Old 12-28-2007, 09:20 PM   #13 (permalink)
Slow from the get Go 6spd
Tread Heavy's Avatar
I for one have not had many problems with my dodge truck. Everything is holding up right now(knock on wood). I can say i had more problems out of my 02 chevy(duramax). The door lock would fall out any time you unlocked the truck, broke a leaf spring at 20k(still not sure how that happened), and the idler pulley froze up at 30k.
We run E450's at work and they are plagued with Ac problems, vaccum problems all the time, and we are not going to start on the 6.0
So I think all the trucks have there own set of problems. You just have to pick which set you want.:thumbsup
RED04.5 Quad Cab 3500 4x4 SRW SWB NV5600 6 speed with SB OFE, 3.73's, K&N intake, Banks Six Gun with Speed Loader, Boost Gauge, Pyrometer, Muffler and Silencer Ring MIA, 4 inch Superlift, 18'' American Racing Wolverines with 35x12.50x18 Nitto Mud Grapplers rapped around them, tailgate spoiler like the 07's have, Black tool box and Brush Gaurd
Tread Heavy is offline   Reply With Quote
Old 12-28-2007, 09:36 PM   #14 (permalink)
Larry @ DPP
DiscountPowerParts1's Avatar
If they ever invent a time machine, Im going back to hunt the man or men that invented the concept of the van.... and take them out! I will stop the insanity that is the modern van with the snub nose. I have been forced to work on some 7.3L E-Series vans, and your one sore and hurting puppy after that. Its uncool in the most severe of ways. Death to the gods of the modern van!
DiscountPowerParts1 is offline   Reply With Quote
Old 12-28-2007, 09:40 PM   #15 (permalink)
Larry @ DPP
Almost forgot to mention... Ford 6 leakers.....
Stuck VGT turbos
Stuck EGR valves
Cracked EGR heat exchangers.
Injector failure
Head bolts made out of play-doh... alowing head gaskets to blow daily.
Leaking bellows on right side up-pipe.
Easiest way to work on it.... step one... remove cab from frame.
You couldn't get me to buy a 6-Leaker (or 6-Slow?) on a bet. And I am a Ford lover that bleeds blue! Problem is.... I also work on them! I'm dumb.... but I'm not stupid.
Old 12-28-2007, 09:41 PM   #16 (permalink)
BigDsCummins's Avatar
I had an '01 7.3 before I got my first Cummins. I had it modded and I can tell you from experience the Cummins is way easier to mod and get more hp out of. It is also more reliable when you do all the right mods the right way. JMO
'06 3500 Sport 4x4 QC DRW, 48RE, Sunroof, Loaded, 6" Superlift, 37" Toyo Mt's, Quad Commander & Xzillaraider, Therminator Muffler, Gutted Intake, Silencer Ring Gone...
'96 3500 4x4 DRW, 5spd., 3KGSK, 12mm Studs, 60lb Springs, No Plate, Starwheel Cranked, Disabled Wastegate, Isspro Boost & Pyro, BHAF, Silencer Ring Gone, 4" Turbo Back...
BigDsCummins is offline   Reply With Quote
Old 12-28-2007, 09:43 PM   #17 (permalink)
Stuck VGT turbos
Stuck EGR valves
Injector failure
Old 12-29-2007, 12:40 AM   #18 (permalink)
Kbrogger's Avatar
I like Chevy pickups much more than any of the others. But I won't buy a new one, (all three brands are ugly), and I won't buy a Dura-reck. My brother has a 2000 Chev 3/4 with the worthless 6.0 gasser w/ 55k miles on it. He wants a newer pickup so it might be a good swap truck. It'll need a little lift though, I've gotten used to sitting up a bit. ol
2001 H.O., 6spd, Edge comp, FASS 150/150, South Bend con OFE clutch, MBRP 5" exhaust
Kbrogger is offline   Reply With Quote
Old 12-30-2007, 12:33 AM   #19 (permalink)
my dad has a '00 7.3 and the truck itself feels much better built and is a bit more comfortable to drive. Howeve, his is more modified and mine is virtually stock and I dont think his is a whole lot faster.
bottom line: (in my opinion)
-If you want an easy/cheaper go-fast truck then i'd say cummins, if you dont mind the dodge part.
