 09:55 AM   #7 (permalink)
jlbayes's Avatar
if your running just the injectors without a fueling box you will be alright! i ran 150's on a stock truck and my pyro would NEVER get about 900 degrees. with the tst on there its a different story though!
Jacob, 01 qcsb 4x4 ported & o-ringed cr head eep 115# springs fmw s467.7 ats t4 manifold Weston's 6x.013s TS MVP Shibby GHD BD rad box 4" tbe w/6" mitre's bhaf 165 adII "built" trans w/triple disc DTT billet flex plate, p-pump in the works!
jlbayes is offline   Reply With Quote
Old 09-01-2011, 12:17 PM   #8 (permalink)
ok thanks guys and all so my truck has to be started with eather but when u get it runnin it runs fine i was told it could be a cam shaft senser problm but idk yall ever heard of that
Old 09-01-2011, 01:08 PM   #9 (permalink)
jlbayes's Avatar
do you have an aftermarket lift pump? if so pull the fuse before you try and start it. it should fire right up
Old 09-01-2011, 01:45 PM   #10 (permalink)
yea i do and when i do pull the fuse
some times it cranks and sometimes it dont
Old 09-01-2011, 09:36 PM   #11 (permalink)
TripleT's Avatar
probably is your Crankshaft Position Sensor probably throwing a P0336 code
2000 Dodge Ram 2500 4x4 White Extended Cab, Garmonized 47RE Triple Disc TC, Smarty/ADR w/iQuad, 5" straight pipe to 6" tip, AFE stage 2 CAI, Amsoil Dual oil filtering kit, Boost Elbow, Raptor 150 fuel pump,On-board Air and Train Horn, 2" Leveling kit
TripleT is offline   Reply With Quote
Old 09-02-2011, 05:34 PM   #12 (permalink)
yeap il try that is that above the starter?
