4" down pipe??? - Dodge Cummins Diesel Forum
Old 07-19-2011, 03:06 AM   #1 (permalink)
lociman's Avatar
4" down pipe???
so i have a 2000 dodge with a stock turbo and i was looking into a 4" down pipe but lookin in there at the turbo outlet looks like it is the stock 3" so what good will a 4" pipe do when u are still only push out a 3" outlet just woundering if it helps or if it just sounds really cool
lociman is offline   Reply With Quote
Old 07-19-2011, 04:00 AM   #2 (permalink)
HDKid's Avatar
You can get a larger elbow for the exit on the turbo, but the larger pipe helps open things up and flow better. To get a complete 4" exhaust an upgraded turbo(S300 or hx40) and hx40 downpipe is the best way.
HDKid is offline   Reply With Quote
Old 07-20-2011, 12:48 AM   #3 (permalink)
Not like the others......
dieseltracks's Avatar
Yes, the turbine outlet is only 3"...and yes a 4" dp will help if going with a 4"exhaust".
Just be sure if you buy a 4" dp to tell whoever that it is for a stock turbo so they can get you the right size for the inlet.
05 2500 Quad Cab Long Bed....BullyDog PMT
Project "Bits-n-Pieces"
dieseltracks is offline   Reply With Quote
Old 07-20-2011, 11:35 AM   #4 (permalink)
PatD's Avatar
pac brake & banks sell a 4" elbow. Dieseltracks your sig shows tst/van aaken stacked, hows that working? I thought van aaken was timing & fuel, I'm interested in what kind of hp your seeing, Op sorry for the hijack
99 2500 5 spd 275 hp injectors, afe stage ll, van aaken sb-r, 4" str8 exhaust, fass 150, pyro, boost, fuel press, LUK cerametallic, boost elbow,tunnel ram
PatD is offline   Reply With Quote
Old 07-21-2011, 01:01 AM   #5 (permalink)
The VA is timing only...it adds some fuel but only what it can through the can-bus (data link) connector via the computer (doesn't tap the pump wire).
Some VA's had a toggle switch that allows you to run a timing only setting or timing+fuel setting. Mine has the toggle switch...I like it just for that reason...I can run it either way depending on my mood.
I usually just run the VA on timing only and use the TST to add fuel...seems to get better MPG that way.
I dyno'd a little over 400 the last time...but I've had some IP issues for about 2 yrs. now...it runs so I don't mess with it.
Old 07-21-2011, 09:26 AM   #6 (permalink)
PatD's Avatar
Thanks for the info, I dont have my VA switched, I'm going to checkout that option
