08-25-2011, 09:18 PM
#2 (permalink)
iTrader Score: 8 reviews
The 62 is the inducer size of the compressor wheel, the 65 is the exducer size of the turbine wheel, and the 13ss the size of the turbine housing. Sometimes instead of seeing a ??cm size for the turbine housing you will see a ?.??AR. The wheels are measured in millimeters.
Say you have a Hx35w turbo - The compressor is a 54mm inducer/78mm exducer. The turbine wheel is a 70mm inducer/60mm exducer, and it has a 12cm waste-gated turbine housing.
1998.5 QCDRW - Edge"DRAG"Comp, TunnelRam, ATS Pulse Flow Exhaust Manifold, s362/HT3B Compounds, BD Intercooler, SOVP44, 6" Exhaust, SAC 6x.013, FASS 150, FirePunk Billet Transmission, DPC 3150 Triple Disc Converter, B&M Deep Trans Pan, BD Steering Brace, Detroit Truetrak, DD Diff Cover, TGC 1" Coil Spacers, Rough Contry-Nitro-Shocks, LT235/85R16 Kumho Road Ventrure SAT KL61, Gauges, exc.
