What size exhaust? - Dodge Cummins Diesel Forum
post #1 of 21 (permalink) Old 03-31-2011, 08:25 PM Thread Starter
Cumminssmoke48's Avatar
What size exhaust?
I have a 2002 Dodge 3500 Cummins with the NV5600 tranny. It has a slightly modified stock exhaust and wanting a bigger dia. pipe and also the deep noise that comes from a aftermarket exhaust. What size and tip should i get and who should i buy it from so it does not cost an arm and a leg to get.
Your comments please.
Cumminssmoke48 is offline
post #2 of 21 (permalink) Old 03-31-2011, 08:30 PM
organized_confusion's Avatar
IMO it depends on whats done to ur truck. When i had my eadge juice, RV275s and an hx35 i prefered a 4inch exhaust to a 5 inch. But with the setup im running now it competely changed the tone of my truck and i just love the way it sounds with the 5 inch on it now.
As for tips i had a 5inch tip with a 4 inch exhaust but now with my 5 inch exhaust i prefer not having a tip at all. I think it looks way better without one and makes it more of a sleeper.
02 sport 6spd, HRVP, edge hot/smarty, 5" exh, FASS, bored/balanced, 181/210 cam, SB OFE, studs/oringed, 62/71/14, DDP 150, ATS manifold, maxspool springs/pushrods, peak IC boots, wicked bypass, HID, sound system, Kore coils, DT control arms, borgeson box/shaft
organized_confusion is offline
post #3 of 21 (permalink) Old 03-31-2011, 09:22 PM
I don't see tail gates's Avatar
do you want to strait pipe it
blue 2001 2500 5speed 8ft bed 5in strait pipe 8inch tip with ceramic clutch and silence ring removed,smarty s-03,autometer gauges
I don't see tail gates is offline
post #4 of 21 (permalink) Old 03-31-2011, 09:26 PM
if you want to strait pipe it i would go wit 4-5 inch pipe with 6inch tip
post #5 of 21 (permalink) Old 03-31-2011, 09:28 PM
oudive's Avatar
iTrader Score: 5 reviews
Sup,
I had a dual 4" kit that I threw on a couple years back in Florida. It had something like a muffler on it and then it Y'ed out. I lost the drivers side exhaust section....long story for another time.....so I just finished operating on it. I threw a straight pipe to make it just a single exhaust again, and I had forgot how good a straight pipe diesel sounds. I am running a 4" with a 5" tip.
oudive
2013 Lone Star- 3500 CC / DRW / AISIN / 4.10 / Renegade Front Bumper / Hellwig Bags w/wireless AirLift
oudive is offline
post #6 of 21 (permalink) Old 03-31-2011, 09:49 PM
yea and a dodge just makes a strait sound better
post #7 of 21 (permalink) Old 04-01-2011, 07:33 PM
ifyoucantdodgeitramit's Avatar
Well diesels as most of us know aren't like gassers and they don't need back pressure to run correctly for a fact the less back pressure the better u r im going with a 5" dp to 6" to 7" bullhauler stacks straight piped. But if u don't like a loud drone get an exhaust with a muffler. But if u want a straight pipe it really doesn't matter who u get it from it will sound around the same and actaull if u want it to be cheaper go to a custom exhuast shop and they should be able to do just about any size u want, the may not be able to bend it but they can cut pie shapes out to make the exhaust curve and it will be alot cheaper than buying a manufacturers exhuast
01.5 2500 4x4 H.0. 6spd 136k loaded sport bank 4" exhaust k&n cai (movie star: "Adrenaline" signed by John Schneider)plans: mach 5, supercharger,66 dble bat,water/meth,quad adr,mega convr.
ifyoucantdodgeitramit is offline
post #8 of 21 (permalink) Old 04-09-2011, 03:49 AM
money in the mane's Avatar
i have a 5in duel with seven inch tips and i love it! i is so so deep! when you get on it people know your comming! i bought mine off a guy who has semi trucks and just customized to to fit but really you dont even need a bend you could go straight and just set it as high as you can! i perfer a 5 over a four but its between those two. if you really start to modify it you could go with a six and it sounds sweet but if you dont have enough mods to your truck they sound stupid.. just my input for you
98.5 quad with long bed, a quadzilla with adrenaline, fass 150, 4in jake brake, afe intake, custom 5in duel with 7in tips, custom intake mainifold, afe intake, 35's, 62mm
money in the mane is offline
post #9 of 21 (permalink) Old 04-09-2011, 12:53 PM
f44life's Avatar
4 or 5inch exhaust...it dont matter either one sounds deep...nobodies going to be like i know that is a 4inch exhaust because it sounds higher pitched then my 5inch...who gives a shat...either one does the job and makes the sound
98.5 24v 5spd 53 block 2wd/ raptor 150/ drawstraw/ full mbrp ex/ats intake mani/bhaf/edge attitude/150 nozzles/sb upgraded hydros/sb3600dd and input shaft
f44life is offline
post #10 of 21 (permalink) Old 04-09-2011, 08:45 PM Thread Starter
Thanks everyone for your comments and opionions.
post #11 of 21 (permalink) Old 04-10-2011, 05:52 PM
this is the one i got last year. it was a super easy install and the best deal around. i love it!
Rollin Smoke Diesel. 1994-2002 Dodge Cummins 5" Turbo Back Exhaust (No Muffler)
02 2500 QCLB 4X4 6spd (BHAF, 5" Exhaust)
SMP142 is offline
The Following User Says Thank You to SMP142 For This Useful Post:
cummminsV12 (04-13-2011)
post #12 of 21 (permalink) Old 04-10-2011, 08:25 PM
I got my 4" from summitracing.com for 299 or 399 I cant remember. The one I got was aluminzed and if you pay 100$ bucks more you can get stainless. It has a glasspack style muffler
SOLD! 2001 QCLB 2500
2010 CCSB 2500 Big Horn, Auto, Webasto engine heater, Firestone air bags, H&S EGR delete, Smarty JR, 4" aFe DPF delete, B&W Turnover ball
Smurfry is offline
