how do i adjest the wastegate to build more boost? - Dodge Cummins Diesel Forum
post #1 of 25 (permalink) Old 04-03-2011, 01:40 PM Thread Starter
95ctd95's Avatar
hey guys i have an 01 24v with the stock turbo how can i adjust the wastgate to make it build more boost? a step by step process would be very helpful!
1999 ram 2500 24v 200hp injectors 8 inch stack intake leveling kit with 305's
95ctd95 is offline
post #2 of 25 (permalink) Old 04-03-2011, 02:21 PM
chevota84's Avatar
A boost elbow is the simplest way, a name brand one like tst and so on will have instructions.
99 Dodge 24v 5spd, tst comp/smarty, 7x.014's, super b over s475, fass 95
chevota84 is offline
post #3 of 25 (permalink) Old 04-03-2011, 02:50 PM
HDKid's Avatar
It depends if it is a HY or an HX turbo. A boost elbow can be used with a HX, but the HY needs a J-hook to gain boost. That's if your turbo is stock.
HDKid is offline
post #4 of 25 (permalink) Old 04-03-2011, 02:55 PM
f44life's Avatar
i dont know what a dieseldynamic chip is....but you need a boost fooler...with my setup and no boost elbow i hit 32psi....i see no reason in my case to increase the boost 3psi
98.5 24v 5spd 53 block 2wd/ raptor 150/ drawstraw/ full mbrp ex/ats intake mani/bhaf/edge attitude/150 nozzles/sb upgraded hydros/sb3600dd and input shaft
f44life is offline
post #5 of 25 (permalink) Old 04-03-2011, 03:44 PM Thread Starter
95ctd95's Avatar
diesel dynamics chip is just a map sensor plug in kinda like the edge ez but do you think if i get a boost fooler i would be alright?
95ctd95 is offline
post #6 of 25 (permalink) Old 04-03-2011, 03:48 PM
HDKid's Avatar
If it has a boost fooler your turbo itself will still be wastegated to 20psi or so. Once you get a boost elbow or j-hook you'll make better boost.
HDKid is offline
post #7 of 25 (permalink) Old 04-03-2011, 05:07 PM
EJS0806's Avatar
So do you need a boost fooler and a elbow or a j hook?? Also can all stock components hold up to a little extra boost outta a stock turbo?? Including the turbo itself??
EJS0806 is offline
post #8 of 25 (permalink) Old 04-03-2011, 05:16 PM
HDKid's Avatar
A boost fooler is needed or the truck will de fuel itself and not create power. a boost elbow is easier and more reliable than messing with adjusting the wastegate. The only way to create boost on an HY turbo is a J-hook. A stock truck will take up to 40psi comfortably.
HDKid is offline
post #9 of 25 (permalink) Old 04-03-2011, 05:30 PM
EJS0806's Avatar
Wow thanks I never knew all that. Where do I find a boost fooler and a hook or elbow?? Also that's not gunna destroy the turbo faster??
EJS0806 is offline
post #10 of 25 (permalink) Old 04-03-2011, 06:03 PM
Lets nip this in the bud before it gets to complicted. Fill out your sig so we kno what year and trans your truck is. All manual trucks had the hx35 turbo. All autos from 98-2000 had the hx35 as well. The autos from 01-02 had the hy turbo. If you have an hx you need a boost elbow. If you have an hy you need a j hook. Dieselautopower.com or ebay are probably your cheapest and best sources. Also you shoudnt exceed 40psi without studs, but furthermore you shouldnt exceed 35psi with an HX or 32psi with an HY. Yes they will spin faster, but its just hot air and eventually something will let loose.
2002 QCSB 6 Speed/ Quad Adrenaline 4k With PV2
/ Raptor 150/ Big Line Kit/ BHAF/ 4 Inch MBRP/ 285 75 Nitto Terra Grapplers
curtis026 is offline
The Following User Says Thank You to curtis026 For This Useful Post:
whitewhale24v (09-28-2014)
post #11 of 25 (permalink) Old 04-03-2011, 06:11 PM
f44life's Avatar
35psi is max on a hx35...after that the turbo is out of its compressor map and it turns into a hairdryer
f44life is offline
post #12 of 25 (permalink) Old 04-03-2011, 06:13 PM
rdix7991's Avatar
So you swapped in a 01 24V. Do you know which turbo you have? HX or HY?
Runs good!
That's all that matters at this point!
rdix7991 is offline