- If you want a more comfortable rig thats still very reliable and can pull just about anything the cummins can, then go with the 7.3, but it probably wont be as fast unless you throw a whole lot of money at it.
- you cant really go wrong with either truck
'01 black 2500 5-speed QC/LB. banks high ram. 4" exhaust. FP, pyro, and boost gauges. FASS 95/150. BHAF w/ heat shield.
TXaggie09 is offline   Reply With Quote
Old 12-30-2007, 01:16 AM   #20 (permalink)
GA VP...so close to 500hp
patracy's Avatar
Originally Posted by Bosshogg View Post
I swear I dont know why you guys b!tch about the dodge part of our rigs!!!
What part of it is dodge, The frame and the cab?
Cummins engine
NV trans (OK so the autos are dodge, but autos suck anyway)
NV Tcase
Dana Axles
IMHO, the best trucks ever made, thats why I bought one.
Chevy's feel vauge when driving to me, and the ride is stiffer than my dodge, and IFS sucks ballz
Fords are way too hard to work on and the quality is slipping way out of line. My dad had ford trucks all his life until he recently bought a chevy (all gas BTW I cant get him to convert) and his 92 ford was the best of all. The 99 he got had to wait forever to even get the truck after he ordered it, and the quality just was not there, truck was falling apart after 50K miles
Just my observations!!!
Good god, what kinda chevy did you drive? My 02 durmax IFS rode like a Cadillac (Oh wait, that's a GM product too) Want vague? Drive my 99 cummins. Coming to a stop will keep you on your toes. Seems to be a common problem though.
1999 2500 4x4 Club Cab Sport. sorta functional ADRENALINE/pulse , BHAF, FBD 150 sticks, 3rd Gen HE351 retrofit, Hamilton 110lb valve springs, A1 head studs, 5" FBD exhaust, Isspro Boost and Drive pressure gauges, fuel pressure gauge, FP light, Mallory Comp 250 pump, 1/2" big line kit, Draw straw, TC lockup switch, Stealth VP plate, BD TC, BD VB, Billet input, Derale pan. 462hp and 920ft-lbs 11/14/09, I know I can get 500hp...
patracy is online now   Reply With Quote
Old 12-30-2007, 02:06 AM   #21 (permalink)
Kbrogger's Avatar
OH what about the wandering. Feels like your driving blitzed, or worse you drive straight when you're hammered.
Electrical- What doesn't go wrong
Drivers side window took a crap on me. Glass came out of the clips
Eventually the back doors will be f-ed and either not seal, or not close.
The powerlocks stopped working, then started working, then stopped working, then......
The doors only shut well when they're new, or if you're careful and your A-hole friends don't slam your doors for you.
I don't think the Dodge interior is the worst. Chevy "feels" the best, Ford seems the cheesiest. Chev's ride nice, Dodge/Ford=lumberwagon. Chev's handle the best by far, Ford is ok, dodge is CRAP!!
Old 12-30-2007, 02:13 AM   #22 (permalink)
TECH SPECIALIST
DodgeCummins98's Avatar
Talk about a thread going way off topic.
Some of you guys I don't know why you drive a Dodge. If the Fords and Chevys are so good buy one.
I like the Dodge/Cummins combo. Always been good to me and I plan to keep buying them.
98.5 2500 4x4 Reg Cab, 6" GrandRock's, Adrenaline w/ Pulse, FASS 150, Isspro gauges, Auto to NV4500 swap, Leveled on 315's Cooper ST's - Engine being rebuilt
07.5 3500 6.7L G56 Manual 4x4 Quad Cab Dually
DodgeCummins98 is offline   Reply With Quote
Old 12-30-2007, 03:19 PM   #23 (permalink)
Amen!:thumbsup
Old 12-30-2007, 07:51 PM   #24 (permalink)
proracer700's Avatar
i love my dodge. I would never buy a ford for one reason...my grandpa has a powerstroke that he had a chip in and which he doesn't even use anymore. 9 tranny's later. pretty bad for a truck that just hit 130k
2002 2500 qc 4x4, 4 inch bds lift, mt wheels and tires, fbd 5 in. straight piped, k&n air filter, silencer ring (m.i.a.), isspro fuel boost and pyro, bhaf....more goodies to come
proracer700 is offline   Reply With Quote
